Are you reusing the two anti squeal shims on front brake pads ?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 2016Tacoman, Oct 26, 2021.
  1. Oct 26, 2021 at 6:27 AM
    2016Tacoman
    2016Tacoman [OP] Well-Known Member
    J
    2016 Tacoma 4x4 V6 Metallic
    Are you guys reusing the antisqueal plates on your front pads when changing pads ?
    Mine are dirty. Didn't know whether to just slap them back on, or clean them and put some of that red antisqueal stuff in between.
    Thanks.
  2. Oct 26, 2021 at 7:46 AM
    airforceb2cc
    airforceb2cc Well-Known Member
    Don
    KCMO
    2021 DCSB Nightshade
    Ironman FCP; 315/75R16; KDMAX; Skids; Sliders
    My new pads came with new shims.
  3. Oct 26, 2021 at 7:59 AM
    Clearwater Bill
    Billy
    Largo Florida
    Quality pads will normally come with new shims.
    You can clean the old ones and use anti squeal lube in the same way you do in your bi-annual brake servicing.
  4. Oct 26, 2021 at 8:01 AM
    MidCitiesMildMan
    MidCitiesMildMan Well-Known Member
    2017 Toyota Tacoma Limited
    Stock and staying that way
    I’m a little bit behind. Mind detailing this?
    Key-Rei and SDTaco4x4 like this.
  5. Oct 26, 2021 at 8:04 AM
    Clearwater Bill
    Billy
    Largo Florida
    More for folks who off road a lot and/or live in salt country.
    It's worth while to clean, lube, adjust brakes on a minimal of bi annual basis.
    No new parts generally needed, unless your work finds something needing attention.
    Water, mud, salt are not good for any part of the vehicle, but tip top brakes are good for all of us. :D
    Key-Rei, RustyGreen, Vmax540 and 2 others like this.
  6. Oct 26, 2021 at 8:07 AM
    MidCitiesMildMan
    Thank you sir. That makes sense.
  7. Oct 26, 2021 at 8:28 AM
    2016Tacoman
    J
    Bought them from the dealer and no shims. Rip off.
  8. Oct 26, 2021 at 8:34 AM
    2016Tacoman
    J
    Did they use anti squeal lube on the factory build or rely on just the shims? Hard to tell from the old ones.
    Looks like the rubber between the shims takes the place of the lube ?
  9. Oct 26, 2021 at 8:51 AM
    cryptolyme
    cryptolyme Well-Known Member
    Virginia
    2021 SR Access Cab 4x4 2.7L
    some of the cheap-o pads don't come with shims. you can just clean and reuse them.
    2016Tacoman[OP] likes this.
  10. Oct 26, 2021 at 11:34 AM
    Clearwater Bill
    Billy
    Largo Florida
    Dunno. I've never had a new one apart.
    IIRC Toyota offers 2 types of replacement brake kits. A std. and a value set, value being pads only, std. having all the other bits. But I could be wrong about that. Or it could have changed.
  11. Oct 26, 2021 at 11:53 AM
    CanadaToy
    CanadaToy Well-Known Member
    Greg
    Toronto
    17 DCSB TRD OR Alpine
    TRD Pro grille & skid, OEM tonneau and roof racks
    I replace the shims if they are rusting / falling apart. if they are in good physical condition i will clean them and re-use with new grease.
  12. Oct 26, 2021 at 11:56 AM
    ppham444
    ppham444 Well-Known Member
    Phuong
    Portland, OR
    2023 White TRD Off-Road doublecab
    I just changed my front brakes last month with OEM pads and rotors. They didn't come with new shims, but I reused mine. So far no issues.
  13. Oct 26, 2021 at 12:14 PM
    rolled93slc
    rolled93slc Well-Known Member
    Jerry
    Lynchburg VA
    16 Tacoma TRD Sport DCSB MGM
    I'm a Toyota tech, I can confirm there are two different "grades" of pads. The difference is one comes with new shims, at a much higher price. The other w/o shims. We always clean and reuse the original shims when possible. I have done this on vech with 150K plus miles with no issues. So reuse your originals without worry my friend.
    HP11 and RustyGreen like this.
  14. Oct 26, 2021 at 2:53 PM
    2016Tacoman
    J
    So you are saying no grease between shims ?
    Also, are both grade pads the same, it's just the added shim pack, or are the pads better in the ones with the shims ?
    Dealer wants $100 just for the pads.
  15. Oct 26, 2021 at 6:58 PM
    rolled93slc
    Jerry
    Lynchburg VA
    From what I can tell. The shims is the only difference between the two different grades of pads. Both grades of pads have the same numbers and markings on them. Put grease between the back of the pad and the shims. It doesn’t take a lot. Just a thin layer to hep the shim stick to it. At my dealer the pads w/o the shims are $70.
    RustyGreen likes this.
  16. Oct 26, 2021 at 7:02 PM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    Living in AZ. I cleaned and reused mine, just added some ceramic grease when I did mine
  17. Jan 7, 2022 at 11:52 AM
    1Shifter
    1Shifter Well-Known Member
    Jeff
    Outta the black and into the blue
    09 PreRunner
    Same as everybody else...
    I'm getting ready to replace the pads with a set from my local dealer. He recommended to replace the shims but from what I'm reading I can reuse the old ones. Pads only is $66, shims are $35.
  18. Jan 8, 2022 at 4:00 AM
    kgilly
    kgilly Well-Known Member
    Kurt
    Pennsylvania
    2016 DCSB SR5 4x4
    Bed cover and Mud flaps, OEM Audio, Super Bump stops, Sumo Springs, Bed Stiffeners, Stryker hood shocks
    Whether you clean and use the original shims or new ones, always coat with anti squeal grease
    na8rboy likes this.
  19. Jan 8, 2022 at 8:39 AM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    When i did the brake pads on my tundra you only got their box with the ceramic pads. I was able to reuse those anti-squeal shims, but had to buy the caliper pad pins to replace the badly rusted, and grooved up ones.
  20. Jan 8, 2022 at 8:44 AM
    SDTaco4x4
    SDTaco4x4 Well-Known Member
    San Diego
    2016 Black TRD Sport 4x4
    Pardon?
