Are Toyo Open Country A/T II Radial Tires - 265/70R16 111T good for a 2015 TRD off-road Tacoma?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by rollemeasy, Nov 12, 2017.
  1. Nov 12, 2017 at 9:48 AM
    rollemeasy
    rollemeasy [OP] Member
    NY metro area
    2015 Tacoma TRD OffRoad AC 6spd
    k&n air filter, TRD short shift kit
    Appreciate any assistance with this...trying to figure out if I should cancel the tire order...
    I did a fair amount of research prior to ordering these tires and thought I was all set. I have not been able to confirm with confidence if these tires are good for my 2015 TRD Off-Road V6 Access Cab Tacoma. Most tire sales websites (Tirerack and the like) do not spec my truck (only the TRD Pro is offered in the selection menus)- frustrating...please help. The order is in and I am still searching for confirmation that the fitment is correct...
    I ordered the correct tire size (265/70 R16) but am unsure if the tire is 'correct' for my Tacoma...the Toyo's seem to match what is the OEM tire on the truck currently (BFG rugged trails) but I haven't been able to confirm fitment.
    Thank you in advance for the assistance !!
  2. Nov 12, 2017 at 9:52 AM
    Fitz235
    Fitz235 Well-Known Member
    Rob
    New Hampshire
    Black '22 DCSB TRD Offroad 4WD
    - TRD T4R Pro Wheels - TRD Lift Kit - TRD Skid Plate - 265/70/17 Toyo Open Country 3's - OEM Bed Lights - OEM Bed mat - Alpharex Tail Lights - TacomaBeast LED Interior Lights - Green Lane Offroad Aluminum Sliders - Place Holder for More Bad Financial Decisions...
    Since that's the stock size on TRD Offroad models, I'd say your good.
    It's a nice tire BTW, I have those now, with about 20k on them, and there appears to be very little wear.
    rollemeasy[OP] likes this.
  3. Nov 12, 2017 at 9:58 AM
    rollemeasy
    NY metro area
    Thanks for reply- I got concerned with the load rating after realizing Toyo actually makes different versions of the Open Country AT II tire. Glad to hear they are working well for you.
    Fitz235 likes this.
  4. Nov 12, 2017 at 10:01 AM
    Fitz235
    Rob
    New Hampshire
    Did you get P, or LT? Either would work, just curious.
  5. Nov 13, 2017 at 12:59 PM
    ArmandHammer83
    ArmandHammer83 This truck is AMAZING
    Raymond
    Alabama
    2018 Tacoma AC V6 MT 4x4
    none yet
    i have these on my '05 and have about 10k miles on them...they sing a little bit ( which i like ) but nothing a turn of the volume knob won't fix.. good choice in my opinion
  6. Apr 16, 2019 at 5:20 AM
    oe40ounces
    oe40ounces Active Member
    Visalia,CA
    08 PreRunner
    Simple bolt-ons and piggy back ems.
    Drilled slotted ceramics front rotors. Gotta tune bk drums. Spend the cash on all terrain off road tires. Shit saved my life couple times. Plus off rd sr5 pk comes with sway bar.
  7. Apr 20, 2019 at 10:29 PM
    joes06tacoma
    Joe
    Central Coast, CA
    Just bought a set in the same size and load rating. So far so good. The weight rating matches up with what the stock tires and the truck itself are rated for. Unless you're planning to overload the truck, all should be good.
    They are a bit loud as mentioned, but I love it. They track better than the Michelin LTX MS2s I had before.
