ARE tonneau cover lift support question
Discussion in 'Tonneau Covers, Caps and Shells' started by Soylent Green2012, Apr 11, 2020.
  1. Apr 11, 2020 at 5:08 PM
    Soylent Green2012
    Soylent Green2012 [OP] RestoRides MotorSports
    jake
    Apopka, Florida
    2012 Tacoma Pre runner SR5 V6 Limited Edition
    chrome bull bar, 20" vision wheels, LED lighting, Custom grill.
    Hey folks I needed some info on the support rods that raise and support the fiberglass top.
    on mine the raised point is maybe 16 to 18" above the rear most portion of the tailgate.
    Can these supports be adjusted to change this distance so it can open wider ?
    Mine is the LSII series. on 2012 tacoma prerunner sr5 DCSB ...
    Thanks jake
  2. Apr 16, 2020 at 4:10 AM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    Go to the Boxi or Strong Arm lift sites or auto store sites and they list all the sizes/lengths compressed and extended and pressures.
    On my ARE shell DCSB I used (2) BOXI 4419 Universal Lift Supports Struts Extended Length: 14.50 Inches, Compressed Length: 9.25 Inches, Force: 35 Lbs. 10mm ball socket Shocks from Walmart online for a pair $16.99. They open up to like 70-80 degrees (90 is up vertical) and have lots of lift so once you pull it up about 6" it will quickly swing up.
    Measure for extended/compressed length from the lift ball sockets.
  3. Apr 16, 2020 at 6:41 PM
    Soylent Green2012
    jake
    Apopka, Florida
    thanks for the update. I will check that out for sure. I even reached out to the company that makes these
    tonneau covers to see if I can get an original manual or parts list. Nothing so far.
