Are the 3rd gen UCA's the same as the 2nd gen???
Discussion in '2nd Gen. Tacomas (2005-2015)' started by pearing, Mar 27, 2019.
  1. Mar 27, 2019 at 3:53 PM
    pearing
    pearing [OP] Well-Known Member
    Wisconsin
    2015 SR5 quadcab
    I got a box of parts to put 3rd gen struts on my 2nd gen and included in the package were the upper control arms. Are they the same or are they going to help with my budget lift? Truck only has 40k on it so things are not worn out yet, just want the low budget lift... Also, any recommendations on spacers? Want 2-21/2 total out of this project. Truck is a parking-lot queen and will see limited dirt if any.
    Thanks in advance
    Pat
    OhDannyBoy likes this.
  2. Mar 28, 2019 at 11:26 AM
    pearing
    Wisconsin
    2015 SR5 quadcab
    A nybody know the answer here?
  3. Mar 28, 2019 at 11:30 AM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    Looks like it was answered yesterday right above.
    Naveronski and El Duderino like this.
  4. Mar 28, 2019 at 11:36 AM
    pearing
    Wisconsin
    2015 SR5 quadcab
    okay-i misunderstood that post... thanks for pointing out the obvious (I needed the help!)
  5. Mar 29, 2019 at 7:23 AM
    OhDannyBoy
    OhDannyBoy Well-Known Member
    DFW’s Southern Star
    2015 4x4 DCSB SR5
    I swapped the original coils and shocks on my 2015 SR5 4x4 (30K mileage) with take-offs from a low mileage (<4K) 2017 TRD OR and added a 1/2 spacer from Headstrong Off-Road - Net lift was 4 cm/1.5 inches in the front (nothing in the back, obviously) - be sure to get an alignment after install - truck looks and rides great!
    winkel likes this.
  6. Mar 29, 2019 at 7:34 AM
    pearing
    Wisconsin
    2015 SR5 quadcab
    Thank you OhDannyBoy!
  7. Mar 29, 2019 at 7:41 AM
    ALI3N_123
    ALI3N_123 ( -_・)ᡕᠵ᠊ᡃ່࡚ࠢ࠘⸝່ࠡࠣ᠊߯᠆ࠣ࠘ᡁࠣ࠘᠊᠊ࠢ࠘
    Eric
    Austin, Texas
    2021 Silver TuRD Squirt DCSB 4x4 // 2008 Black Rusty Shitbox DCSB PreRunner
    I have 3rd gen coils, and a 1" lift spacer on mine with stock upper control arms.
  8. Mar 29, 2019 at 8:00 AM
    OhDannyBoy
    DFW’s Southern Star
    2015 4x4 DCSB SR5
    In your pic it looks like you have a 1/2 inch spacer (giving you 1 inch of lift) - not sure you could get the nuts to thread on those original top hat studs with a 1 inch spacer in there - or am I seeing things?
    Truck looks good!
    winkel and ALI3N_123[QUOTED] like this.
  9. Mar 29, 2019 at 8:01 AM
    ALI3N_123
    Eric
    Austin, Texas
    The spacer is .5" thick
    OhDannyBoy[QUOTED] likes this.
  10. Mar 29, 2019 at 8:32 AM
    junkyardyote
    junkyardyote Well-Known Member
    2010 4x4 sr5 4.0 crew cab/ 2023 TRD Offroad DCLB 3.5 auto
    I really like that idea,too much work but seems like the right way to go. Did you put the 17 ucas on there?My spacers on my leveling kit are too high,hard to align.
  11. Mar 29, 2019 at 10:35 AM
    pearing
    Wisconsin
    2015 SR5 quadcab
    Thanks guys-this is what I was after. Headstrong is out of spacers, but there are others I am sure. I also got rear shocks and spring packs!
  12. Mar 29, 2019 at 6:54 PM
    OhDannyBoy
    DFW’s Southern Star
    2015 4x4 DCSB SR5
    I did not use the 17 UCAs - they’re identical to what’s already on my 15...I did have longer studs installed on the top hats (for peace of mind) since the 1/2 inch spacer left fewer threads for the nuts to grab (did I just type that? lol)
    The labor for installation was $360 including alignment.
  13. Jun 16, 2023 at 8:35 PM
    Jdilla83194
    Jdilla83194 Active Member
    Carlos
    Colorado
    2006 Radiant Red Tacoma TRD Sport, Access Cab
    Just got a 3rd gen suspension to put on my 2nd gen, also came with a 1” rear block. I’ve read that it can give an about a 1” lift on the 2nd gens. I already have a 2” spacer on there sooo would that really give me 3” lift?anyone have experience on this? And would that much lift just start messing up my suspension/ride quality
  14. Feb 12, 2024 at 3:50 PM
    cswires
    cswires New Member
    TN
    05 Tacoma Access 4x4
    Did you ever figure this out? Getting ready to put 3rd gen shocks on my 2nd gen that has 2" spacer on it. I do NOT want 3" of lift
  15. Feb 12, 2024 at 10:08 PM
    wi_taco
    wi_taco My skid plates give rocks taco flavored kisses
    Adam
    SE Wisconsin
    2015 Toyota Sienna with rear locker
    Quoting so it can’t get edited. How did that whole “limited dirt” thing work out, friend? :rofl:
    Have you fellas considered making your own post in the suspension section linked below rather than hijacking a thread that was originally about UCAs? Because if not and if you want answers that’s something you can look into. Just saying.
    https://www.tacomaworld.com/forums/suspension.18/
    Strictlytoyz likes this.
  16. Feb 13, 2024 at 3:42 AM
    pearing
    Wisconsin
    2015 SR5 quadcab
    Third gen works fine on second gen. Bolt right up. If you have OR or better shocks and springs you get around an inch of lift. So YES, it works upper shocks springs the whole mess. Ran it for years with a .75" spacer too (oh the drama!!) so I had about 2- 2 1/2 inches of lift.
    2inch spacer-cryptic... is it really a 2" spacer or a 1" spacer (which will give you 2")????
  17. Feb 13, 2024 at 3:43 AM
    pearing
    Wisconsin
    2015 SR5 quadcab
    Worked great and then I found this bunch... 35's baby (although I think I can 37's to work...)
    wi_taco[QUOTED] likes this.
  18. Feb 24, 2024 at 2:56 PM
    cotton2011trd
    cotton2011trd Well-Known Member
    Cotton
    Maine
    2011 TRD 4WD Metallic grey
    Westin Sportsman Brush guard. Sony XAV-AX5600 head unit, head, and taillight strobes.
    So they ended up fitting? I’m looking at the same solution.
  19. Feb 24, 2024 at 4:18 PM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    Front spacers will give you approximately double the lift, rear blocks are one for one.
    A 1" spacer in the front will give you about 2" of lift.
  20. Feb 24, 2024 at 5:53 PM
    pearing
    Wisconsin
    2015 SR5 quadcab
    ifvyou are asking about the 35’s they do but require lots of extra work and trimming. 37’s would just be ego and not worth it
