ARE struts
Discussion in 'Tonneau Covers, Caps and Shells' started by tomwilson74, Jan 9, 2018.
  1. Jan 9, 2018 at 4:16 AM
    tomwilson74
    tomwilson74 [OP] Well-Known Member
    Tom
    West Virginia
    2020 TRD double cab OR
    OME 3” lift Mickey Thompson Classic III Wheels
    Looking for some mew struts for the back door of my ARE shell. Are these things universal or do I need something specific for my camper shell?
  2. Jan 9, 2018 at 11:22 AM
    dman100
    dman100 Well-Known Member
    Central Coast, California
    2016 TRD OR DCSB
    The length, the end fittings and the strength (force) of the spring are all variable, but most auto parts stores (Autozone, O’Reilly’s, you don’t need to go to a specialty shop) have a huge selection and you should be able to find what you need.
  3. Jan 9, 2018 at 11:24 AM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    http://www.truckoutfittersplus.com/store/topper_parts_gas_props_toppers.htm
    I used the above website and looked at the tag# on the shocks that were on my rear window to track down the part number I needed. I then found the same shocks on Amazon for half price. The website I posted is mainly to just help you find the part number and the collapsed/extended lengths & lbs rating of the ones you need(ie they arent all universal fit, but most are similar). Let me know if you have any q's
  4. Jan 9, 2018 at 7:48 PM
    Bajatacoma
    Bajatacoma Well-Known Member
    SC
    05 TRD Off-Road, SR5, 6 speed
    There should be a part number on them, there was on my ARE. I just put that in Amazon and it pulled them right up. Only takes a couple of minutes to swap.
    tomwilson74[OP] likes this.
  5. Jan 14, 2018 at 11:32 AM
    stbear
    stbear Well-Known Member
    SE PA
    2015 DCSB TRD Sport MGM
    I got mine from Amazon. Easy to match from info on shock.
  6. Jan 14, 2018 at 7:22 PM
    Snotrocket
    Snotrocket Well-Known Member
    Maine
    2022 TRD OR DCLB
    The lift struts were junk on my Century cap. I took one off and into a local Carquest and they had them in stock.
    A little less than $40 for both.
