Are shims need for this lift?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Yotathegreat, Feb 4, 2019.
  1. Feb 4, 2019 at 4:54 PM
    Yotathegreat
    Yotathegreat [OP] Member
    Trd OFF-ROAD
    17 offroad double cab
    OME 886 firm shock
    Heavy Dakar springs
    Diff drop
    Carrier bearing drop
    Camburg UCA's
    1/4 top plate
    17×8.5 Methods w/ 0 offset
    Not sure on tires yet. Might try 295's o_O
    Do I need rear axle shims for this? If so what degree? Can't find much about it..Anything else I may need?
  2. Feb 4, 2019 at 5:07 PM
    TXTRDOR
    TXTRDOR IG @txtrdor
    18 DCSB TRD OR 4X4
    So...
    Don’t do the diff drop
    Don’t do the carrier bearing drop
    Do measure your angles before and after the install
    You’ll probably need a 3* shim. I just did 887s and Dakars and needed a 2.5*.
    Dr. Emmett Brown likes this.
  3. Feb 4, 2019 at 5:07 PM
    Dr. Emmett Brown
    Dr. Emmett Brown Well-Known Member
    You can't guess/be given the answer to this question. You'll have to measure before and after drive shaft angles. That's the only way.
    Slashaar likes this.
  4. Feb 4, 2019 at 5:08 PM
    Hans7
    Hans7 Well-Known Member
    2017 TRD OR 4X4, DCSB, MGM
    TRD Pro fogs, tint, OV Tuned 1.05, TRD Pro grille, Winjet Taillights, Meso Custom turn signals, Rhino lined rear bumper, dipped emblems, F5 3.5 BS wheels, Wrangler UltraTerrain 32s, Radflo 2.5 COs/All Pro leafs w/Fox rears, custom bedrack w/ Smittybilt RTT/ditch and bar lights/ pelican hardcase/shovel.
    I would do axel shims before I would do a diff drop if eliminating vibs is your concern. And typically the degrees necessary is equal to the inches in lift you’re adding to the rear.
  5. Feb 4, 2019 at 5:13 PM
    jsinnard
    jsinnard Well-Known Member
    J
    Virginia
    16 QS DCLB OR 4X4
    Rule of thumb is 1 degree for every 1 inch of lift so if 3 inch lift, 3 degree shims as a start.
    Slashaar, bzzr2 and Yotathegreat[OP] like this.
  6. Feb 4, 2019 at 5:17 PM
    jsinnard
    J
    Virginia
    16 QS DCLB OR 4X4
    Consider adding ECGS bushing replacement for needle bearing.
  7. Feb 4, 2019 at 5:18 PM
    13txtaco
    13txtaco Well-Known Member
    Katy Texas
    2013 Tacoma 4x4
    If needed i have a new set of 3 deg fs
  8. Feb 4, 2019 at 5:18 PM
    bzzr2
    bzzr2 Well-Known Member
    save yourself the hassle of taking it apart after install by adding a 2.5/3 degree shim from the start.
  9. Feb 4, 2019 at 5:19 PM
    bzzr2
    this you could wait and see if you need or not. i didn't add this to my current or previous tacoma
    Yotathegreat[OP] likes this.
  10. Feb 4, 2019 at 5:19 PM
    Yotathegreat
    Trd OFF-ROAD
    Why not diff drop or bearing drop? Everywhere I have look calls for one anything over 1.5 inches. Plus it makes since to do it, but it's my first tacoma
  11. Feb 4, 2019 at 5:20 PM
    Dr. Emmett Brown
    lol that's what I'm doing. More chances of needing a 3 degree shim when I put my Dakar HD pack on so I'm putting it on and if I gotta change it, that's what I'll do
  12. Feb 4, 2019 at 5:21 PM
    bzzr2
    start at rear shims! the front stuff is not as frequently a requirement, the diff drop is a personal preference that most feel is not needed. i didn't use the one that came with my kit and don't plan to
  13. Feb 4, 2019 at 5:22 PM
    bzzr2
    i used shims with my dakar pack on my regular cab with success, had no vibes. used a 3 degree with my add a leaf on my 2018 trd access cab and removed the factory shim that looked to be around 1 degree, drives the same vibe wise as when stock.
  14. Feb 4, 2019 at 5:24 PM
    Hans7
    It’s generally not necessary to do a diff drop. I’ve got 2.75” up front and my CVs look totally fine. Additionally, you’re literally putting important shit (your diff) closer to the ground... where it could get smashed. We lift our trucks to get ground clearance, then some dudes lower it right back down. Doesn’t make since to me! Lol
  15. Feb 4, 2019 at 6:48 PM
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    No, not necessarily.
    I have a 3” lift, no carrier bearing drop kit, no diff drop kit, no shims, and no vibes
    synaps3, Lt. Dangle and oscolivar1 like this.
  16. Feb 4, 2019 at 6:52 PM
    rollin904
    rollin904 Feather Slinger
    TJ
    Greenville, SC
    '14 DCSB 4x4
    Dont shoot at the hip on this one, measure before your lift so you can see how it changes. I just threw shims and spacers at mine instead of measuring before lifting and I'm still screwing with it two years down the road.
  17. Feb 4, 2019 at 7:14 PM
    bzzr2
    Well if you’re still screwing with it 2yrs later uuummmm.... it either can’t be that bad or you really dunno what to do??
  18. Feb 4, 2019 at 7:19 PM
    rollin904
    TJ
    Greenville, SC
    '14 DCSB 4x4
    Yup the latter, I didnt measure so I've just been guessing and throwing things at it.
  19. Feb 4, 2019 at 7:24 PM
    bzzr2
    Well shard. This is a whole new thread requirement!!
  20. Feb 4, 2019 at 7:32 PM
    rollin904
    TJ
    Greenville, SC
    '14 DCSB 4x4
    Lol yea best one I've read so far is the first one that comes up if you search driveline vibes. I've tried 2, 2.5, 3, and 3.5 shims with various CB shimming, so I've recently pulled my shims out and seeing if just CB shims will get it vibe free. The vibes arent bad enough to break anything but they wear on your nerves after a while
