Are magnetic oil plugs worth it, if so what's recommended
Discussion in '3rd Gen. Tacomas (2016-2023)' started by dan7365, Jul 8, 2024.
  1. Jul 8, 2024 at 12:08 PM
    dan7365
    dan7365 [OP] Member
    Dan
    2018 Tacoma Double Cab TRD Off Road
    None
    Hello everybody,
    I've got a 2018 Tacoma Double Cab Short Bed TRD-Off Road A/T and recently made the decision to start doing my own tire rotations and oil changes. I've already ordered oil, oil filter, MotivXTools oil filter wrench, drain tool and funnel, since then I've read that it's recommended to replace the oil plug crush washer when ever you change the oil, is that true and if so do I have to use OEM or can can I use another brand that available sooner, also is it worth just replacing the plug with a magnetic one and what brand is recommended?
    Thank,
    Dan
    boston23 likes this.
  2. Jul 8, 2024 at 12:14 PM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    Opinions on oil / oil changes / oil filters are a dime a dozen.. But heres my $0.02. No, a magnetic drain plug not really needed on a system that has a filter
    As for crush washers, they are cheap enough to replace every time. But the world isnt going to end if you reuse them :D
  3. Jul 8, 2024 at 12:15 PM
    NoOne
    NoOne El Taco Guapo
    Ø ©
    Gulf South
    2022 Tacoma DCLB OR (AT) - BC
    2018 SR5 - (Sold) 2018 OR - RIPieces 2022 OR - BluCrush
    I order them in bulk from Amazon, I also use GoldPlug replacements because they are machined and use a strong neodymium magnet. Do whatever suits you, as you’re the one under there. I’m already saving money doing it right myself… I prefer to spend the money on things that make my life easier and worry free.
  4. Jul 8, 2024 at 12:18 PM
    fxntime
    fxntime Well-Known Member
    2015 Tacoma off road TRD and 2014 FJC
    As long as you have a steel pan, placing a strong [I have some stupidly strong magnets lying around] magnet right by the drain plug works pretty well. I would say that putting a little grease between the magnet and the pan is a good thing to make sure, if in a rust prone area, no water gets under the magnet and causes localized rusting.
  5. Jul 8, 2024 at 12:20 PM
    Dark_Taco
    Dark_Taco Well-Known Member
    2023 TRD Pro
    Stock
    Stevie17 and Jakerou like this.
  6. Jul 8, 2024 at 12:36 PM
    nds0000
    nds0000 Well-Known Member
    Agree. No magnetic drain plug, but I do cut open my oil filters and inspect for any debris.
  7. Jul 8, 2024 at 12:40 PM
    JdevTac
    JdevTac Well-Known Member
    Josh
    GA/WA
    2nd gen
    I bought some of the Amazon special OEM washer clones and the adhesive under the felt melted/seeped out and my drain bolt loosened. Never again. Was just checking reviews after I already changed the oil and someone mentioned it happened to them and sure enough, first highway drive it happened to me.
    YMMV.
  8. Jul 8, 2024 at 12:45 PM
    TacoGlenn
    TacoGlenn Nobody Makes a Monkey Outta Me!
    PNW
    '13 MGMAC 2.7L SR5
    Hellwig 1251's, Leer 122, Kahtec smart stop delay flashing 3rd brake light, de-chromed, de-badged, WeatherTech mats, WeatherTech side window deflectors,
  9. Jul 9, 2024 at 9:01 AM
    crockett8513
    crockett8513 Member
    I just changed my oil and noticed the washer stuck to the pan. I believe it came off every other time. Since it didn't fall off, I just reused it and left it there. No issues yet
