are degreasers ok for wheels, tires, and wheel wells?
Discussion in 'Detailing' started by TacoTitan11, Jan 20, 2012.
  1. Jan 20, 2012 at 8:56 PM
    TacoTitan11
    TacoTitan11 [OP] Well-Known Member
    Mr. C
    North Carolina
    2012 Tacoma
    what is a safe cleaner to use on wheels, tires, and wheel wells? is there something out there that i need to watch out for? like greased lighting? i heard someone once tell me to be careful with certain degreasers. any inputs guys? simple green maybe???? :confused:
  2. Jan 20, 2012 at 9:09 PM
    TacoTitan11
    Mr. C
    North Carolina
    2012 Tacoma
    car wash stuff not strong enough to loosen all that dirt and grime on tires and fender walls. for the wheels, i can see doing that.
  3. Jan 20, 2012 at 9:12 PM
    Tacolover443
    Tacolover443 Well-Known Member
    Kyle
    Haverford, PA
    07 TRD OR DCSB BSP
    Satoshi, color match grill, 2 Hella 500ff's, rear TSB, yellow "Taco", OEM all-weather floor mats, OEM TRD seat covers, Ultra-Gauge, bed linered rear bumper, Plasti-dipped rims, DuraTrac's,
  4. Jan 20, 2012 at 9:18 PM
    dYL0n
    dYL0n أنا لست الإسلامي
    Dyl0n
    New Orleans, LA
    17TRDORDCSBQSJBLKBRO2SPECU1.04
    1.04. Kbro2s. ICONS.
    Simple Green or Purple Power, used both of those. Both worked fine on my wheels. They're chrome. Best results for fender wells is degreeser and dress them lightly once truck is dry. Best thing for tires?? Comet powder and water. AMAZING.
  5. Jan 20, 2012 at 9:26 PM
    TacoTitan11
    Mr. C
    North Carolina
    2012 Tacoma
    simple green or purple power? interesting......do you have to dress inner fender walls after using a degreaser?
  6. Jan 20, 2012 at 9:58 PM
    TacoTitan11
    Mr. C
    North Carolina
    2012 Tacoma
  7. Jan 20, 2012 at 10:04 PM
    Maverick904
    Maverick904 Resident Fishing Expert
    Kameron
    Northeast Florida
    08 TRD Rugged Trail 4x4
    3" Procomp Lift, BDF Light Bar, Borla Stainless Cat-Back System, 2 10" Polk MM Subs, LED Interior Lighting, Pioneer Touch Screen, Kicker Speakers up front, Sonys in the back, Grillcraft grill, 20% tint, Weathertechs, Projector Retrofit Headlights. BHLM
    Simple green should be pretty safe. We used it to clean the tiles around the pool I used to lifeguard at. So it would drain down in the water.
  8. Jan 20, 2012 at 10:33 PM
    TacoTitan11
    Mr. C
    North Carolina
    2012 Tacoma
    simple green wont dry out the rubber will it? make it look chalky and white?
  9. Jan 20, 2012 at 10:37 PM
    noSKills858
    noSKills858 battlescars
    Alex
    Poway, CA
    2003 5-lug Prerunner
    Couple shocks, some old tires, and a bad paint job
    The stealerships around here use degreaser on those really stained wheels from brake pad erosion dust. It doesn't affect the tires and leave them with any negative wear or burn. It's when you use brake cleaner on rubber or plastic (unpainted) that destroys it.
  10. Jan 21, 2012 at 8:41 AM
    Gooch
    Gooch Well-Known Member
    Orange County CA
    2000 Tacoma SR5 V6 4x4
    I use 409 on the tires.
    Spray it on the tires when they are dry and let it sit for a few minutes (but don't let it dry). Scrub with a brush and some warm water.
    If your tires are really dirty, you may have to do it a few times. Also, some 409 will inevitably get on the wheels. It strips the wax off, so be sure to rewax the wheels when you're done.
  11. Jan 21, 2012 at 3:04 PM
    wileyC
    wileyC Well-Known Member
    Centerville, OH
    2012 PreRunner Double Cab TRD Sport
    in the owners manual it says to avoid using tire/wheel cleaners and stick to car-wash soap and water, ..perhaps a small brush and wash rag... i have one wash rag i use on the body of the vehicle, and separate one for the wheels...
    keep in mind, degreasers strip wax (which is a grease), so if it gets on the painted areas or on the wheels, if you've waxed them, it will take off the wax..
  12. Jan 21, 2012 at 3:34 PM
    TacoTitan11
    Mr. C
    North Carolina
    2012 Tacoma
    i dont mind if wax comes off the wheels, i just dont want them to be discolored or anything, you know.
  13. Jan 21, 2012 at 3:39 PM
    Tacomanator
    Tacomanator Well-Known Member
    Clam Slammer
    Southern Cali
    King 2.5" extended travel coilovers with compression adjusters, Camburg UCA's, King 2.5" rear shocks, TRD 1st gen CAI.
    Carwash soap normally does the trick for me, but when it doesn't, I use Simple Green or Greased Lightning.
  14. Jan 21, 2012 at 3:41 PM
    TacoTitan11
    Mr. C
    North Carolina
    2012 Tacoma
    looks like we got a winner : simple green
  15. Jan 22, 2012 at 5:49 PM
    SocalMGM
    SocalMGM Well-Known Member
    Huntington Beach, CA
    2010 MGM SR5 Longbed
    Spindle lift, Bilstein 5100's on all corners, Ultragauge, CB radio, BFG all-terrains 285/75/16, satoshi grille, Desert guy's Light bar, 4 Hella 700's converted to HID, 5000k HID headlights, 3000k HID foglights, Raceline "predator" wheels
    Simple Green!
    Ive been using it on my tires and wheel wells without any issues.
    Just be sure to watch where you spray it, Simple green DOES strip wax!
  16. Jan 22, 2012 at 5:51 PM
    fletch aka
    fletch aka www.BeLikeBrit.org
    Gary
    Left Coast
    09 Magnetic Gray TRD OffRoad
    TRD cat back exhaust, TRD Cold Air Intake, differential breather mod' Hellwig rear sway bar, 16x8 TRD Ivan Stewart's, Michelin LTX A/T2, DTRL Stealth Mode Mod, custom "Texas Edition" shift knob, Sock's "Classic" bedside decals, MetalMiller custom grill emblem, 20% front tinted windows, tinted taillights, Viper alarm, ScanGauge II, Flyzeye Designs V2W Tacoma Interior LED lighting, de-mud flapped, de-badged, extra D-rings under bed bolts, WeatherTech ED floor mats, G4 Elite Fold a Cover ,Toyota bed mat, tailgate theft deterrent device and absolutely no plasti-dip!
    I use nothing but simple green and rinse very well.
  17. Jan 25, 2012 at 5:19 PM
    TacoTitan11
    Mr. C
    North Carolina
    2012 Tacoma
    anyone else have a simple green success story?
  18. Feb 1, 2012 at 6:07 PM
    differential
    differential Member
    Dallas
    Black Pre Runner
  19. Feb 2, 2012 at 2:41 PM
    RedTaco2134
    RedTaco2134 Well-Known Member
    Scott
    Portland, Or
    08 Long Bed TRD Sport
    295/70/17 Cooper STT Pro, Revtek 3" lift. TSB rear and Blistein 5100's http://www.cardomain.com/ride/3097063
    Any kitchen soap will do. They have degreasers in them already and leave a nice shine. Buy a toilet brush from the dollar store and some sponges.
  20. Feb 4, 2012 at 12:18 PM
    jeebee808
    jeebee808 Member
