Are crush washers NEEDED for Diff and Transfer fluid change?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TnShooter, Sep 17, 2014.
  1. Sep 17, 2014 at 6:48 PM
    TnShooter
    TnShooter [OP] The TacomaWorld Stray
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    I went to Toyota to get the needed crush washers to do my front and rear differential along with my transfer case.
    The parts guy came back with 3 crush washers.
    1 regular looking thin washer ( not sure what it is?)
    And 2 big Copper washers.
    This didn't look right to me. And I even questioned him about it.
    He assured me it was the right parts. And I took his word.
    After all he works for Toyota and is looking right at the computer in the Toyota Dealership.
    After looking up at the How-To on the fluid change I can see I only need 1
    copper washer. At this point I am about to say screw it and just reuse the old washers.
    What's the chances I'll develop a leak if I do this?
    For the record. I have never used a new washer on my oil pan.
    And so far all is good. No leaks YET.
  2. Sep 17, 2014 at 7:01 PM
    chetweewax
    chetweewax Well-Known Member
    NJ
    15 TRD Sport
    Homelink mirror (Adding soon) Came with truck: FUEL Rims, Mickey Thompsons, Vinyl Tonneau Cover, Remote Start, 20% front window tint
    I replace mine every second change, unless they looked damaged. I keep extras in the garage. For me I think torquing them properly is more important in keeping it from leaking. I only replace them to be sure, it's only a few $'s every 30000.
    camillethetoy and Toysareus like this.
  3. Sep 17, 2014 at 7:08 PM
    1980 Well-Known Member
    The Dust Bowl
    Some people change washers with every oil change but I've found it unnecessary most of the time. I've yet to change any washers in my '06 and it has never had a leak. In my '87 that I had nearly twenty years I bought an oil pan washer once, not because it was leaking but because someone mentioned that I should. I found that washer the other day going through a box in the garage -- I never put it on and never had a leak. Either my '87 differentials and transfer case didn't come with washers or I didn't notice them, I never put a new one on and never had a leak.
    On some vehicles washers may be needed though. My Dad's Lincoln has dripped oil since he last had it serviced. It's too low for me to crawl under and check but I'm hoping that the service tech just forgot a washer (or maybe doubled up on them) versus stripping out the drain plug threads.
  4. Sep 17, 2014 at 8:12 PM
    gearcruncher
    Canadain bumper technician
    1980 has a great point . In all honesty , I dont remember the last time I replaced a crush washer when changing any of the fluids on any motor or diff / transmission / transfer case and I have done well over a thousand services to customers vehicles .With this said , its not usually mentioned on a forum becuase it would steer new members to beleive that crush washers are not needed. A well seasoned technician can usually determine if the seal will leak as the bolt is being torqued . Silicone is a mans best friend for lazy threads.:D
    Benny123 likes this.
  5. Sep 17, 2014 at 8:17 PM
    EatMyTacomaDust
    EatMyTacomaDust Well-Known Member
    2014 "Black Beauty" Baja DC 4x4
    ICON 3" LIFT, Console Vault, Tailgate Security Clamp MOD, SuperBumper Crash Attenuator, TRD Front Skid Plate, Wet Okoles - 1/2 Piped, Undercover SE Tonneau
    On the subject of Oil Pan drain plug washers [that was the subject at one point right?], I've never bought a new vehicle that ever had one.
    Neither of my new Tacoma's had one either. But I do add them at the first oil change.
    I can't add anything about the diff washers - sorry.
  6. Sep 17, 2014 at 8:37 PM
    Taco'09
    Taco'09 Well-Known Member
    OP,
    Front Diff: the fill plug uses the crush washer, the drain plug uses the large copper washer.
    Transmission: fill and drain plugs both use that flat aluminum washer.
    Transfer Case: fill and drain plugs both use that flat aluminum washer.
    Rear Diff: fill and drain plugs both use the crush washer.
    Post back if you need actual part numbers.
  7. Sep 17, 2014 at 8:57 PM
    TnShooter
    Deogee
    STOCK
    No, I don't the part numbers. But thanks for asking.
    And Thanks for the info on where each goes.
    Here is what I plan to do.
    I will reuse the fill plug washer on the transfer case.
    I only got 1 aluminum washer.
    By the time go back to Toyota
    and get the washer I'll have over $15.00 in washers.
    $13.03 for 6 washer, not counting my time or gas to get them.
  8. Nov 9, 2014 at 8:42 AM
    BoredIdea
    BoredIdea Member
    '15 Taco
    K/N, Redline Oils
    What are the torque specs for these?
    Fr, Rr, T/C, Trans?
  9. Nov 9, 2014 at 8:44 AM
    TACORIDER
    TACORIDER Just another statistic
    JAKE
    EAST TAWAKONI TEXAS
    12 TACO and some other Toyota’s
    If it drips replace it, my moms Corolla has 230,000 miles on it so after removing and torquing numerous times I bought a new one because it because beveled. I splurged on the 50 cents
  10. Nov 9, 2014 at 10:57 AM
    Taco'09
    Front Diff: Fill - 29 ft.lbs; Drain - 48 ft.lbs.
    Rear Diff: Fill - 36 ft.lbs; Drain - 36 ft. lbs.
    Manual Transmission: Fill - 27 ft.lbs; Drain - 27 ft. lbs.
    Automatic Transmission (A340): Oil Filler Tube - 8.9 ft.lbs; Drain - 15 ft.lbs.
    Automatic Transmission (A750): Fill - 29 ft.lbs; Drain - 21 ft.lbs.
    Transfer Case: Fill - 27 ft.lbs; Drain - 27 ft. lbs.
  11. Nov 9, 2014 at 3:27 PM
    08TacoTrD
    08TacoTrD Well-Known Member
    08 TRD Offroad
  12. Nov 9, 2014 at 3:33 PM
    styk
    styk Well-Known Member
    Greg
    New Brunswick
    Inferno 17 TRD Sport DCLB 4x4
    in-channel vent visors
    I didn't used to change them until one day I stripped the threads on the oild drain. For all the cost, I now change it every time and carefully torque it. Your less likely to over torque it with a new washer.
  13. Nov 9, 2014 at 3:44 PM
    monkeyface
    monkeyface Douchebag, or just douche if we're friends
    Colorado
    '90,'97,'12,'05 Tundra 4.7,'07 T4R 4.7,'08 T4R 4.7
    No. I haven't had crush washers on front diff, transfer case, rear diff and oil pan for 20 years on four different Toyota trucks. No leaks.
  14. Dec 30, 2015 at 9:36 PM
    mahaloTaco
    mahaloTaco TcBob's BFFL
    Max
    Los Angeles
    13 RC 4x4 S/C'd lockers 4.88's Airflow Snorkel McNeil Glass
    I could use the part numbers!!
  15. Dec 30, 2015 at 10:19 PM
    Taco'09
    Here ya go:
    - Large copper washer for front diff drain plug: 90430-24003
    - Crush washers for front diff fill, rear diff fill an rear diff drain: 12157-10010
    - Aluminum flat washers for transfer drain and fill, and transmission drain and fill:
    90430-A0003. << Edit: part no. has changed this is new part number.
  16. Dec 30, 2015 at 10:26 PM
    kodiakisland
    kodiakisland Well-Known Member
    NW Arkansas
    12 AC 4x4 2.7L 5MT
    5100s/1.6in eibachs, wheelers AAL, OME N182 rear shocks, 4.56s, Detroit truetrac, 255/75/17, SOSConcepts sliders
    My rear drain plug doesn't have a washer. I noticed it laying on the ground after I filled the diff. It has 5K miles with no leaks. I'll try to remember to put it on in a year when I change the fluid again.
  17. Dec 31, 2015 at 10:11 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    I always change them.
    O'DubhGhaill likes this.
  18. Jan 1, 2016 at 12:22 PM
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    If you're only draining the rear differential and need to replace that washer, you can use the following part available at O'Reilley's and other mass marketers:
    Dorman 095-149. AutoZone's part number is 095149
    You can cross reference OEM numbers with others at this site:
    http://www.autopartoo.com/
  19. Sep 7, 2016 at 6:32 PM
    Jakefromflorida2009
    Jakefromflorida2009 Member
    Jake
    1995 Single cab Tacoma 3.4L V6 4X4
    Sorry to dig up a old post, but about to do both difs, transmission and T case. I looked up the above part numbers and the first number says not compatible with my truck??? 95 Tacoma 3.4? I can't believe it would be a big deal or difference but want to make sure...
  20. Sep 7, 2016 at 9:11 PM
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    Welcome to TW, Jake!
    Those are/were correct part numbers for both your 1st Gen and our 2nd Gen Tacomas. Note, however, that you posted in the 2nd Gen discussion area. While these part numbers are interchangeable for our vehicles, others are not. Most of your questions will be better answered in the 1st Gen. Tacomas (1995-2004) area. (FWIW, I answered your specific question several years ago when I had my '04.)
    Having just done this service last week, I discovered part #90430-18008 has been discontinued/replaced by #90430-A0003. All other part numbers listed were still valid and pricing remained similar.
