ARE camper shell replacement door/glass
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BigHoss96, Apr 20, 2020.
  1. Apr 20, 2020 at 3:03 PM
    BigHoss96
    BigHoss96 [OP] Well-Known Member
    Matthew
    Boston MA
    2014 DCSB trd sport
    315/75/16 Geolandars on FZJ80 wheels Elka 2.5s RR Coilovers JBA UCA's Moog LCA's All-pro rock sliders All-Pro leaf pack w/ U-bolt flip kit ARB front bumper Badlands 12K winch Spyder Projector headlights\ BD fog lights Cowl air intake relocation
    Found this ARE camper shell online for sale for cheap. The problem is the rear door is missing the glass and looks slightly bent. Any suppliers of ARE parts anyone knows about? Don't have the model number, but its the 2nd gen ARE camper shell for short bed.
    Thanks boys
  2. Apr 20, 2020 at 3:06 PM
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    If ARE is like SnugTop, you must go through a dealer for parts unless you can find them online. For glass, I never found replacements online, just latches, locks and such.
    You'll have to get the serial number and call a local dealer and inquire about pricing. Rough price for actual safety glass and frame will be several hundred dollars, which is why most shells that have broken windows take forever to sell and/or why people end up just getting plexiglass and putting that in.
  3. Apr 20, 2020 at 3:08 PM
    pmstoy10
    pmstoy10 Well-Known Member
    hudson valley, ny
    2010 Tacoma DCLB TRD Sport
    Weathertech Floor Liners, UWS Toolbox, Seatbelt Chime Mod, Coverking Covers, Window Guards, Wheeler's 1.5" Single Leaf AAL, Rear Spring TSB, Front Bilstein 5100's @ 2.5", Rear Extended Travel Bilstein 5100's, removed front mud flaps, Lifetime LED Headlights, Firestone RideRite Air Bags with Daystar Cradles, Light Racing UCA's, ECGS Front Diff Bushing
    I mentioned this somewhere else, but if you have glass coverage with your insurance they may cover that 'loss'. YMMV
  4. Apr 20, 2020 at 4:00 PM
    spp
    spp OC, Kalifornia
    OC California
    Either way a dealer will be needed.
  5. Apr 20, 2020 at 4:13 PM
    pmstoy10
    hudson valley, ny
    Truth
  6. Apr 20, 2020 at 5:19 PM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    ARE has a metal plate riveted on inside roof for that # and all parts available from a dealer.
    JoeKeepsTruckin likes this.
