ARB CKMTA12 Question
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OdiN1701, May 29, 2017.
  1. May 29, 2017 at 2:19 PM
    OdiN1701
    OdiN1701 [OP] Well-Known Member
    Colorado
    2017 Quicksand TRD OR DC SB
    Searched, but can't find what I'm looking for.
    Everything I see says that for the ARB Twin compressor, it requires a manifold for air lockers, filling tires, etc.
    Well, what if I don't need air lockers? If I only wanted to use this for filling tires or whatever else and just needed the one single output, do I really need the manifold?
  2. May 29, 2017 at 2:24 PM
    OdiN1701
    Colorado
  3. May 29, 2017 at 2:25 PM
    4x4Runner
    4x4Runner Sam’s gone, man. Moderator
    Drunken Sailor
    Not north, not south, not west, mostly east
    1WD
    nuttin fancy
  4. May 29, 2017 at 2:26 PM
    OdiN1701
    Colorado
    The twin doesn't have a manifold apparently...or it has one that just has a single output and if you want to run dual lockers + air up, you need the other one.
  5. May 29, 2017 at 2:27 PM
    airborndad
    airborndad Well-Known Member
    Keith
    Montclair, CA
    2017 Black DCLB TRD Off Road 4X4 JBL
    Front Runner Slimline Roof Rack
  6. May 29, 2017 at 2:27 PM
    CenCal805
    CenCal805 Well-Known Member
    California
    2016 Tacoma TRD OR AC
    Weird, I was just about to ask this same exact question. Some say you need it, and some say you don't. Can't make up my mind if I want to order the manifold or just skip it.
  7. May 29, 2017 at 2:28 PM
    OdiN1701
    Colorado
    The photo I linked is on the ARB box for it apparently, looks like they just come right off the compressor itself, no manifold.
    CenCal805[QUOTED] likes this.
  8. May 29, 2017 at 2:34 PM
    airborndad
    Keith
    Montclair, CA
    my thought is it's probably good to have
    mount the pressure switch and relief valve
    and 1 quick disconnect on it and optionally run a line to the back of the truck for another quick disconnect
    again just my initial limited OBA education reply
    see drawing on post #1304
  9. May 29, 2017 at 3:49 PM
    brendanwebster911
    brendanwebster911 Well-Known Member
    Brendan
    Fort Bragg, NC
    2016 DCSBOR 4X4
    Don't need the manifold if you just want to use the compressor as a compressor. Just installed mine today in my other truck. The pressure switch is built in already aswell. I just ran my hose and pressure relief valve off a "T" from the hole on top of the compressor setup.
  10. May 29, 2017 at 5:26 PM
    CenCal805
    California
    Brendan, just received mine in the mail on Friday. Read through the directions and I still have questions. First, do you remember the thread fittings? Secondly, I'm guessing the pressure relief valve is a good idea? I guess I don't understand where the pressure would be built up… Just in the compressor I'm guessing. What bracket did you use? I like how the stainless hose runs into a fixed point on the bracket, looks nice.
  11. May 29, 2017 at 5:36 PM
    brendanwebster911
    Brendan
    Fort Bragg, NC
    2016 DCSBOR 4X4
    The thread fittings are the universal 1/4" NPT.
    I purchased the pressure relief valve (175PSI) just as a precaution in case of an internal pressure switch failure, AND I like to manually release the pressure from the system after use because The pump will keep air inside of it after use. I like to drain the last bit of air out after I'm all done running my air tools or inflating tires.
    The bracket I used for my Raptor (pictured) is from BajaMod. Its specific to the 2017+ F150 Raptor as far as mounting under the rear seats. But I'm sure it can be adapted for many other applications. I had to drill the hole in the bracket to mount the stainless hose and the air chuck myself.
    Link to the mount: https://bajamod.com/detail.php?product_code=BM1017&color=
    Link to the pressure relief valve: https://www.amazon.com/gp/product/B0142ALXTU/ref=oh_aui_detailpage_o05_s00?ie=UTF8&psc=1
  12. May 29, 2017 at 5:44 PM
    CenCal805
    California
    Thanks for the info! I appreciate you taking the time to post those links answer my questions.
  13. May 29, 2017 at 5:45 PM
    brendanwebster911
    Brendan
    Fort Bragg, NC
    2016 DCSBOR 4X4
    Anytime! You're very welcome!
  14. May 29, 2017 at 5:47 PM
    uhplifted
    uhplifted The Hopfather
    Brian
    Huntington Beach, CA
    16 DCLB OR
    Why do you want the dual just to fill up tires? Faster fill up time? Are you planning on running air tools? Or lockers in the future? Just curious as to why not save money and get the single.
    brendanwebster911 likes this.
  15. May 29, 2017 at 5:52 PM
    erok81
    erok81 Well-Known Member
    Imposter
    Exactly. I was originally signed up for the dual in the group buy. But reading (even from arb) they say if it's just tires do the single.
  16. May 29, 2017 at 5:56 PM
    brendanwebster911
    Brendan
    Fort Bragg, NC
    2016 DCSBOR 4X4
    I had the single in my Tacoma (CKMA12) it was GREAT as far as a solid and reliable compressor. It just took a long time to inflate 33"s after airing down, it also couldn't run any air tools. I was kinda sick of sitting in the dirt and waiting for the tires to air up, granted it was only a few mins per tire.
    When i bought my Raptor, I decided on board air is a must and splurged for the dual (CKMTA12) and ill never go back. In inflates my 35" tires crazy fast and i can run my air impact for tire rotations off the compressor. It also can run a lot of other air tools and is very versatile.
    You cant beat ARB compressors, I've had both. But, if i could do it again, id get the dual everytime
    uhplifted[QUOTED] likes this.
  17. May 29, 2017 at 5:57 PM
    CenCal805
    California
    My reasoning was I may in the future want to do a front locker. Also, a few guys on here have a single and wish they would've gotten the duel. By once, cry once sorta thinking, I guess.
    uhplifted likes this.
  18. May 29, 2017 at 5:58 PM
    brendanwebster911
    Brendan
    Fort Bragg, NC
    2016 DCSBOR 4X4
    Exactly... after having both, I would never consider the single again. If you're thinking about the single, honestly, id just save a few more pennies and get the dual.
  19. May 29, 2017 at 6:02 PM
    uhplifted
    Brian
    16 DCLB OR
    I just bought the single for airing up. The no power tools is kind of a bummer which I found out after the fact. The inflate for my 33s isn't too bad. I did a timed run at home and only took 8.5 minutes which was better than my shitty viar I had previously that broke.
  20. May 29, 2017 at 6:04 PM
    brendanwebster911
    Brendan
    Fort Bragg, NC
    2016 DCSBOR 4X4
    For sure better than the Viair! The single is a great little compressor and it worked very well for me. The only downside is time. Im lazy as fuck, and getting old. So, the less time i have to spend squatting down the better lol
    uhplifted[QUOTED] and CenCal805 like this.
