ARB air locker in SR5 question.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Griffin13, Sep 10, 2018.
  1. Sep 10, 2018 at 10:18 AM
    Griffin13
    Griffin13 [OP] Well-Known Member
    2013 Tacoma SR5 DCSB Texas Edition
    OME 884 Coils. GeneralSpringKC 90-297HD Leafs. Bilstein 5100's all around, front set at 0. Toytec 1/4" top plate on driver's side. Leer 100XR Camper Shell. OEM Bed Mat.
  2. Sep 10, 2018 at 10:22 AM
    Hobbs
    Hobbs Anti-Lander from way back…
    Yep…
    Rock Bangen', Desert Tamin', Gold Findin' Machine!
    Griffin13[OP] likes this.
  3. Sep 10, 2018 at 10:24 AM
    16Tacos
    16Tacos Well-Known Member
    Zach
    Boston
    08 Access Cab 4x4 V6 SR5
    OME Nitrochargers w/886s & Dakars, ARB Deluxe Bull Bar w/Warn winch, RCI sliders with kick out, IFS & Mid skids, BFF Hi-clearance rear bumper, Brushed Copper 17" SCS Ray10s w/285-70 KO2s, Black OEM 16" steelies w/255-85 KM2s, Leer contractor cap w/Smittybilt overlander xl RTT, Off-Grid Engineering dual battery kit and bed power panel, Blue sea aux fuse block, Wyntner 60L fridge freezer, ARB dual compressor, Pioneer 720BT head unit, CB radio, @Matt_Gecko bed and engine bay lights, @TacomaTruckParts Dirt bike tie down bar, color matched OEM grill, A-Pillar phone mount mod, @Docloco rear seat molle panel
    @Hobbs has it right, get an assembled third from ECGS. That's what I plan to do once I can afford gears and lockers.
    Griffin13[OP], BassAckwards and Hobbs like this.
  4. Sep 10, 2018 at 10:28 AM
    ItalynStylion
    ItalynStylion Sounds Gooooood
    Steven
    DFW, Tx.
    09 Double Cab TRD Sport 4x4
    I have ARB lockers front and rear that I added to my Tacoma. They are absolutely incredible. I roll around in 4WD until I get to a spot where I start spinning a wheel. Stop, hit the magic button, and BOOM...forward motion again. They make the truck a hugely capable beast; far more capable than it looks.
    Sugar Silva and honda50r like this.
  5. Sep 10, 2018 at 10:31 AM
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    You only want the locker installed and no gears?
    If you're near Seattle I can do that for you
    Sugar Silva likes this.
  6. Sep 10, 2018 at 12:20 PM
    GoXplore
    GoXplore Member
    2007 Tacoma DCLB
    Building for Overland travel. Just got the truck in July of 2018. Added camper shell shore power plug and fan gastric fan to the top. I have a long list of plans yet to come.
    I am going with east Coast gear.
  7. Sep 10, 2018 at 12:23 PM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
  8. Sep 10, 2018 at 12:23 PM
    16Tacos
    Zach
    Boston
    BassAckwards[QUOTED] likes this.
  9. Sep 10, 2018 at 12:28 PM
    BassAckwards
    Me and a buddy installed it in about 2-3 hours. Wasn't bad to install. Hardest part is getting brake lines/brackets out of the way, and pulling the rear axles out just enough to get the old 3rd out and the new 3rd member into place. I already had all the wiring and plumbing in place for the rear locker(I did this before hand), so all we had to do there was plug it in and test it out.
    The wiring for the compressor and locker is the hardest part of this job imo.
  10. Sep 10, 2018 at 12:46 PM
    Griffin13
    I'm located in NW Arkansas so either coast is a bit of a drive and not feasible. Doing it myself is definitely an option for me but having never messed with rear ends before, I am hesitant. I don't like getting into wiring much either. I do like saving money a LOT though. Surely there is a write up or YouTube video to walk do-it-yourselfers through the install.
    I have looked at the locker itself and some compressors... what would you all say a good budget is for this? I'm also curious as to where everyone has installed their compressor. I was kind of thinking about the rear passenger side, where the little bed box thing is. Figured it would make for easy access to an air hose and it would be a counter weight to the battery and fuel tank.
  11. Sep 10, 2018 at 12:54 PM
    16Tacos
    Zach
    Boston
    I think you could do the assembled thirds install yourself as all of the hard work is done for you, other than the compressor install. You just pay them a deposit and then once you install and send them back your core they refund the deposit.
    I am tentatively planning to install my compressor where the original spare tire was located as I have a swingout rear but I've seen them installed anywhere you can think of (in engine bay, behind rear seats, in place of the cubbys in the bed, etc.). Depends on your preferences. They are quite loud so I don't think I'd want it in the cab with me.
    Griffin13[QUOTED][OP] likes this.
  12. Sep 10, 2018 at 12:55 PM
    solgardener
    solgardener Well-Known Member
    William
    '14 Tacoma DCLB SR5
    MattCowsmasher likes this.
  13. Sep 10, 2018 at 12:57 PM
    ItalynStylion
    Steven
    DFW, Tx.
    If you plan to regear (you probably should if you're even considering larger tires in the future) then you should do that at the same time. The labor charge is the same. If you regear, install lockers and the compressor at the same time you're looking at about $5k roughly. This is for the front AND rear. I did it last year in the spring and I haven't regretted it. There's a shop here in Dallas called Baertrax that does stellar work and they did mine. I'm sure up in NW Arkansas there's a decent place too.
