ARB Air Compressor - Under Hood Install
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Neato_Taquito, Jul 26, 2021.
  1. Jul 26, 2021 at 1:10 PM
    Neato_Taquito
    Neato_Taquito [OP] Member
    Benito
    3rd Gen Taco
    Hey there, Tacoma World family, first post here for me! I recently purchased an ARB on-board air compressor for my 2017 Tacoma and thought I'd share my install, as I have not seen it mounted like this before. I know there are a lot of solutions already out there (Slee bracket, etc.) but I've got all the ABS junk on the passenger side and I didn't want to be covering up my fuse box on the driver side. I also just spent $350 on a compressor and didn't want to drop another $150-$200 on mounting. I also only have access to very basic tools. So, I did some thinking, did some drinking, and I came up with a pretty neat, sturdy solution at a fraction of the price (approx. $85)...
    Here is what I did... I used the existing threaded studs for the ABS unit to create standoffs that would create a raised platform for the air compressor.
    I found these hex adapters to go from female metric to female standard. I then used standard 8-inch all-treads to create the standoffs. I bought all of the hardware off of McMaster-Carr, all stainless.
    For the mounting surface, I went to my local metal supply and bought a 12"x12" piece of 16-gauge steel. I used cardboard to make a template of the the area then used a cutting wheel and vice to make the base. I then measured out the standoffs to drill the holes. As you can see, I also used an existing threaded hole to mount the bracket to the sidewall for additional support.
    I then placed the compressor on the base to see where I wanted to mount it so it wouldn't interfere with anything. I also cut out a spot where I wanted to mount the switch.
    I mounted everything up and installed it just to make sure it fit. I was worried about the hood damaging the solenoid and wires, so I bought a 90-degree elbow so it would clear. I then cut the small air compressor bolts underneath so they wouldn't hit the ABS unit. I also cut the two front all-threads so they weren't so tall. I then took everything back out and hit the bracket with the ole rattle can for a cleaner look and to prevent rusting (I live by the coast).
    I gave it the ole wiggle test and it seems pretty solid. I'll have to report back after I hit some trails. I'm no metal fabricator, but it was a fun project and I'm pretty stoked on the results. Let me know if you have any questions or want specific part numbers for the hardware, would be happy to share and save you some $$$.
  2. Jul 26, 2021 at 1:13 PM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    Nice! Love it when that happens. When u just keep mulling it over in your head till it finally clicks. Hope you saved that cardboard template. All the sport guys are gonna ask you for it lol.
    Mindgame and Neato_Taquito[OP] like this.
  3. Jul 26, 2021 at 1:58 PM
    Skydvrr
    Nick
    YMH
    Black '17 OR
    Also, if u really wanna spruce it up, add edge trim to the visible areas for a more pro look.
    Mark77 and Neato_Taquito[OP] like this.
  4. Jul 26, 2021 at 2:28 PM
    Neato_Taquito
    Benito
    3rd Gen Taco
    Oh I like the sound of that!
    Skydvrr[QUOTED] likes this.
  5. Jul 26, 2021 at 2:37 PM
    Ritchie
    Ritchie Well-Known Member
    San Diego (North County)
    RC Step side Pre-runner
    2.7 w/auto, 4WU 3 link, F & R Diamonds, ARB's F/R w/ Yukon 5.29's, Inchworm 4.7 Lefty, Deavers, ARB OBA, Schrockworks up front.
    Welcome to TW... clean install you did there.
    As a suggestion, cut the all-thread down to the top of the nut, remove nut and replace with a stainless acorn nut.
    This way you won't slice an arm or digit while in there.
    I did this to my battery hold down after I cut myself while cleaning.
  6. Jul 26, 2021 at 2:52 PM
    Neato_Taquito
    Benito
    3rd Gen Taco
    Oooo I like that, thanks for the suggestion. I'll have to make sure I put something up so I don't scuff my compressor again *rolls eyes*
  7. Jul 26, 2021 at 2:55 PM
    HVLA
    HVLA Well-Known Member
    Idaho
    2020 Voodoo Blue OR DCSB 6MT
    That looks really good! Great job!
    Neato_Taquito[OP] likes this.
  8. Jul 26, 2021 at 3:07 PM
    Ritchie
    Here is how I mounted the 'twins':
  9. Jul 26, 2021 at 3:18 PM
    Neato_Taquito
    Benito
    3rd Gen Taco
    Oh the twins are looking real nice! Also, how is it so clean under your hood? I'm feeling very self conscious now about how dirty my truck is lol
  10. Jul 26, 2021 at 3:39 PM
    Ritchie
    Another suggestion?...
    Wire the switch to the cab and run the air hose connection to the filler neck area. It stays clean, the air hose is long enough to reach all 4 corners and you won't have to lift the hood.
    Here is what I did:
  11. Jun 26, 2022 at 4:01 PM
    Baja Action Drone
    Baja Action Drone Do cool stuff, rinse and repeat!
    Gregory
    2021 TRD Off Road Access Cab
    Front ADS 2.5 Coil overs RR w/Clicker. Rear ADS 2.5 piggyback, Camburg 1 1/4 Uniball UCA's,Camburg LCA's Camburg Performance Spindles, Deaver U401 Stage 1 Leaf Pack, BAMF Greaseable Shackels, CaliRaised Rock Sliders/Overland Bed Rack, Method 305 Wheels, Borla S-Type Cat Back & uuuuh, various Pods, Light Bar Rotopax..........
    That location looks cool AF! I like the idea of keeping the quick release clean.
  12. Jun 26, 2022 at 4:08 PM
    Baja Action Drone
    Gregory
    Welcome to TW! Nice DIY write up!!
  13. Jun 26, 2022 at 4:37 PM
    soundman98
    soundman98 Well-Known Member
    NW Indiana
    '18 Taco Sport, '14 Ranger
    nice install!
    i'd be interested in the part number for those thread extensions. thinking i'm going to do something with that space later as well
  14. Jun 26, 2022 at 7:56 PM
    Mindgame
    Mindgame Well-Known Member
    22' Offroad limited
    Decals removed
    Nice set up. I want this.
  15. Nov 29, 2022 at 12:34 PM
    Aromero369
    Aromero369 New Member
    2014 Tacoma Trd
    Can we get the hardware part numbers? thanks.
    Landpirate likes this.
  16. Nov 29, 2022 at 12:54 PM
    P8trit
    P8trit Well-Known Member
    Very cool! It's always better if you can DIY.
    I'm sure lots of members are going to want the part numbers
  17. Nov 30, 2022 at 9:47 AM
    GoldenTaco27
    GoldenTaco27 Well-Known Member
    Blake
    Long Beach Ca
    2017 Tacoma DCSB TRD Off Road
    @hungoverland on IG, King 2.5" EXT Travel w/ Archive Garage shock relocation, Icon RXT leafpack, 285 Nitto M/T's, bronze Raceline Defender wheels, TJM front/rear bumpers, TJM Sliders, Prinsu Cabrac, Katzkin leather, RSI Smartcap EVO topper, OV Tuned, MESO everything, Spyder headlights and tail lights, center mounted infant restraining system (CMIRS) \m/
    This makes me want to go pop my hood and figure out my solution for my twin compressor that I have put off for 3 months. Does the 16 gauge hold up well? The thinner I keep it the easier to manipulate with my basic tools.
  18. Mar 11, 2023 at 4:30 PM
    Cement_4x4
    Cement_4x4 New Member
    Britt
    2021 trd Tacoma sport 4 door cement
    Question: what’s the difference between the single and the twin compressor? Can you air up your tires ok with the single? I don’t have lockers on my truck…wondering if I should go with the single over the twin? Thanks! Nice set up!
  19. Apr 25, 2023 at 5:58 PM
    Overland_Architect
    Overland_Architect Well-Known Member
    Phoenix
    2002 Tacoma PreRunner Ext Cab Black
    Old Man Emu Suspension Dakar Leaf Springs Icon Delta UCA’s Relentless Fabrication Summit Bumper 4xInnovations Rear Bumper Tire Swing out 05 OEM Bed Rails
    How long of a line did you need to route to that location? And did you use a stainless steel braided line? I just installed a compressor in my 1st gen and was thinking of doing something similar. Looks like a very practical setup for airing up.
  20. Apr 26, 2023 at 7:28 AM
    Landpirate
    Landpirate Strong like horse, smart like tractor
    North Texas
    2018 Tacoma BBP SR5 4x4 DCSB
    OME HD leafs, 5100s, CaliRaised skids, UpTop Overland Bravo, KB Voodoo rack, Overlander RTT/awning, DECKED
    Great write-up. I've been thinking about putting one over there and trying to figure out how to set that up. I was kind of bouncing around your solution but seeing it actually done and the work you put into it I think is what I need to go ahead and get it done.
