ARB 2500 awning
Discussion in '2nd Gen. Tacomas (2005-2015)' started by thegrandpoohbah, Jul 21, 2023.
  1. Jul 21, 2023 at 10:49 PM
    thegrandpoohbah
    thegrandpoohbah [OP] Well-Known Member
    Terrace, BC, Canada
    2013 4x4 Double Cab V6 TRD Sport
    I am going to take a look at a used RTT next week and the guy also has an ARB Touring 2500mm x 2500mm awning for sale as part of the package. It's 8'2" long and I have a double cab with a Prinsu cab rack. Can I even mount this awning on my rack? That just seems awfully long to have hanging on the side of the rack. Does anyone on here have one of these awnings?
  2. Aug 20, 2023 at 6:56 PM
    2Toyotas
    2Toyotas Well-Known Member
    Ken
    Western NC
    '13 Taco SR5 AC
    I have a 2000 x 2500 awning with addon annex.
    And just got front and side windscreens.
    As suggested by @ETAV8R
    ETAV8R likes this.
  3. Aug 20, 2023 at 9:21 PM
    ETAV8R
    ETAV8R Out DERP'n
    MGM 09 AC 4WD V6 TRD-OR w/ Tradesman Shell
    Just the basics
    How do you like it so far?
  4. Aug 20, 2023 at 9:28 PM
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    The 2500 would be pretty long and awkward. The 2000 and the fully enclosed room works very well.
    My old 2nd gen:
  5. Aug 21, 2023 at 2:33 AM
    2Toyotas
    Ken
    Western NC
    '13 Taco SR5 AC
    We love it.
    Just got the windscreens and put them on. I left them up last night, in the front yard.
    The 'front' windscreen, when on, means the annex cannot be attached. The zipper strip, for the annex, requires the trough that the windscreen uses.
    It looks like the side windscreen 'might' attach with annex installed. It uses hook & loop,
    All parts are sturdy and look very well made.
    ETAV8R[QUOTED] likes this.
  6. Aug 21, 2023 at 4:08 AM
    2Toyotas
    Ken
    Western NC
    '13 Taco SR5 AC
    Awning.
  7. Aug 21, 2023 at 7:56 AM
    ETAV8R
    ETAV8R Out DERP'n
    Just the basics
    Super cool. Is the annex the same as the room?
  8. Aug 21, 2023 at 8:41 AM
    2Toyotas
    Ken
    Western NC
    '13 Taco SR5 AC
    Yes. The one that zips to the awning.
  9. Aug 21, 2023 at 4:43 PM
    Sudsman44
    Sudsman44 Well-Known Member
    Abington PA
    2012 Tacoma Access 4x4
    Ranch cap w/ rhinorack bars, 5100s, Deaver AAL, 2” front receiver, Matt Gecko bedlights, yadda yadda…
    IMG_0341.jpg 8x8 awning on my AC. Works great with my 6’ cap.
    ETAV8R and WOODY2 like this.
  10. Aug 22, 2023 at 7:02 PM
    2Toyotas
    Ken
    Western NC
    '13 Taco SR5 AC
    Next rain I am going to set it up in the yard and sleep in the annex/room to check the worthiness in rain.
    The dealer says they only say 'not for sleeping' in cuz it is not called a tent. Dang lawyers :)
    ETAV8R likes this.
  11. Aug 22, 2023 at 7:50 PM
    ETAV8R
    ETAV8R Out DERP'n
    Just the basics
    If it's raining make sure to find a way to keep water from pooling. I use a telescoping pole from the hardware store. Mine has a blunt side where the handle is...it's what I use to keep a tented section on the awning.
  12. Aug 22, 2023 at 7:51 PM
    crazysccrmd
    Alaska
    Aprilia Tuareg 660
    I always just lower one corner of the awning so it runs off that side.
    BigCountry762x39 likes this.
  13. Aug 22, 2023 at 10:34 PM
    ETAV8R
    ETAV8R Out DERP'n
    Just the basics
    I've tried that but maybe I didn't do it enough. Plus if it's raining, I usually have the room attachment in place too.
  14. Aug 23, 2023 at 3:29 AM
    2Toyotas
    Ken
    Western NC
    '13 Taco SR5 AC
    Is it something like the Kelty brand pole for Kelty tarps? I have several.
    I can see tilting being a problem if the annex is attached
  15. Aug 23, 2023 at 3:40 AM
    ETAV8R
    ETAV8R Out DERP'n
    Just the basics
    I have those but don't use them for this purpose. Simple aluminum telescoping pole from Lowes. One end is threaded for brushes or squeegee. The other end is like a small disc which won't harm the tent fabric.
    2Toyotas[QUOTED] likes this.
  16. Aug 23, 2023 at 4:03 AM
    2Toyotas
    Ken
    Western NC
    '13 Taco SR5 AC
    Ha, I was at Lowe's yesterday.
  17. Aug 23, 2023 at 5:47 AM
    crazysccrmd
    Alaska
    Aprilia Tuareg 660
    The tilt works fine with the room attached as well, it only needs to have one keg about 2-3” lower than the other to create enough angle for rain to run off.
    2Toyotas and ETAV8R like this.
  18. Aug 23, 2023 at 8:48 AM
    ETAV8R
    ETAV8R Out DERP'n
    Just the basics
    Makes sense. I think I dropped both legs a few years ago during a several day storm. Water still pooled and I had to come up with a solution in the field which was a metal pan and a tarp pole.
  19. Aug 23, 2023 at 2:00 PM
    2Toyotas
    Ken
    Western NC
    '13 Taco SR5 AC
    Thanks, a few inches is probably enough.
    I used a 2 inch dowel, with a small hole drilled in it, and a rounded end, to add to a tarp pole of an old setup I do not use anymore.
    I will look at lowes.
    I live in a rain forest. Wouldn't you know it, I want to check the rainworthiness, and it doesn't rain.
  20. Aug 23, 2023 at 2:09 PM
    ETAV8R
    ETAV8R Out DERP'n
    Just the basics
