ANZO headlights
Discussion in '2nd Gen. Tacomas (2005-2015)' started by thereverend, Apr 28, 2015.
  1. Apr 28, 2015 at 5:39 PM
    thereverend
    thereverend [OP] rev
    Adam
    B'ham AL
    '14 DCSB TRD Sport 6spd SC
    TRD SC, URD 1 size smaller SC drive pulley, Volant CAI w scoop, TacoTunes full kit, MagnaFlow muffler for flow but ran out rear to kill the drone.
    Does anyone use those aftermarket projector beam horseshoe aftermarket replacement lights by ANZO? Does anybody know what bulb comes stock in these units (the projector) from the factory. I would very much like to upgrade to anything better, brighter and more white (6000k, or whatever). I haven't tried to pry the rubber grommet/seal off a unit yet - is it possible?
    Any help will be appreciated,
    Adam
  2. Apr 28, 2015 at 5:49 PM
    thereverend
    Adam
    B'ham AL
    OR, (as I severely regret selling my OEMs) I could get some OEMs and upgrade the light source. I DONT WANT BLUE! HIDs, xenonor what? I don't even know the terminology. I guess I would like to replace the ANZO bulb. Can antbondy help me out?
  3. Apr 28, 2015 at 5:54 PM
    buckmark32
    buckmark32 Well-Known Member
    Christian
    Jacksonville
    14 Taco 4X4
    Stock
    If you dont want blue but dont want yellow... 6000K is the best... I had them in my past truck and loved them! I didn't have them in a projector lens so the light did go everywhere, but it lit the road up great! I am wondering myself if putting aftermarket HIDs in a aftermarket projector set (not the retro fit) would work.
  4. Apr 29, 2015 at 7:29 PM
    thereverend
    Adam
    B'ham AL
    No one taken these anzos apart or know what type of bulb they use? Can you pud HIDs in these?
    Thanks
  5. Apr 29, 2015 at 7:31 PM
    pudge151
    pudge151 Well-Known Member
    Sean
    Connecticut
    2015 Tundra Platinum
    They dont have great reviews from what I've read. Only aftermarket lights I'd recommend are Depo. If u want HID projectors a true retrofit is the only way to go
  6. Apr 30, 2015 at 8:35 AM
    braik
    braik Well-Known Member
    Louisville, KY
    2006 4.0L 4x4 BASE
    2" Ironman 4x4 (B) Front Spacer Level LR UCAs Level 8: Tracker Wheels 255/75 Cooper ATPs Welded Rock Sliders Weathertech floormats Wet Okole seat covers JVC Head Unit Diff Breather Mod Zip Tie Mod Needle Bearing Mod HID Retrofit (Acura TL-R)
    6000k is getting into the blue range.
    5000k is pure white.
    4300k is the color of sunlight and will give you the most usable light.
    3000k is yellow.
    None of those things matter unless you perform a HID projector retrofit (the kind where you actually open the headlight, not a drop in bulb kit). Any extra light you get from an HID drop in kit is going to go straight up or into oncoming drivers' eyes. If you just want brighter light out of a stock reflector then you should be looking into more expensive halogen or LED bulbs. PIAA, Phillips, or some of the other bulbs recommended in the "Lighting" section of the forum.
  7. May 3, 2015 at 12:34 AM
    thereverend
    Adam
    B'ham AL
    I haven't looked into the lighting sections thickly be pointless but on the back of the announcement the main (not the horseshoe or led) had a rubber grommet? thingingy which I guess you can just pry off? Under this rubber housing is the bulb? Any idea what it is (I.e. H13)? Just so I can look for something in the white (5000k?) range, not the yellowish it is now?
  8. May 4, 2015 at 1:05 PM
    braik
    Louisville, KY
    2006 4.0L 4x4 BASE
    You're kind of hard to understand so I'm guessing here at what you want. Yes, there is a rubber boot on the back of the housing that you have to take off to get to the bulbs. Every housing has to have a way to change the bulbs. I have no idea what size the bulbs are, you'll have to look at the manual/website or pull them out and see for yourself. Yes you can just buy some different halogen bulbs that give you different colors if that's all you want. Just beware, you get exactly what you pay for. If you want to pay $10 for the bulb, or buy from a sketchy guy on eBay you're almost certainly going to be disappointed.
