Anytime front camera on after market head unit
Discussion in '3rd Gen. Tacomas (2016-2023)' started by RaviYang, Jan 25, 2024.
  1. Jan 25, 2024 at 1:23 PM
    RaviYang
    RaviYang [OP] Member
    Ronald
    2016 Red SR Utility Package Tacoma
    N/A
  2. Jan 25, 2024 at 1:32 PM
    Rednecktacoma22
    Rednecktacoma22 Well-Known Member
    Logan, UT
    22 TRD OR 6MT
    The kit you linked states, "The harnesses will plug directly into the back of your factory in-dash screen with no cutting or modification to the factory wires required". If you intend to use this one, you will need to splice wires on your own to get it to work. I am of no help on that regard, however. Do you have a wiring diagram of your aftermarket head unit?
  3. Jan 25, 2024 at 2:43 PM
    RaviYang
    Ronald
    N/A
    I sadly don't have a wiring diagram for my aftermarket head unit, but it came with the connections needed to make everything work. For example, my steering wheel controls and the factory backup camera. So I'm not sure what to do.
    https://www.youtube.com/watch?v=fS_ofjlWh0c&t=501s
    https://www.youtube.com/watch?v=MI-olJnJPEw&t=903s
    These videos got me somewhere with my research because she has done the same kit with a different factory head unit than mine. But then in the second video has an after-market one and still has the front camera. So I don't know.
  4. Jan 25, 2024 at 2:57 PM
    Rednecktacoma22
    Logan, UT
    22 TRD OR 6MT
    I know that stinger has the capability for programming like 4-6 cameras and will have designated hook up spots I imagine. Chloe is also some sort of engineer for work and enjoys making wiring diagrams IIRC. Anyway, the only way for this kit and the aftermarket ones to work, would be to understand the kit's diagram that it is using to "jump" the signal and then using the diagram for yours to splice them in.
    I am sure if you google your aftermarket head unit you can find a manual/diagram. I am also sure the anytime wiring diagram can be found on other threads here on TW.
    Good luck! :fingerscrossed:
  5. Jan 25, 2024 at 3:28 PM
    caribe makaira
    Caribbean, Puerto Rico
    If the aftermarket head unit was "plug & play" you should have the required connectors to add the ABC harness.
  6. Jan 25, 2024 at 6:18 PM
    CLVol1255
    CLVol1255 Well-Known Member
    Tennessee
    2017 TRD Sport DCSB
    Bilstein 8112/8100 ICON RXT Stage 2 JBA UCAs Archive Garage HH w Shackles Archive Garage U Bolt Flip kit Nitto Ridge Grapplers 255/80/R17 TRD Front Skid and RCI Transmission Skid Kenwood DMX 1057XR Head Unit Focal Utopia WM 3 way plus WM10 Sub Mosconi 5/30 and Genesis Dual Mono Amp
    Kenwood DMX1057XR has it with the option to install 3 views and there is no switch needed. Just push camera button under the screen and choose front rear or whatever view you chose for your 3rd camera angle
  7. Jan 26, 2024 at 10:32 AM
    sak29
    sak29 Member
    I would stay away from the anytime back up camera brand. They sold me a broken unit and ghosted me when I tried to contact them with my issues. Wouldn't return any emails or phone calls. Clearly a company that doesn't stand behind d their products or customers. I ended up going with the germes labs camera system and couldn't be happier. Easy instal and uses the steering wheel to control the cameras.
  8. Jan 26, 2024 at 8:02 PM
    Toycoma2021
    Toycoma2021 Well-Known Member
    Northern California, Temporarily
    2021 Access Cab, LB, AT, V6, Off Road
    I also contacted "Anytime Back Up" by phone and had no problems getting them to replace what I damaged in my installation. OP give them a call and tell them what you have and what you want to do. They may have experience with your unit, they may not. Post #5 gives me good vibes that it can work out. It is a very simple system, get the upgraded camera.
