Anytime front camera mounting - Steel bumper
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Ez2typethis, Mar 16, 2021.
  1. Mar 16, 2021 at 8:08 AM
    Ez2typethis
    Ez2typethis [OP] Well-Known Member
    California
    2017 Sport
    Suspension -LSK Uniball Uper Control Arms -LSK Uniball Lower Control Arms -Camburg Performance Spindles -ECGS Needle Bearing Installed -Archive Garage Hammer Hangers -Archive Garage 3.6” Shackles -Archive Garage Hanger Cross Tube -Icon 2.5 CDC Extended Travel Coilovers -Icon 14" 700 pound coils -Icon 2.5 CDC RXT Shocks -Icon 2.0 Hydraulic Bump Stops *Bolt On Bump Stop Mount -Wheelers Front Super Bumps Armor -At The Helm Front Bumper -At The Helm Rear Bumper -At The Helm Rear Swing Out -RCI Sliders -RCI Engine Skid Plate -RCI Transfer Case Skid Plate -RCI Transmission Skid Plate -RCI Fuel Tank Skid Plate -Prinsu Designs Top Rack -Prinsu Designs Cab Rack Lights -Black Head Light Mod -OEM TRD Pro Tail Lights -MESO LED Turn Signals -Morimoto HID Headlight Kit -Caliraised LED 40” Slimline -Caliraised LED 20” Slimline -Caliraised LED Amber Pods -Caliraised LED Wide Ditch Lights -Caliraised LED Flush Mount Pods -LED High Beams -LED Dome Lights -LED Back-Up Lights -LED License Plate Lights Miscellaneous -OVtuned2.0 -4.88 gears -ARB twin comp -ARB rear locker -Leer 100XQ Camper Shell -Smitty Built X20 Winch -Warn Fairlead -Warn Sidewinder -Roto Pax 4.5 Gallon Gasoline -Roto Pax 2 Gallon Water -Roto Pax 2 Gallon Gasoline -Weathertech Floor Liners -Double limo tinted -50% tinted windshield -Leather Seats - Installed At Dealer Wheels and Tires -Matte Black Stealth Custom Series Ray 10's (X5) -BFG KO2 285x70r17 // Load Range C (X5)
    Looking for ideas on where to mount my front camera
    The traditional mounting location under the "Tacoma" on a TRD pro grill will not work for me. The view only looks down to the top of the steel bumper. I am deferring to the deep knowledge pool of tacomaworld for advice.
    Image below: View through camera is blocked by bumper. Over 60% of the image
    Image below: Mounting right above bumper light bar. Camera angle seems to be pointed down a little too much
    Picture below: Mounting below the light bar, on the lower side of bumper. Seems like camera is pointed at the sky a little too much.
    What do you folks think? Appreciate the input, thank you in advance
  2. Mar 16, 2021 at 10:04 AM
    skibums_toyo
    skibums_toyo Well-Known Member
    Kevin
    2018 Tacoma TRD Off-Road Cement
    Doesn't the kit come with some shims to adjust the angle? I don't think you'd want to mount it in that under the light bar location as it would probably be damaged pretty easily.
    Try the shims in the original locations on the grill to see if you can get it angled between the space of your bumper and bullbar.
  3. Mar 16, 2021 at 10:35 AM
    Lunabird
    Lunabird Well-Known Member
    Can you go above the TOYOTA logo?
  4. Mar 16, 2021 at 10:39 AM
    Gen3TacomaOBX
    Gen3TacomaOBX Well-Known Member
    S
    2018 Tacoma DCSB SR 4x4
    Bilstein 6112 front / 5100 rear (extended) shocks, Headstrong AAL, Firestone airbags, 4.88 gears, OME Carrier bearing drop kit, Aluminum 1/4" skids (engine to transfer). Custom sliders (1.75" HREW tube w/ 3/16" base plates). Custom front bumper and high clearance rear bumper (1/4" steel plate, 1.75" tube.) Apex 5500 winch w/synthetic line (36lbs) and required accessories for an underpowered winch (snatch blocks and extra line.) Tekonsha P3 brake controller, remote start, any-time-backup camera w/ front facing camera, Leer 100R shell (w/e-track single slot tie-down mounts for removable Yakima EasyTop.) Cat shields by CaliRaised. Husky liners, window tint, heated seat (passenger only.) Relentless bed rail brackets with QuickFists (shovel/axe/fire extinguisher.) Hondo Garage Un-holey vent mount. Anytime rear with front facing camera. Billet front seat risers. Viair 88p. 265/75r16 Goodyear Ultra-terrain tires.
    Wire it up temporarily so you can check the onscreen image for best placement.
    Prjct_Vodo likes this.
  5. Mar 16, 2021 at 10:42 AM
    Prjct_Vodo
    Prjct_Vodo Well-Known Member
    Ali
    Michigan
    2019 Voodoo Blue Tacoma TRD Pro
    Why not just run the wire from the outside first and turn the camera on to find what angle looks best on the screen? Trying to guess without knowing what the actual image and angle would be is a waste especially if you’re going to drill a hole into your steel bumper
    9TRDTCO and Gen3TacomaOBX like this.
  6. Mar 16, 2021 at 10:45 AM
    crashdb
    crashdb I break chainsaws
    Dave
    Manassas, VA
    2008 Toyota Matrix
    Rollin' hydrocarbons!
    I ended up putting mine inside the letters under the top ridge. I had to slot the hole a little so it would sit flush. I get a little bit of the hoop in the picture, but I use it to judge stuff. I can take a picture and what-not if needed. Can't do the camera's image right now because I don't have a radio....
    Ez2typethis[OP] likes this.
  7. Mar 16, 2021 at 7:33 PM
    Ez2typethis
    California
    2017 Sport
    I like that idea
  8. Mar 17, 2021 at 8:53 AM
    crashdb
    Dave
    Manassas, VA
    2008 Toyota Matrix
    I see my memory sucks.
