anyone with firestone airbags experiencing slow leak?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by forana, Oct 13, 2016.
  1. Oct 13, 2016 at 3:01 PM
    forana
    forana [OP] Well-Known Member
    Kaneohe, Hawaii
    2022 DCSB OR Lunar Rock
    No money, all went to truck...
    I installed air bags several months ago. Boy, are they awesome. I'm experiencing very slow leaking. Over a few weeks I lose 5 psi in them. anyone experience the same thing? What should I do?
  2. Oct 13, 2016 at 3:24 PM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    Find the leak. Use a spray bottle with some dish soap and water. If it's a threaded fitting use Loctite 545 thread sealant.
  3. Oct 13, 2016 at 3:24 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    Spray all connectors and fitting with soap diluted with water, I personally like it a little thick.
  4. Oct 13, 2016 at 3:59 PM
    Pigpen
    Northwest Montana
    Lots of soap in that water.
    Mine leak super slowly. I just check them from time to time when I fill up with fuel. Even though I have on board air, the gas station is easier - the hose and chuck are ready to go.
  5. Oct 13, 2016 at 4:29 PM
    Pickeledpigsfeet
    Pickeledpigsfeet Well-Known Member
    Foothills, CA
    Do you have both bags teed together or separate? I have had the T crack before and leak.
  6. Oct 13, 2016 at 4:41 PM
    forana
    Kaneohe, Hawaii
    Not Teed together.
    Can I pull the air hose out the the fitting and reseat them?
  7. Oct 13, 2016 at 4:45 PM
    Pigpen
    Northwest Montana
    Yes. push the hose in and hold the fitting down. It'll come right out. just pushing it in further may fix the leak. These things are notorious for slow leaks. I've had them on 4 trucks and all have had leaks where I lost a few pounds every month. For the record, I only installed one of the kits personally. Two of the kits were professionally installed. In the manual, Firestone even states that slow leaking can be common.
  8. Oct 13, 2016 at 4:50 PM
    T4RFTMFW
    Those fittings are shit. They're easy to use, but they are junk!
  9. Oct 13, 2016 at 4:56 PM
    Shwaa
    Shwaa Well-Known Member
    Bay Area, CA
    '13 DC Prerunner TRD Off-Road
    ^this man knows his shit. Listen to him
  10. Oct 13, 2016 at 5:00 PM
    T4RFTMFW
    Brass fittings and high pressure tubing is moar better.
  11. Oct 13, 2016 at 5:01 PM
    Shwaa
    Bay Area, CA
    I've been saying that since Day 1
  12. Oct 13, 2016 at 5:19 PM
    wake100
    wake100 Well-Known Member
    Syracuse, NY
    2021 AG DCLB off road 4x4
    Uptop roof rack, cali raised light bar, diamondback tonneau
    God dammit do I really need another project on my truck... :annoyed:
  13. Oct 13, 2016 at 5:37 PM
    Mossyjaws
    Mossyjaws Well-Known Member
    VA
    2015 dclb
    Footprint Gas Pedal
    Post some pics when you get it taken care of.:D
  14. Oct 13, 2016 at 5:37 PM
    forana
    Kaneohe, Hawaii
    Yeah, my friend that helped me install the bags said the fittings are garbage but OK since its such low pressure.
    I'll try and reseat them this weekend. The leak is slow so not a real big deal
    Thanks guys
  15. Oct 13, 2016 at 8:22 PM
    Notoneiota
    Notoneiota Well-Known Member
    Oakdale, MN
    14 Tacoma DCLB TRD Sport
    Mostly stock with a few minor mods.
    Mine lose a little over time but I only pump them up when I tow something heavy and that's maybe once every couple of months.
  16. Oct 16, 2016 at 9:33 PM
    RKCRUZA
    RKCRUZA Well-Known Member
    Bob
    Placerville, Ca
    2015 TRD Pro in the Garage!
    Had them on my 1st gen Tundra for almost 10 years and on the Taco Pro for over a year....no leaks on either set...they are tied together with a Tee and usually running about 10psi. Put a bit of air in them every few months as they will go down without a leak just like a tire.
