Anyone with a Engine Mounted York Compressor on a 2nd Gen V6?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by HBMurphy, Jan 20, 2010.
  1. Jan 20, 2010 at 10:12 PM
    HBMurphy
    HBMurphy [OP] Ban Pending
    Paul
    So California Coast
    09 Off Road Delete Model
    None
    Anyone with a Engine Mounted York Compressor on a 2nd Gen V6? :confused:
    TIA
  2. Jan 20, 2010 at 10:21 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
  3. Jan 20, 2010 at 10:46 PM
    HBMurphy
    Paul
    So California Coast
    None
    Thanks - I've seen alot of 210 mounts for other rides - I'd love to find someone that has reconfigured a second gen.
    I also have a couple of the caddy compressors too... and a High Vol ARB - I would just like to have a REAL COMPRESSOR ;)
    Thanks again!
  4. Jan 21, 2010 at 4:41 PM
    HBMurphy
    Paul
    So California Coast
    None
    ... without spending $1300! ;)
    camojared likes this.
  5. Jan 21, 2010 at 5:55 PM
    HBMurphy
    Paul
    So California Coast
    None
    :bowdown: :drool: Like I said, I'm cheap. Otherwise if I could peel off $1300-$1600 and not cringe, I would order it in a second. - I want the kinda compressor that would require ear muffs! :eek:
  6. Jan 21, 2010 at 6:00 PM
    HBMurphy
    Paul
    So California Coast
    None
    How 'bout one of these:
    Extreme Outback Extremeflow Compressor (Serpentine)
    This compressor puts out a whopping 8 CFM at 100psi. Capable of 200psi, the unit has a greasable zerk fitting for lubrication and uses high temperature synthetic grease. ExtremeFlow compressors will fill tires, run air tools and can be used whenever large volume of air is needed. Each unit is manufactured with the highest quality components for the ultimate in performance. The compact size makes for easy installation. Dimensions are 5.5" in diameter, 8.5" long with eight mounting ears. This is the ultimate compressor for speed, volume and performance.
    DistortedAxis likes this.
  7. Jan 21, 2010 at 7:45 PM
    HBMurphy
    Paul
    So California Coast
    None
    Not a bad price ($400) - and if I wanted to go on the cheap, I could do the same to a Sanden bone yard compressor (step up the oil to synth grease). Now to see if I can squeeze it in the engine compartment.
  8. Jan 21, 2010 at 7:49 PM
    HBMurphy
    Paul
    So California Coast
    None
    :D
  9. Jan 21, 2010 at 9:27 PM
    HBMurphy
    Paul
    So California Coast
    None
  10. Dec 22, 2010 at 8:52 PM
    Jason'sLawnCare
    Jason'sLawnCare Prepared for Bambi
    Jacksonville Florida
    08 4x4 Double Cab TRD Rugged Trail
    CBI Moab 2.0, CBI Trail Rider 2.0, CBI sliders w/kickout, Superwinch EPi9.0S, OME sport shocks w/886 coils, OME n182, 1.5" aal, JasonBuilt 3/16th full belly skid, BuiltRight uca, Body Mount Chop, 285/75/16 km2's, Rear cat delete, exhaust crossover rerouted, Fog light anytime, Locker mod, Rear leaf tsb, Debadged, Uws Tool Box, Electric Exhaust Cutout, AFE Pro Dry S, Kiwi Wifi, Diff Breather Relocated, Grom Ipod Adapter, Dual Diehard platinum batteries isolated by BlueSea marine switch
  11. Dec 22, 2010 at 9:19 PM
    joes06tacoma
    Joe
    Central Coast, CA
    What would you mount this to? Isn't the York compressor cast iron (heavy). Looks like the timing cover supports some of the factory accessories? Or am I missing something? Seems like you would be stressing the timing cover trying to hang all that weight on it.
  12. Dec 22, 2010 at 9:31 PM
    Jason'sLawnCare
    I guess a bracket would have to be fabbed up. I doubt it's much heavier than a compressor with a decent electric motor on it.
  13. Dec 22, 2010 at 10:05 PM
    AKTACO420
    AKTACO420 Well-Known Member
    RETODD
    Anchorage AK
    2009 tacoma
    bucket seats grille craft mesh grille and lights behind grille
    Do it I wanna see
  14. Dec 25, 2010 at 8:49 PM
    AKTACO420
    RETODD
    Anchorage AK
    2009 tacoma
    im in the process of getting a sanden a/c compressor for free so im going to try and do this but i have a four cylinder not a v6 we are also going to do it on my friends 98 xj which should be easy because the sanden is found on jeeps
  15. Dec 25, 2010 at 8:51 PM
    AKTACO420
    RETODD
    Anchorage AK
    2009 tacoma
    thanks for the idea and info
    nosedive likes this.
