Anyone with 255/75/17??
Discussion in 'Wheels & Tires' started by TRDfarmerTN, Apr 3, 2017.
  1. Apr 3, 2017 at 7:53 PM
    TRDfarmerTN
    TRDfarmerTN [OP] Well-Known Member
    20% tint, painted handles,painted grill, wet okole seatcovers,sockmonkey decals
    If you got this size post what lift also and a pic?
  2. Apr 25, 2017 at 11:51 AM
    Thunder Fist
    Thunder Fist Well-Known Member
    David
    Birmingham, AL
    2017 MGM TRD OR DCSB
    Like, so many.
    I'm interested in this too.
  3. Apr 25, 2017 at 11:58 AM
    SocalOC
    SocalOC Well-Known Member
    2015 Sport
    17" rockstart 2 levling kit 285/70/17 toyo ipen country
    I have a 255/80
  4. Apr 25, 2017 at 12:07 PM
    Taka The Tacoma
    Taka The Tacoma Enjoy the Roy
    2017 SR 2.7L 4WD
    TRD Rims, duratrac tires
    Goodyear Duratrac 255/75/17 with 1.5 lift...
  5. May 3, 2017 at 5:06 PM
    Atomic
    Atomic Master Cylinder
    New Mexico
    13 TRD Sport Double Cab Long Bed
    Me. Cooper S/T Maxx. C-Rated. Awesome Tire.
    11TRD, TRlPPlN, OH-_SNAP and 2 others like this.
  6. Mar 13, 2018 at 10:00 PM
    OH-_SNAP
    OH-_SNAP Well-Known Member
    San Diego, CA
    2016 WHITE LIMITED 4x4 DOUBLE CAB
    ARE V Camper Shell, FiberGlass Hood w/ Functional Skewp. ICON 2.5" Front (ordered)
    Here are mine - 255/75/17 light and tall Duratracs.
    20180313_174211.jpg Screenshot_20180313-215547.jpg Screenshot_20180313-215337.jpg
    Jessrin and TRlPPlN like this.
  7. Mar 14, 2018 at 9:53 PM
    Mikeybuck
    Mikeybuck Well-Known Member
    SW WA
    2018, 2010, Tacoma
    I like mine. Did take a little MPG hit but not too bad.
    255/75/17 duratracs
  8. Apr 6, 2018 at 9:23 AM
    Ram.95
    Ram.95 Well-Known Member
    2017 Black Tacoma TRD OR 4x4 Dallas Tx
    TRD PRO Bilstein Suspension HS Progressive AAL
    How are you liking the Duratracs? Think i am going to pull the trigger on the same size as well. I have seen some mixed reviews on these though.
  9. Apr 6, 2018 at 9:20 PM
    Mikeybuck
    SW WA
    2018, 2010, Tacoma
    I have 2k miles on them now.
    Towed my boat a couple times, no issues. They track straight. Did great in the snow, pulled good in the sand. No issues with wet roads. I really do like them.
    My only issue is. Stock I was 19.5-20 mpg. Now I'm at 16-17 mpg. I could also feel a loss in power. As much driving as I do, I should of went with 255/70/17s.
    Themexicantaco and Ram.95 like this.
  10. Apr 9, 2018 at 6:57 PM
    Ram.95
    Ended up with C rated KO2’s in the 255/75/17
    4CB94023-A1D6-48BF-B1C5-9289012675CD.jpg D9D9D40D-027A-42AB-BC54-C9A317AC4BF3.jpg
  11. Apr 10, 2018 at 7:35 AM
    OH-_SNAP
    San Diego, CA
    What tire pressure are you running in front and rear? I have the same tires..
    Have you figured out a good psi?
  12. Apr 10, 2018 at 7:36 AM
    OH-_SNAP
    San Diego, CA
    What is your psi?
    Sna likes this.
  13. Apr 10, 2018 at 7:40 AM
    91Enforcer
    91Enforcer Well-Known Member
    Western CO
    2008 Access Cab TRD Off Road
    Contemplating putting this size tire on my 08 no lift(yet) Ive heard conflicting reports of whether they rub or not.
    From what I've researched they are only .5'' taller but narrower than my 265/75/r16 stock tires
  14. Apr 10, 2018 at 8:11 AM
    Ram.95
    You correct on the .5" taller in theory but I would look at what the manufacture states as the true measurements. For instance KO2's in this size are 32 exactly, instead of the measurement of 32.1. I believe Coopers ST Maxx's are only 31.77 but their width is 10.2 vs the KO2's being 10.0.
    The chart below helped me when picking a tire (I also switched to a different offset wheel) . I was more worried about rubbing on my UCA, which is why I went skinny.
    91Enforcer[QUOTED] likes this.
  15. Apr 10, 2018 at 8:23 AM
    Mikeybuck
    SW WA
    2018, 2010, Tacoma
    Right now I'm at 35 front, 33 rear. (Cold psi) when I tow the boat, or haul firewood, I'll bump the rear up to 35 psi.
    With my cold psi of 35f, 33r, after a couple miles they warm up to 38 front, 36 rear.
    How about you?
    OH-_SNAP[QUOTED] likes this.
  16. Apr 10, 2018 at 8:35 AM
    91Enforcer
    Western CO
    I'm looking at a set of BGF MT's that have 60% tread left so I think ill be alright. Im going from the stock trd off road 16" to 17"black steelies that say J17X7J DOT 4 15 /7MT 24 do any of those numbers tell me the offset of the wheel?
  17. Apr 10, 2018 at 9:09 AM
    OH-_SNAP
    San Diego, CA
    I think I was at 32-33 all around when discount tire mounted them. I am currently at 36, cold, on all 4 corners. I am going to see how high it goes up when warm. I think I may lower in the rears like you are doing. I have to look into doing the chalk test. Haven't done one before, I just want to make sure I am at an optimal tire psi.
  18. Jun 27, 2018 at 2:44 PM
    msfit
    msfit Well-Known Member
    SJ
    I'm thinking about going with this size as well. I have a set of SCS F5s in 17x8.5 4.3" BS -10 and currently stock suspension, but picking up some billies and just need to find an aal.
    Van_island likes this.
  19. Sep 21, 2018 at 5:18 AM
    Scottyrocco16vdub
    Scottyrocco16vdub Well-Known Member
    Scott
    Latham, NY
    Are these the 17x8.5 4.3bs wheels? I am picking up a set and wanted to go with those same exact tires but was worried about the rim being a bit too wide. How are you liking the setup? I saw the off-road pic a few posts down and the tires don’t look as ballooned out.
  20. Oct 14, 2018 at 9:07 AM
    Scottyrocco16vdub
    Scott
    Latham, NY
    255/75/17 Cooper discoverer AT3 on 17x8.5 scs F5
    E922CC2E-4874-4806-8058-A2EFD79A6411.jpg D258B696-10D0-4286-A5F7-B8356375205E.jpg 95B6DEB3-7072-41AA-B32D-E7EF05CE5CDB.jpg
    Van_island, Greenbean, 6MTPro and 6 others like this.
