Anyone using other than 0W-20 oil?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by MaGuyver, Jan 15, 2021.
  1. Jan 15, 2021 at 9:17 AM
    MaGuyver
    MaGuyver [OP] Well-Known Member
    Savannah, Ga.
    2020 Tacoma Sport, Cement
    Tinted glass, Bed mat, Rigid light bar, Bakflip FiberMax tonneau, Bull bar, LED cabin lights, Bed lights.
  2. Jan 15, 2021 at 9:20 AM
    Rockefelluh
    Rockefelluh Well-Known Member
    Rocky
    Orange County, CA
    2018 DCLB TRDOR 4x4
    Are you having trouble finding 0W-20 and that’s why you’re thinking about another viscosity?
    Junkhead and shakerhood like this.
  3. Jan 15, 2021 at 9:22 AM
    Tacospike
    Two Trucks
    Nope. 0W-20 only
    Manual says you can use 5W-20 but to change it back at next change, or something along those lines I think
  4. Jan 15, 2021 at 9:23 AM
    MaGuyver
    Savannah, Ga.
    My Father is bugging me about going to thicker grade, so I thought I would ask. I used 10W-30 in my 2007 Tacoma for its whole life, but I am sure things have changed since it came out.
    I was thinking about using Mobile 1 0W-20 Truck and SUV oil
  5. Jan 15, 2021 at 9:25 AM
    Rockefelluh
    Rocky
    Orange County, CA
    2018 DCLB TRDOR 4x4
    Different engine. My suggestion is use what Toyota engineers suggest. It’s easy to find and cheap where there really is no positive to going to another grade.
    gudujarlson, Junkhead, Chew and 3 others like this.
  6. Jan 15, 2021 at 9:26 AM
    Silverlogic
    Silverlogic Well-Known Member
    Tyler
    San Diego, California
    2018 Silver DCSB TRDOR
    You can use any viscosity of oil for an engines whole life, but that life may be much shorter than expected.
    BillW, 44-16 Taco, Junkhead and 7 others like this.
  7. Jan 15, 2021 at 9:27 AM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Thicker oil flows slower through the VVT screen retarding ignition timing. Use 0-20.
  8. Jan 15, 2021 at 9:29 AM
    MaGuyver
    Savannah, Ga.
    LOL good one.
  9. Jan 15, 2021 at 9:31 AM
    Gen2 Man
    Gen2 Man Well-Known Member
    Midwest
    07 Sport DCLB
    3rd Gen Sport wheels
    You don’t need old school heavier oil. Newer engines are running tighter clearance for better fuel economy and believe it or not that thinner oil dissipates heat more readily. Toyota and everyone else went to these oils because they are better. Daddy needs to go over and read up at www.bobistheoilguy
  10. Jan 15, 2021 at 9:41 AM
    Grossomotto
    Grossomotto Complete 3rd Member
    39.9526° N, 75.1652° W
    2017 4WDV6LB6MT
    Hooper89 likes this.
  11. Jan 15, 2021 at 9:42 AM
    davidstacoma
    davidstacoma Friendly Curmudgeon
    David
    NC
    2019 Tacoma SR Access cab - Utility
    *OEM Mods: Intermittent wipers, Fogs, Keyless Entry, Lomax
    Not gonna make much difference except when cold, that’s where the 0 weight first number will flow easier. After the engine warms up the second number comes int to play and they’re both the same at that point.
    from https://www.lubricants.total.com/help-support
    Viscosity is notated with the common "XW-XX." The number preceding the "W" rates the oil's flow at 0 degrees Fahrenheit (-17.8 degrees Celsius). The "W" stands for winter, not weight as many people think. The lower the number here, the less it thickens in the cold. So 5W-30 viscosity engine oil thickens less in the cold than a 10W-30, but more than a 0W-30. An engine in a colder climate, where motor oil tends to thicken because of lower temperatures, would benefit from 0W or 5W viscosity. A car in Death Valley would need a higher number to keep the oil from thinning out too much.
    The second number after the "W" indicates the oil's viscosity measured at 212 degrees Fahrenheit (100 degrees Celsius). This number represents the oil's resistance to thinning at high temperatures. For example, 10W-30 oil will thin out at higher temperatures faster than 10W-40 will.
    TJN771, usmc2msu and NAAC3TACO like this.
  12. Jan 15, 2021 at 9:49 AM
    MaGuyver
    Savannah, Ga.
    Ok, thanks guys. 0W-20 it will be.
  13. Jan 15, 2021 at 9:50 AM
    VirusCage
    VirusCage Well in the secondary immune response
    Bruce
    Allison Park, PA
    2017 TRD Sport DCSB 6MT 1995 Landcruiser 2015 Highlander XLE
    Hood deflector, window vent visors, stainless steps, kb voodoo bedrack, bed cubby cap seals, meso ext fuse cover, meso lower switch panel, 4xhella horns, power tray aux panel, 2wd lo mod, rear FU lights, bed led lights, BPF SKID and Hook, rear view mirror usb power ports, front and rear dash cam, front and rear cam anytime mod, cherry air freshener! Anytime 400watt, inside 110v outlet, BPF Skid plate, BPF shackle mount,
    A long time, 20ish years, I worked at a car dealership, in the parts department. While I was there, the newer models/engines that came around had changed their oil requirements. The older models had run on 10w30. The giant oil tank that fed all of the tech bays was stocked with 10W30. Gradually the newest 04/05/06 etc models were calling for 5w20. Even when the specs had changed to 5w30 (in the 90s), the orders for the tank fill never got updated. By 07 the specs were 5w20 and some even 0w20. After a few warranty issues trying to track down odd oil pressure issues, nothing catastrophic but lights and odd readings, corporate recommended that the giant tank start getting 5w20 and cars needing 0w20 got individual quarts.
    After that no more odd pressure issues.
    Will it blow up your motor, probably not. Does it work the oil pump more (literally reduce overall efficiency) and cause issues on tighter tolerance pathways and potential lead to "more" wear, most likely.
    Junkhead likes this.
  14. Jan 15, 2021 at 9:51 AM
    Tacowin1013
    Tacowin1013 Well-Known Member
    2017 OR DCSB 6MT MGM
    I run diesel fluid as well as diesel fuel in mine. I've been noticing a huge improvement on the low end torque
  15. Jan 15, 2021 at 9:59 AM
    Jowett
    Jowett Well-Known Member
    Brian
    North Adams, MA
    5W30 will be absolutely fine. Toyota recomends this weight for the 2GR-FKS on other continents.
    TJN771 likes this.
  16. Jan 15, 2021 at 9:59 AM
    GrundleJuice
    GrundleJuice Well-Known Member
    Michigan
    2016 TRD Bro
    [S]Un-Molested[/S] Lightly Molested
    Wat?
  17. Jan 15, 2021 at 10:00 AM
    Smacky2020
    Smacky2020 Well-Known Member
    Bristol, VA
    2020 TRD ORDC - Cement
    Stock wheels and suspension. Random "utilitarian" mods featured on this great forum.
    Sounds like my Dad. He's been using 10w-30 for probably past 30 years and you won't convince him otherwise. If the owners manual doesn't say its supported, don't use it. Some engines have a "recommended" weight but also list other weights but not this one.
    Good luck with the conversation with Dad. I always try to bestow some newer knowledge but his stubbornness doesn't let him go beyond a certain point. Man I can't wait to be old(er).
    whatstcp likes this.
  18. Jan 15, 2021 at 10:08 AM
    davidstacoma
    David
    NC
    I would use the recommended viscosity range myself. Having said that I don’t live in a cold climate so I wouldn’t shat my pants fearing engine early failure if I ran 5-30, the actual running viscosity is higher equivalent viscosity number than 0 with a warmed engine. And if I lived in a really hot climate I would probably run 5-30.
  19. Jan 15, 2021 at 10:09 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    I use Mobil1 0W-30. Easy enough to find in big box stores.
  20. Jan 15, 2021 at 10:10 AM
    MaGuyver
    Savannah, Ga.
    You have to introduce new information to older parents slowly or their ears shut down and you get some long story. Sadly, I think I am starting to come down with the same condition.
    Gearheadesw, wahoobie and Steves104x4 like this.
