Anyone use these wheels? any comments or reviews.
Discussion in 'Wheels & Tires' started by P33Rob, Jun 7, 2013.
Do you approve of these?
Poll closed Jul 7, 2013.
  1. Yes
    100.0%
  2. No
    0 vote(s)
    0.0%
  3. dont care
    0 vote(s)
    0.0%
  4. Get the steel wheels.
    0 vote(s)
    0.0%
  1. Jun 7, 2013 at 8:43 PM
    P33Rob
    P33Rob [OP] Well-Known Member
    Rob
    Watertown, NY
    13 Tacoma V6 TRD 4X4
    OME 3" Lift; Maxfit aeromax; Volant CAI w/scoop; TRD Exhaust; Step rails; SCS stealth 6 wheels; Bedrug
    Black rock wheels Yuma series 908b
    They weigh 29 lbs they are aluminum but look like steel their load cap. Is 2200lbs.
    For a truck that rarely goes serious off road just dirt roads and some uneven terrain.
    They are 17x8 with 4.5" offset (backspacing) so they will stick out about a half inch more I assume. I believe these are the same weight as stock and therefore won't suffer any noticeable changes is mpg or low end torque. If not these i was gonna get some black steel like procomp 52. For the price of these you can't beat them in aluminum obviously steel is cheaper.
    I posted a link at the bottom. Opinions appreciated.
    They go for $131- tirepackage .com
    http://www.blackrockwheels.com/products16-16/BlackRockYumaSeries908B
  2. Jun 8, 2013 at 3:51 AM
    P33Rob
    Rob
    Watertown, NY
    Bump deos anyone have a reason why I should avoid these?
  3. Jun 8, 2013 at 3:55 AM
    drunktaco
    drunktaco Well-Known Member
    Sage
    Southwest Va
    Icon ext travel C/O's, Total Chaos UCA's, King R/R shocks, All-Pro leaf pack, lights, RCI skid, Brute Force sliders, ect.
  4. Jun 8, 2013 at 4:21 AM
    P33Rob
    Rob
    Watertown, NY
    I pm'd him I think his were steel and a different type but I consulted him either way he prob has more info than most.
  5. Jun 8, 2013 at 4:36 AM
    drunktaco
    Sage
    Southwest Va
    If I'm thinking right I believe they were the same wheels just silver. But he can tell you if they were or not. Good luck
  6. Jun 8, 2013 at 5:16 AM
    MadToy
    MadToy Well-Known Member
    Nick
    Huntersville, NC
    07 Midnight Blue TRD
    OME 886, Dakar leafs, LR UCA's, 16x8.5 Level 8 ZX, 315 MTR Kevlar, All-Pro sliders, BudBuilt skids, Undercoverhwms winch mount, Warn M8000 with synthetic rope, ATO Hi-Lift bed mounts, Diff locker override, Hitch harness relocated to bumper, Undercover bed cover, Gromm Aux adapter, Grillcraft grill, DT pipe bombs, Custom Magnaflow exhaust, Brute Force HC bumper, TRD Supercharger
    They were aluminum. Great wheels for the price. Only reason I changed was to get the scratch guards to protect the lip from the rocks. I think the Yuma is a very under appreciated wheel. I almost plasti dipped them black :)
  7. Jun 8, 2013 at 5:35 AM
    P33Rob
    Rob
    Watertown, NY
    So if they are with a wider tire i.e. 285 on a 17x8 would the lip stick out to the point that they would get scratched easily on a curb or lite rocks/of road.
    Also if I buy them matte black and coat them with a high gloss spray before mounting tires will it go from flat to gloss like I want? Granted I use the correct product.
  8. Jun 8, 2013 at 5:50 AM
    MadToy
    Nick
    Huntersville, NC
    Nah, you won't scratch em on curbs. I wheel in the rocks, so they took abuse from that. The 8" width is perfect with a 285.
    You can paint any color you want. I would use wheel paint though if possible.
  9. Jun 8, 2013 at 6:15 AM
    Polymerhead
    Polymerhead Well-Known Member
    Missouri
    '18 TRD Limited Inferno...Tundra!
    The Yumas look good. There is a thread on here about Yumas on a red truck and they seemed to fit OK. I considered them for my SR5 steelies but ended up buying some CL OEM alloys for $200.
  10. Jun 8, 2013 at 6:30 AM
    P33Rob
    Rob
    Watertown, NY
    Thanks for all the input. What would be better if I want them gloss black spray them with gloss black or coat them in high gloss both would be wheel paint by duplicolor prob but I am not going to rough the surface.
  11. Jun 8, 2013 at 6:36 AM
    MadToy
    Nick
    Huntersville, NC
    I'm confused. You say spray, or coat with Duplicolor? Coating wouldn't use paint at all, and is the much better way to go - but would add about $100 per wheel.
  12. Jun 8, 2013 at 8:56 AM
    TacoDeLaPlaya
    TacoDeLaPlaya Total Automotive Performance Sleeper Cell
    Bobby
    Del Mar, CA
    06 Silver Access cab
    Custom sotoshi deep dish grill 6112 front 5100 rear Leer 100xl
    The onmly problem i see is that the 4.25 inch center bore is slightly bigger than 106mm
    4.17 vs. 4.25. Idk if this would be a problem or not i think the lug nuts would help center the wheel.
  13. Jun 8, 2013 at 9:37 AM
    P33Rob
    Rob
    Watertown, NY
    I am talking about spraying with high gloss over the satin black finish not powder coating. Hopefully that is clear sorry for the confusion
  14. Jun 8, 2013 at 12:37 PM
    MadToy
    Nick
    Huntersville, NC
    Not a problem. Most aftermarket wheels are lug centric. As long as you criss cross and evenly torque the lugs, they run perfect.
  15. Jun 10, 2013 at 2:25 PM
    mikesixtysix
    mikesixtysix Well-Known Member
    North Jersey
    2018 TRD Pro
  16. Jun 26, 2013 at 9:44 AM
    TanderSON
    TanderSON Member
    Tyler
    Northern BC, Canada
    '07 TRD A-Cab (mT)
    I have the Black Rock 937s on my 2007 TRD Sport and really like them. Good quality - I had a good look over before they were installed. They fit just like stock but the centre caps to stick out a bit past the face of the wheel, not really beyond the tire though.
    I know this is a different wheel than you're looking at but just thought I'd put my two cents in re: Black Rock.
  17. Aug 9, 2013 at 5:00 PM
    mad dog
    mad dog Well-Known Member
    laurel springs nj
    blk
    Looking to get those wheels at 4wheel.com however they r out of stock until 8/21/13,also at jegs .com was also waiting for orders on the same date for yuma.
