Anyone use Redline motor oil in their 2.7?
Discussion in '4 Cylinder' started by dawgn86, Jul 31, 2018.
  1. Jul 31, 2018 at 8:11 PM
    dawgn86
    dawgn86 [OP] Well-Known Member
    2013 Toyota Tacoma
    anyone using Redline motor oil in their 2.7?
  2. Jul 31, 2018 at 8:14 PM
    PROseur
    PROseur Well-Known Member
    Pussy
    2012 FJC TTSE/ 2001 Taliban Poverty DCSB/ 2017 6MT PRO / 2018 2.7L SR Utility
    Did once
    Didn’t notice any difference
    Went back to Mobil 1
    But I run redline in gear and diff on all my vehicles
  3. Aug 1, 2018 at 1:54 PM
    casey2012
    casey2012 Well-Known Member
    mark
    yota
    none
    allways used it had a 94 with 22r motor put 413000 miles on it used red line in the diffs trans tranfer case never had any issues use it in my 12 2.7
    specter208 likes this.
  4. Aug 2, 2018 at 5:38 PM
    PreRunnerAlabama
    PreRunnerAlabama Well-Known Member
    2015 Black Toyota Tacoma PreRunner I4
    TRD Sport 17" rims Fog Lights OEM Curt Receiver and Hitch
    I just run the Valvoline Synthetic oil. Good price at most automotive stores and the Blackstone Lab report shows it’s working great. Viscosity holds up over 5-6 thousand miles and Flashpoint remains high after that mileage.
  5. Aug 2, 2018 at 9:26 PM
    shamuspi
    shamuspi Well-Known Member
    Richard
    2017 Tacoma SR
    None
    I will, when my first oil change comes up. Only got my 2017 (new) this last Jan 18. As of today have only 1100 miles on it, and it is my only vehicle. I have used Red Line for years in my other vehicles with fine results. When others dropped their levels of ZDDP, Red Line refused showing its benefits. Red Line was a "high mileage change" oil before it was an industry cool thing to advertise. I have never gone through the expense or trouble of having the old oil analysed (sic), but have relied on other's reports. Yes, it is pricey, but I feel worth it in a vehicle that I hope to keep for many years. Red Line isn't as big as Pennzoil or Valvoline, nor have their advertising budgets, but they have lab tests, race tracks, and chemistry (Group V). I intend to switch out my ATF and differential lube to Red Line also. Do I dare add that I also spend about $12 on what I (and others) consider the best oil filter - the Purolator BOSS.
  6. Aug 3, 2018 at 10:32 PM
    TRVLR500
    TRVLR500 Well-Known Member
    Wyoming
    Tacoma SR5 4X4 2.7 4CYL
    If you want to go boutique, Redline or Amsoil. Either is top notch and probably the best there is. I use Amsoil Signature 10-30 in my 2.7. I also use Amsoil in everything else from diffs to tranny to transfer case.
  7. Aug 5, 2018 at 6:02 PM
    Petrol
    Petrol Well-Known Member
    Central Va.
    Tacoma
    I'm a fan of Amsoil synthetic in manual transmissions but use conventional oil in everything else.
    The only advantage I can see to running synthetic oil in an engine is longer oil change intervals.
  8. Aug 5, 2018 at 9:28 PM
    taco2010trd
    taco2010trd Cyber Bully
    Tampa, Florida
    2010 Silver TRD OR DCSB
    Don't waste your money. Mobil 1 is $2 / quart after rebate.
  9. Aug 8, 2018 at 5:03 PM
    shamuspi
    Richard
    2017 Tacoma SR
    None
    Okay, you chose a highly advertised oil. I chose an oil that is at the top rung of all oils; a Group V synthetic, which Mobil is not. Red Line, with its "extra" ZDDP and it's extreme top level of oil base surpasses all others. Everything depends on do you want the best, for a long life, extreme lubrication under all conditions, or do you want something advertised on TV and magazines. Isn't it great to have a choice!
  10. Aug 8, 2018 at 5:13 PM
    dawgn86
    2013 Toyota Tacoma
    Yes. Using Valvoline now
  11. Aug 8, 2018 at 5:54 PM
    taco2010trd
    Tampa, Florida
    I choose the cheapest I can find. Just get the correct viscosity. Btw I'm doing 12,500 mile oci too! Crazy right?
    Sounds like you are falling for some advertising yourself! Ha
  12. Aug 9, 2018 at 1:27 AM
    shamuspi
    Richard
    2017 Tacoma SR
    None
    Nope, just lab results, race tracks, chemical makeup; stuff like that.
  13. Aug 21, 2018 at 8:59 PM
    TRVLR500
    Wyoming
    The other advantage is that 100% synthetic engine oils are far superior in very extreme conditions as in arctic cold, extreme heat and industrial/commercial use. They flow FAR better when it gets downright cold and excel when it's 110 degrees at high rpm or heavy loads. I'd bet there isn't a race team on the planet that isn't running full synthetics at this point in time. No matter where they race on the planet. I don't follow racing at all so that's just a guess but I'd bet I'm right. In addition to longer change intervals 100% synthetic oil is far better than dino. If you live where the temp never gets below 30 degrees and never above 90 degrees then dino is just fine and you change it more often. In the extreme temps 100% synthetic rules. Pennzoil Platinum is the only off the shelf 100% pure synthetic that I know off. The rest are all blends and work fabulously for engines operating in "normal" conditions.
    You have to go boutique if you want a true synthetic besides Penzoil Platinum which is a DAMN good oil for the average person.
    ecoterragaia likes this.
  14. Aug 30, 2018 at 7:26 AM
    SargeBB
    SargeBB Active Member
    2008 Impulse Red regular cab 4x4 Tacoma
    OEM Cruise, OEM Intermittent wipers, 10-ply Michelins
    I use Mobil-1 in everything; 5W-40 TDT. '08 Tacoma 2.7L 4x4, '15 Super Duty Diesel 4x4, '15 Subaru Forester Turbo, '49 Dodge 3/4 ton & '51 Plymouth. The old Camry v6 has 340,000 miles & still uses no oil (and it does not get babied). We live in a rural, very dusty environment. Factory air filters, Wix or Baldwin oil filters. The old Camry gets synthetic Dexron; SD & Turbo factory ATF & Tacoma Redline GL-4 75W-90. Air filters & cabin air filters are changed at half the factory intervals due to the dust. As evidenced by the Camry, this works for me...can't beat Mobil-1 engine oil!
    DGXR and Clearwater Bill like this.
  15. Sep 1, 2018 at 8:47 PM
    shamuspi
    Richard
    2017 Tacoma SR
    None
    Mobil 1 is a good oil, no doubt. But for Red Line oil users we consider its class of synthetics. Red Line is a Group V, which Mobil 1 is not. Overkill? Possibly. But for those of us who bought what we thought were the best vehicles, why not use the best (that is proven it so, not by advertising, but by racing, and lab tests.).
  16. Sep 2, 2018 at 7:19 PM
    specter208
    specter208 Well-Known Member
    California
    2017 TRD SPORT ACLB w/ 6MT TRUCK WHITE
    TOYOTA OEM: Cast Aluminum Running Boards Mud Guards Bed Mat All-Weather Floor Liner NIssan Frontier Sliding Bed Extender
    Heard decent concentrations of lead were found in oil samples of redline engine oil on some other forum. Don't remember what viscosity or if this anything to be alarmed about.
  17. Sep 4, 2018 at 4:32 AM
    iamroddy
    iamroddy Well-Known Member
    Lead (in moderation) is a good lubricant additive. That's why it used to be blended into gasoline...to lubricate valve seats. That said, I don't use Redline engine oil in my Taco. I change it too often. I buy whatever synthetic is on sale at the time...usually Pennzoil Ultra Platinum. I use Redline engine oil in my Mustang (5W30).
    I do use Redline in the Taco for the transfer case (MTL) and front/rear Differentials (75W85).
  18. Sep 4, 2018 at 3:19 PM
    specter208
    California
    There was a guy on a corvette forum who was reporting higher than normal lead using redline 5w30 for 2 3-4km oci's in a z06. He went to a different oil but changed to a higher viscosity as well. Would have been smarter to switch brands but keep the same 5w30 viscosity to prove if the oil was the culprit or not.
    Edit
    Did some research. Redline oil tends to give false increase readings for wear metals in oil sample analysis for the first 1-2 OCIs (lead,iron, etc). This is considered normal and caused by the additives in the oil cleaning oxides and varnish from the engine components and replacing older oil film with its own protective ingredients. Redline shows its value in racing applications and might be overkill for daily driver pickups but it should be perfectly fine for use in your pickup. Some people even report increased MPGs and no problems running it through their vehicles for hundreds of thousands of miles.
    iamroddy[QUOTED] likes this.
  19. Sep 5, 2018 at 12:50 PM
    shamuspi
    Richard
    2017 Tacoma SR
    None
    "False" in what way?
  20. Sep 5, 2018 at 1:10 PM
    specter208
    California
    Oil analysis usually will show increase metals which would indicate wear. But in theory atleast, the oil is simply cleaning off the metal particles that have bonded to the engine components.
