Anyone use FJ fog switch with offroad lights?
Discussion in 'Lighting' started by eltaco, May 18, 2010.
  1. May 18, 2010 at 6:18 PM
    eltaco
    eltaco [OP] Well-Known Member
    Littleton, CO
    '07 4x4 DC Offroad
    I've been researching switches like a mad-man! I would really like to retain the stock look of the 05+ Tacoma, but I also would like to have some indication as to when the offroad lights are on. That being said, I'm starting to take a good look at the FJ Cruiser Auxiliary and Offroad Light switches. Has anyone used these yet? Are any modifications to the switch necessary? Could you post pics and/or wiring diagrams for the switch?
    Thanks!
  2. May 18, 2010 at 9:49 PM
    MJonaGS32
    MJonaGS32 MJ on a GS
    MJ
    SF Bay Area (East)
    07 LT 4x4 DCSB 6spd Vagabond
    Drifter wedge camper, Dual battery, OBA, ARB locker, 4.56 gears
    got a picture of it?
  3. May 18, 2010 at 9:52 PM
    eltaco
    Littleton, CO
    '07 4x4 DC Offroad
  4. May 18, 2010 at 10:02 PM
    afd23a
    afd23a Well-Known Member
    The Dynamo of Dixie
    05 Access Cab 5 Lugger
    Factory Fog Lights, Removed Secondary Air Filter, Metra Ipod Adapter, Int Wiper Stalk, Wet Okole's, URD Short Shifter, Scanguage II w/Blendmount, Fat Bob's 2.75" spacer lift, ARE topper, SP Performance Pads & Slotted Rotors, 4.10 gears
  5. May 18, 2010 at 10:07 PM
    eltaco
    Littleton, CO
    '07 4x4 DC Offroad
    Awesome, that's just what I'm looking for! Thanks so much.
    Is this switch factory orange when not activated, and green when activated?
    I'm going to put this on order, along with the daytime running lights mod!
  6. May 18, 2010 at 10:16 PM
    afd23a
    The Dynamo of Dixie
    No problem man. The light symbol is always illuminated (not sure what color) and when the lights are on the upper LED is illuminated orange or green, sorry not sure which. It's a pricey switch but the upper LED is pretty nice to let you know when they're on.
  7. May 18, 2010 at 10:25 PM
    eltaco
    Littleton, CO
    '07 4x4 DC Offroad
    k, I'm going to order it without the harness. $30 for a harness seems pretty steep. I plan to just solder wires to the switch. If you see any problems with this, I'd love to hear it in advance.
    Also, I just read the wiring diagram. Since I don't have the ATRAC function, do you remember which wires you tapped into?
    Thanks for all the info
  8. May 18, 2010 at 10:35 PM
    afd23a
    The Dynamo of Dixie
    Hmmmmmm.......I agree $30 for the harness is steep. I think I bought the harness just to make it easier, but soldering wires to it will work just as well so no issue there.
    I think I used an add-a-fuse/circuit thing from autozone to get power to the switch. This would be where it says "Interior Light Circuit". I just plugged it into an empty spot on the fuse panel behind the coin drawer. I picked an empty fuse slot that was hot only after the ignition was on. That way when I turn the key off the fogs go off too. Also the regular headlights don't need to be on in order to use the fog lights and I didn't have to tap into the headlight circuit.
  9. May 26, 2010 at 2:29 AM
    ratrod
    ratrod Well-Known Member
    Los Angeles
    2006 Toyota Tacoma Dbl Cab TRD SR5 4x4
    Bilstein 5100s @ 1.75 with 1.5 AAL, Satoshi Grill Mod with 2 Hella 500s behind the grill, LED dome and map lights, custom made (by me) 10" subwoofer box behind the dbl cab seat, DVD/iPod/Bluetooth/GPS/TV/USB/Stereo, Yakima rack, Shell, tinted front windows to match the factory backs. Backup cam in the tailgate handle mod.
    Great thanks for the find!
  10. May 26, 2010 at 6:26 AM
    eltaco
    Littleton, CO
    '07 4x4 DC Offroad
    No problem!
    Mine should be here any day now...
