Anyone use a Foxwell NT650 Scan Tool?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by KY_Rob, Sep 20, 2019.
  1. Sep 20, 2019 at 1:18 PM
    KY_Rob
    KY_Rob [OP] Well-Known Member
    Rob
    North East Ohio
    2022 DCSB TRD-OR 6MT
    OEM: TRD Pro Grille & Garnish, TRD Pro Skid Plate, TRD Pro Rear Tail Lights, TRD Pro Shift Knob (MT), Tailgate Remote Lock, Black Chrome Exhaust Tip, Black Emblem Overlays, Bed Mat Vorra65 AC Drain Mod Kit FBC Harness Solutions (aka daveeasa) D-I-R Harness with Aux out Total Chaos Bed Stiffners Taco Garage Dashtop Multi-Mount MESO: Gashole, Total Tails Stg1, V5 Switchback Mirror Turn Signals, HitchPod + S1, Vent Rings AJT Designs: Radio Knobs, Door Handle Covers (Removed) Black Forest Industries Shift Knob for R8…using an adapter MountainHatch Tailgate Insert KTJO4x4 Drivers Side Grab Handle Cali Raised Catalytic Converter Shields BajaDesigns NextGen Squadron SAE Amber fogs Bilstein 6112 Front & 5160 Rear ICON Add-A-Leaf pack ICON Sway Bar Relocation Blocks ECGS Bushing 17” SEMA Gunmetal Gray Wheels with LT255/75R17 KO2’s Active Off-Road U-Bolt Flip Kit w/Timbren Bump Stops Redline Elite Hood Struts
    Thinking of buying an upgraded scan tool, as every vehicle I own is now 2002 or newer. Been dinged hard by the stealerships in the past, all because I didn’t have the right tool.
    Anyone used the Foxwell NT650 on their 3rd Gen Taco (2018 specifically)? How well do you like it?
  2. Sep 20, 2019 at 2:10 PM
    Taco_Coma
    Taco_Coma That's a lovely accent you have. New Jersey?
    South NJ
    2018 DCSB SR5
    I have the BMW program on mine, It's alright
  3. Sep 20, 2019 at 2:23 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    I am not sure why you'd pay that much for a handheld with a limited interface? I have an 6yr old, $15 BT adapter (ELM 327 clone) that has worked great for settings and such with Carista, OBD Fusion, and Torque Pro. I've used the Tactrix adapter for flashing the ECU on the Taco and settings on my daughter's Mazda (FORScan).
    Cracked versions of TS V14 are out there. Lemme know if you want a link.
    Just sayin'.
    KY_Rob[QUOTED][OP] likes this.
  4. Sep 20, 2019 at 5:29 PM
    KY_Rob
    Rob
    North East Ohio
    Well, this is the kind of things I’m looking for, thanks. Since I don’t have a laptop to use the tools you mentioned (and wouldn’t have any other need for one), having a dedicated device makes sense for me. Perhaps I’ll look at the NT680 model.
    tonered[QUOTED] likes this.
  5. Sep 20, 2019 at 5:49 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Ah! That does put a wrench in the works.
    Just be sure to get a quality unit with a known track record if you intend to flash the ECU.
  6. Sep 20, 2019 at 8:02 PM
    mutely
    mutely Well-Known Member
    TRD Pro in metallic primer
    The only ECU flashing is from OVT at present. ODBII monitoring and changing values is a different story, and that’s what the OP seems to be after.
    To the OP, if you don’t have a laptop, then you’re stuck with limited options, a generic ODBII to Bluetooth adapter and iPhone or Android software is probably your best option, (not the hand held stuff). They will tell you everything you need to know to diagnose problems, but you’ll never get the functionality of decent laptop software. The laptop software will let you reset airbag sensors and wheels size settings (depending of what the ECU supports) and stuff like that. The Carissa app seems to have decent (maybe best) functionality of the Bluetooth adapter variety, but fuck their monthly charges.
    $500 on decent laptop software and adapter, or $20~$60 generic adapter designed for mobile device and free app would be my recommendation depending on what you’re after. You can also get Toyota’s laptop software for free (not legally) that will work with a genetic $15 adapter.
    KY_Rob[OP] likes this.
  7. Sep 20, 2019 at 11:23 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Not exactly true. There are the TSB tunes. There are also at least two other tuners for the 3rd Gen out there. I'm completely satisfied with OVT, but full disclosure and all that.
  8. Sep 21, 2019 at 1:20 AM
    mutely
    TSB you’ll need a dealer account and paid $$$ subscription. That’s not even available to us even if someone wanted to pay for it. But either way, OP wasn’t looking at ECU flashing that was the point.
  9. Sep 21, 2019 at 6:16 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Sorry, but that is 100% untrue:
    https://www.tacomaworld.com/threads/software-update-for-the-manual.562550/
    I did this TSB update myself at home with a borrowed Tactrix adapter before I had OVT.
    Like I said earlier, I have a link for TS V14 if folks want it. That is what I posted earlier, giving the OP a full set of options versus limited HH. Without a laptop, the OP is limited though.
  10. Oct 29, 2019 at 1:28 AM
    joestacostand
    joestacostand Member
    2019 Tacoma SR
    I have been diving deep into threads related to maintenance so far (have a bunch of watched threads now) and just lately have been researching all things "mini-vci j2534".
    It's a shame that Xhorse fell prey to the far east counterfeit market as so many good products that get sourced there often do. Like so many other cheap counterfeit clone products, I am left wondering whether I should even bother with anything on Amazon or eBay that costs from $20 to $80. Perhaps just going to Tactrix will save money and time in the long run: 5 x $40 clones that are flakey VS similar money spent getting something that "just works" and comes with access to "real" vendor support as part of the sale.
    Primarily, I want a "Techstream" based or other device which will allow access to see "real-time" stats like RPMS, fluid temps (ATF for instance), etc. A bonus of using "Techstream" would be being able to get the taco to enter the ATF fluid fill "temp test mode" and monitor the temp while waiting for the "magic window" temperature range to appear. :thumbsup:
    Just about to search around for a bottle pump to set up for getting ATF transferred from quart containers into the fill port of the transmission. Would like to cobble together something that keeps the bottle stable (sitting on the ground and not tipping over) while the siphon is in the neck.
    I just took posession of my taco, and have less than 200mi and I've benched it while I gather the bits and pieces I'll need to make sure I have the correct amount transmission fluid. Part of me is totally pissed that this is even a thing to worry about on a vehicle I've had less than 2 weeks. But I am putting it in perspective: I could be "in the dark" and at the mercy of my ignorance. Instead I have these forums to learn from everyone willing to share their experiences -- good and unfortunately bad sometimes. My own previous experiences with stealership service departments has me convinced that I better "learn and learn good" how to take care of as many things on my own as possible.
    Back to the thread topic though: will the investment in a Tactrix adapter mean that I can use the *coughs* "free" versions of techstream that have found their way out into the hands of lowly Toyota drivers/fans? Or is there a better/best solution? I don't have unlimited money, but have been stung by clone electronica/etc on eBay/Amazon/etc before. (My ELM adapter and Torque Lite for instance was always a "hit and miss" proposition with getting repeatable results with respect to getting it to actually connect to the android tablet and car at the same time.)
    Thanks.
  11. Oct 29, 2019 at 1:41 AM
    joestacostand
    2019 Tacoma SR
    I should have mentioned: I am also curious to know about users of the Foxwell standalone tool(s).
    For quick and simple code reads / resets, it would be great to add a tool that doesn't require dealing with the vagaries of M$ Whinedoze OSes ("Please wait, installing updates"/"*BSOD*"/"*Boot Device Not Found*"/etc/etc). I work in IT, I could go on. NOT having to deal with IT (particularly M$ winbloze related) while I am swinging wrenches is actually therapeutic :p
    Thanks again!
  12. Oct 29, 2019 at 2:09 AM
    soggyBottom
    soggyBottom Well-Known Member
    KY_Rob[OP] and Yann like this.
  13. Oct 29, 2019 at 3:27 AM
    Big tall dave
    Big tall dave Well-Known Member
    Elora, Ontario, Canada
    2018 Tacoma TRD OR DCLB
    Last year I tried to DL Techstream a few times and could never get it to work properly so I did some research and bought the Foxwell NT650. It wasn’t as good or updatable as advertised/reviewed and it couldn’t do the TPMS sensor ID swap on my 18 Taco so I returned it. I then bought a Launch CRP129E hand held and so far it works great for the part time-messing-around-in-the-shop that I need it for. Doubt I would have bought it if I was still in the trade and needed something for daily, money making use, but IMO, it was worth the $240 bucks and far superior to the 10+, non-subscription Bluetooth apps that I also tried.
    **One of these days i’ll get around to upgrading my Windows laptop and I will try Techstream again; it’s ultimately what i’d like to have in the end...
  14. Sep 26, 2020 at 6:16 PM
    harbrown
    harbrown Well-Known Member
    Harold
    Daphne AL
    2016 Tacoma Off Road 4x4
    can you get the transmission temp from this model?
  15. Sep 26, 2020 at 6:41 PM
    tommygs3
    tommygs3 Well-Known Member
    tommy
    18 tacoma limited
    Fox 2.0 - KDmax tune - 5.29 revolution
    i use launch x431.. works great. kinda pricey but it has everything
  16. Sep 28, 2020 at 6:18 PM
    soggyBottom
    Not sure. Ill try.to remember tomorrow. If you don't hear back from me, send me a PM.
  17. Sep 28, 2020 at 8:46 PM
    The_Devil
    The_Devil Well-Known Member
    E
    2018 Tacoma TRD Off-Road
    DIY Tonneau, Toolbox, Lift, TRD Wheels, TRD Grill
    This was the only tool that allowed me to program my BMW fuel injectors.
    I don't really understand why it is necessary, but I was able to save thousands of dollars using this.
    Taco_Coma[QUOTED] likes this.
