Anyone towed their DCLB with a U-haul, penske, budget trailer?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by fur pig, Dec 30, 2012.
  1. Dec 30, 2012 at 7:20 PM
    fur pig
    fur pig [OP] Well-Known Member
    Hey guys,
    The double cab long bed wheelbase is 140" according to toyotas site which is longer than the "max" allowed with uhaul, penske or budget car haulers. Has anyone successfully put their DCLB on one of these? I don't know how conservative their max length measurements are or if there is no way the truck would fit.
    Thanks
  2. Dec 31, 2012 at 7:40 AM
    fur pig
    bump ttt
  3. Dec 31, 2012 at 5:03 PM
    fur pig
    anyone?
  4. Dec 31, 2012 at 5:13 PM
    bluesurfur
    bluesurfur Active Member
    Scott
    CO
    06 DC PreRunner
    Soft Topper Stereo upgrade
    Max length? Seems like an odd dimension to even consider when towing. I have a DCLB and I have towed a 25ft camper/18ft box trailer (5,500 lbs) and a 14ft boat. The 25ft camper has logger 4,000 miles behind my Tacoma. It tows great but, make sure you have a 7-way harness and a brake controller.
    When it comes to tow vehicles the longer the wheel base the better. Your actions with the steering wheel will have lesser effect on the trailer and provide more stability.
  5. Dec 31, 2012 at 5:14 PM
    Oowen
    Oowen Well-Known Member
    Owen
    Reno, NV
    '24 F-150
    Is hat the type of trailer that drags the rear tires of the truck?
  6. Dec 31, 2012 at 5:20 PM
    Ghoster
    Ghoster Well-Known Member
    Baltimore
    2012 PreRunner DCSB
    I think he is talking about putting his truck ON a trailer.
    I have used them a few times, but never with a truck on it. All I have towed was small cars, I never had any issues. One of them had chains/straps built into the trailer to tie down the vehicle. Those tie down points were NOT moveable. So if the wheel base was to long the tie downs wouldn't work.
  7. Dec 31, 2012 at 5:36 PM
    fur pig
    Hey guys,
    Sorry, yes, I am talking about putting my tacoma on the penske trailer and towing it behind a moving truck.
    My concern is that my tacoma wheel base is too long for their trailers. I'm just trying to see if I can still squeeze it on, even if it's not technically the right size to fit.
  8. Dec 31, 2012 at 5:48 PM
    Ghoster
    Baltimore
    2012 PreRunner DCSB
  9. Dec 31, 2012 at 5:54 PM
    truckalter
    truckalter Well-Known Member Vendor
    Luke
    Waynesville, NC
    I actually own 3 Budget Truck Rental dealerships....
    You won't get a DC long bed on a U-Haul or Penske trailer. You won't get it on most Budget trailers... However, Budget does have a few tilt back style trailers that your truck will technically fit on. However, Budget will stay say it won't work. What you are looking for is called an ACC trailer from Budget. They are a flat bed style with a large rear gate on them... you will know if if you see it.
    If you can find one of those trailers from Budget and just tell them you are towing a camry or something you could get away with it.
    Alternative is you could rent a tow dolly and take the drive shaft loose. DO NOT try to tow on a dolly with the rear wheels on the dolly.
    Also, I will deny this post should Budget ever ask...lol
  10. Dec 31, 2012 at 6:37 PM
    fur pig
    Thanks for the help Luke. I know exactly the trailer you are talking w/the flip up gate. I'll have to call Penske and make sure they are okay with me towing a budget trailer behind their truck. What sucks is I have a beautiful 18' car hauler but don't want to risk the liability of towing my own trailer behind the Penske truck as apparently it's a big no no. Last resort I'll use a dolly w/the front tires on it. I just have never towed a dolly and worry it'll whip side to side. I also fear that with a dolly I won't know "what's going on back there" for example, if I had a flat on the dolly or taco, I wouldn't know.
  11. Dec 31, 2012 at 7:00 PM
    truckalter
    Luke
    Waynesville, NC
    Unfortunately Penske will likely say no to the trailer... and Budget will say no to the trailer being towed by Penske... in fact Budget and Penske don't typically rent a trailer to customers who don't have a truck rental as well.
    Any particular reason you aren't renting a Budget truck to go with the Budget trailer?
  12. Dec 31, 2012 at 7:16 PM
    TeamSarcasm
    TeamSarcasm Flawless Escalation to the Ludicrous
    The better coast
    I think it would be smarter to say use it at your own risk :p
  13. Dec 31, 2012 at 8:55 PM
    truckalter
    Luke
    Waynesville, NC
    Since we really aren't supposed to tell you that his sort of setup will work if the corporate people say it won't I don't think tey would like that an better...lol
  14. Jan 1, 2013 at 3:48 AM
    Mxpatriot
    Mxpatriot Well-Known Member
    '06 4x4 AP LT and Locked
    Won't fit on a U-haul, I'll guarantee you that. My truck (DCSB) fit on a U-haul with 4'' to spare (and that's the wheels, not the body; body was hanging off the end of the trailer).
    They also won't rent to you unless the towing vehicle weighs more than the trailer + your truck, which is going to be hard to find. We told them it was for a Rav4 and towed with an F150.
  15. Jan 5, 2013 at 8:07 PM
    satcom221
    satcom221 Well-Known Member
    Rick
    Kingston, WA
    2023 Celestial Silver Double Cab SR5 4x4 SB
    VLEDS V tail conversion, gas cap holder
    Yes it can be done with U-Haul. I just towed my Tacoma from Wichita Falls, TX to Amarillo, TX last weekend - 250 miles with no worries. I have 17 inch wheels and had to let air out on front tires to allow the strap to engage. Extra chains on back axle to secure. Didn't shift or even bounce.
    I was driving a 20' U-Haul and I think you would need to tow with a similar sized vehicle. There is a transporter that is longer than the one I got. You can verify your setup thru U-Haul website, just pick a similar sized truck with the auto transport and put in your towed vehicle info. They do one way rentals without the need to rent the truck from them (good if you are getting Penske or other).
    http://www.flickr.com/photos/harris-inspired/8352104058/
    http://www.flickr.com/photos/harris-inspired/8352112228/
    Drive smart and check the tie downs after 20 or so miles if you are on the highway.
    Rick
  16. Jan 5, 2013 at 8:10 PM
    TeamSarcasm
    The better coast
    Your truck looks like a fat person in a mini cooper on that trailer lol
  17. Jan 5, 2013 at 8:21 PM
    TeamSarcasm
    The better coast
    Also op has a dclb :p
  18. Jan 5, 2013 at 8:43 PM
    08PRELB
    08PRELB Don't Tread On Me
    Adam
    805
    08 Prerunner LB
    Toy Tech Ultimate Lift kit,Buildt Right UCA's 285/70/17 BFG AT, Camburg Spindles, BHLM, K&N, Flow Master 50, Spider Trax, URD MAF CAL, Satoshi Grill, any time fog mod, 20% tint, Katzkins Leather Interior, FX-R Projector Retro
    Good luck I looked into towing my truck when I moved from San Diego to OKC but te DCLB is too long for the trailers they and the wheel size is too big for the straps on the dolly.
  19. Mar 1, 2013 at 2:07 PM
    ckeene9
    ckeene9 Well-Known Member
    Chesterfield, VA
    '12 DCSB Supercharged 4x4 TRD Sport
    See Build Thread
    How much tag did you have left on the wheel straps? I have 33's, think they'll fit around?
  20. Mar 1, 2013 at 4:53 PM
    charles leandro
    charles leandro Well-Known Member
    north alabama
    08 perrunner dc sr5
    none
    just get tow dolly youll be good to go
