Anyone running Eibach Pro Truck Sport Shocks?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by stizo, May 4, 2018.
  1. May 4, 2018 at 3:40 PM
    stizo
    stizo [OP] Well-Known Member
    Roseville, CA
    15 DCSB TRD Sport 4x4
    Looking to replace/upgrade my rear suspension. Doing a 1.5" aal and came across these while looking at rear shock options: https://eibach.com/us/i-2915-pro-truck-sport-shock-single-rear-for-lifted-suspensions-0-1.html
    Anyone running them? How do you like them? Any issues? I was going to do 5100s to match my fronts but have come across several posts about people blowing out their rears prematurely. I'm not a hardcore wheeler but I do haul my motorcycle to trackdays and such. Thanks in advance.
    uurx likes this.
  2. May 4, 2018 at 4:12 PM
    Dropitmore
    Dropitmore Panda Man
    Andy
    Downey, CA
    2013 TRD McDouble Cab
    Mall Crawler Edition
  3. May 4, 2018 at 4:49 PM
    Depoxy
    Depoxy Well-Known Member
    SoCal
    2010 Regular Cab 5-speed 4x4
    URD S/S, Eibach pro-truck @ 0.8" lift, hanook 265/75r16 AT
    I have them in the rear, and I'm ordering the front struts to match soon. I really like them so far, but my truck is a DD/weekend warrior.
    The ride on the street is much better than stock and they handled some time in Pismo just fine. Ive never had 5100s to company them to.
    stizo[OP] likes this.
  4. May 4, 2018 at 7:12 PM
    mjbtaco
    mjbtaco low and slow
    Michael
    Montclair , so cal
    Turbo'd 95.5 extra cab and 2013 Silver DCSB TRD Sport
    PERFORMANCE Custom Turbo Setup FRONT SUSPENSION Drop Spindles by Aaron Carswell 01-04 Swaybar Endlinks Energy Suspension Endlink Bushings Cando Upper Control arms QA1 coilovers with 8" spring Custom 4 pot Brembo BBK Modified lower control arms with mjbfab qa1 mounting plates and Poly bushing sleeves REAR SUSPENSION Chasis Tech drop leafs QA1 adjustable shocks weld in drop notch Gas tank cross member bridge 3" angled blocks 2013 Double Cab Short Bed TRD Sport Eibach Pro Truck Shocks front and rear Lifted to the 3rd setting on the front shocks
    I run them front and rear on my double cab. Really like them a lot. Only been offroad once with them but my wife daily drives with them a lot and they're much better than stock. Going on over a year, maybe two now.
    stizo[OP] and Depoxy like this.
  5. May 4, 2018 at 7:13 PM
    Depoxy
    SoCal
    Are you running them at stock height or with additional pre-load?
  6. May 4, 2018 at 7:14 PM
    mjbtaco
    Michael
    Montclair , so cal
    The rear is stock height and running the front in the middle notch.
  7. Jun 15, 2018 at 12:12 PM
    TerraNerva
    TerraNerva Well-Known Member
    Chip
    Central Arkansas
    Ummm....Tundra
    Middle notch means you're using your stock springs? Just got these and paperwork is a little confusing on snap ring settings. I ordered my kit with springs and Eibach said lowest setting will get you 2.5" with new springs, middle setting will get you 2.5" if reuse stock springs, sound about right? Asking someone who has actually installed them to be sure. TIA
  8. Jun 15, 2018 at 3:21 PM
    mjbtaco
    Michael
    Montclair , so cal
    yes I'm using stock springs.
    I'm not sure on heights with the eibach springs but you should get 2.5" if you use the top notch on the shocks with stock springs. I think the middle notch is about 1.5"
