Anyone running 18x10's -24 offset?
Discussion in 'Wheels & Tires' started by redtaco512, Feb 23, 2018.
  1. Feb 23, 2018 at 12:39 PM
    redtaco512
    redtaco512 [OP] Well-Known Member
    Austin TX
    2018 TRD Offroad
    New to Tacomaworld and grateful for all the good info and community. Maybe i haven't stumbled across the right thread but I found a few pics on google with guys running 5100's at 2.5" (AAL 2" in the rear) and 18x10's with -24 offset. Tire size is 275/65/18. Any info or pics would be greatly appreciated.
    Cheers
  2. Feb 23, 2018 at 4:10 PM
    scottsglock29
    scottsglock29 Well-Known Member
    Scott
    Wisconsin
    2019 Cement TRD Sport DCSB
    If you are set on running an 18 x 10 wheel, I would go with a 285/65R18 tire minimum. IMO, anything smaller and you would be stretching your tire across that wheel. Not saying that is not possible, but for better performance and tire life I would go with a tire that is designed to fit nicely on a 10" wide wheel.
    @Discount Tire Direct may be able to offer you some better insight than I.
  3. Feb 23, 2018 at 4:11 PM
    GreeGunc
    GreeGunc Full of regret
    Jacob
    North GA
    1st gen 3rz+18' inferno OR 6spd
    2lo mod. PIAA 510s. Green Floor Lights. Green dash swap. Axle dump exhaust. Husky floor mats. Moto metal mo970's. Shrockworks. Sundown sa-8. 9.5xrc. Kings
    18x10 with 4.5" bs'ing
    275/70r18 (33.4x11.3)20170826_135602-01.jpg 20180116_103526-01.jpg
    Been off-road a bunch, have scratched a wheel up but they went through way worse with the previous owner so I'll be repainting them anyway. The wide wheel does help to keep the tire wide.
  4. Feb 23, 2018 at 4:18 PM
    scottsglock29
    Scott
    Wisconsin
    Looks good. I do like that color.
    su.b.rat likes this.
  5. Feb 23, 2018 at 4:39 PM
    redtaco512
    Austin TX
    2018 TRD Offroad
    scottsglock29 likes this.
  6. Feb 23, 2018 at 4:49 PM
    scottsglock29
    Scott
    Wisconsin
    I don't blame you for not wanting to trim or CMC, but often times it i needed to get the look that you are looking for. I would think with a 32" tire you should be good to go, just going to have to worry more with the width of the tire.
  7. Feb 23, 2018 at 5:21 PM
    redtaco512
    Austin TX
    2018 TRD Offroad
    Fingers crossed on the CMC. Getting it done this upcoming Wednesday. Will have pics to follow. Thanks again guys
  8. Feb 23, 2018 at 5:50 PM
    GreeGunc
    Jacob
    North GA
    Thank you
    I'm not sure what backspacing you are looking at but 4.5 is stock for 1st gens. So I'm running pretty much stock wheels with a 285 tire, I had to do trimming with the tires that were on the wheels before so I'm not quite sure how much I had to do.
    I don't scrub at all dding but I have been offroading and thought I'd have to throw the flares in the back of the truck
    These are the tires that was on the wheels before 325/70r18 33.4x13.5
    I could turn as long as I was on flat ground
    scottsglock29[QUOTED] likes this.
  9. Feb 23, 2018 at 6:20 PM
    redtaco512
    Austin TX
    2018 TRD Offroad
    I’m going for the moto metal M0970 18x10 -24 offset and they are 4.56 backspace.
    Hopefully the custom offset thread was accurate when he said he didn’t have to trim with the 275/65/18s on the same wheel setup.
    Slick look with the 325s @GreeGunc :muscleflexing:
  10. Feb 24, 2018 at 7:33 AM
    GreeGunc
    Jacob
    North GA
    The 325s were horrible. Got caught in a rain storm and it felt like I was on drag slicks
  11. Feb 28, 2018 at 7:46 PM
    redtaco512
    Austin TX
    2018 TRD Offroad
    Some before and after photos with 5100s, aal in the rear, 18x10 -24 offset with 275/65/18s0EB8BB87-6C2F-4131-9C13-82F5FD6BCAC5.jpg 5A482A32-8681-4675-84DD-74A8F6495689.jpg E66D6D6B-C5FB-4C71-9C67-5CEC1DE36580.jpg 15F6CCCE-DF36-43E1-ABD0-E522FEE80BFC.jpg A38B0B08-1954-40F8-973F-2DAE9E78D115.jpg BC1DB15C-D85F-4078-B96F-EE90897EA1B0.jpg
    GMpartsguy and GreeGunc like this.
  12. Mar 1, 2018 at 10:12 AM
    Discount Tire
    Discount Tire Tire & Wheel Specialists Vendor
    Arizona, USA
    Thank you for posting the results! I think it turned out great!
    What modifications did you have to make, if any?
    redtaco512[OP] likes this.
  13. Mar 1, 2018 at 10:36 AM
    redtaco512
    Austin TX
    2018 TRD Offroad
    Thanks! I set Bilstein 5100s at 2.5” in the front, got 5100s in the rear as well as aal 2”. No trimming needed!! Just had to lose the front mud flaps. 36BD3945-8C13-4203-8E6E-2281D86FC2B5.jpg
    Discount Tire[QUOTED] likes this.
  14. Mar 1, 2018 at 10:57 AM
    Discount Tire
    Arizona, USA
    Thank you for the quick reply!
  15. Mar 8, 2018 at 3:22 PM
    Tricky2015
    Tricky2015 Member
    San DIego
    2015 TRD Sport DCLB 4x4
    5112's front 5100 rear. Dirt Kings UCA's 17x9 -38 Ray 10's on 285/70/17 Toyo Open Countrys
    The guy at 4wheel parts is trying to talk me out of running that set up like I also saw from custom offset also. Said it’s going to run into pro with rubbing. Guess I’ll have to Goto discount tire. Looking at doing a pro comp 3” lift on the front with new springs and shocks and a block on the rear.
  16. Mar 8, 2018 at 3:36 PM
    redtaco512
    Austin TX
    2018 TRD Offroad
    I've had zero rubbing and zero trimming. Only took off mudflaps
  17. Mar 8, 2018 at 3:36 PM
    redtaco512
    Austin TX
    2018 TRD Offroad
    I'd also look into bilstein 5100's instead of procomp shocks.
  18. Mar 8, 2018 at 6:33 PM
    Tricky2015
    Tricky2015 Member
    San DIego
    So you just replaced the 4 stock shocks with the 5100’s? Not sure I would do the aal on mine.
  19. Mar 8, 2018 at 7:04 PM
    redtaco512
    Austin TX
    2018 TRD Offroad
    Yessir. They’re adjustable shocks and I set mine at a 2.5” lift. I think you’d be way better off with an aal instead of the block in the back. Post a photo of how it turns out man
  20. Mar 8, 2018 at 7:22 PM
    redtaco512
    Austin TX
    2018 TRD Offroad
