anyone run Super Tech Full Synthetic Gear Lubricant SAE 75W-90 in diff?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by udrunk2002, Apr 29, 2021.
  1. Apr 29, 2021 at 4:54 PM
    udrunk2002
    udrunk2002 [OP] Well-Known Member
    It's like 1/3 the price of redline. I know it's not 75W-85 but it's the same weight and probably protects better. Anyone think this is a bad move?
  2. Apr 29, 2021 at 5:46 PM
    SpeySquatch
    2016 TRD OR DCSB
    You get what you pay for. Subscribe to Amsoil. Much easier decision making :D, you get 25% off when you subscribe.
    cost $10.00
    Also, 75w-90 is fine. I’ve run it with 4.88’s for some time. (Mobile 1).
    However, switching to 75w-110 next oil change. I tow a lot
  3. Apr 29, 2021 at 5:48 PM
    Bishop84
    Bishop84 Well-Known Member
    Loads of people run 75W90, its all I've ever run.
  4. Apr 29, 2021 at 5:49 PM
    captrussia253
    captrussia253 IG: ruslan.khinotskiy
    PNW
    2017 Tundra CrewMax 2016 Toyota 4Runner
    Super tech will be just fine. It’s only diff fluid. Just make sure to change it every few years and you’re good.
    MannyS likes this.
  5. Apr 29, 2021 at 5:51 PM
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    Oh no!!!!
    I run Valvoline Syn 75w90 in my diffs and Xfer case.
    Truthfully, if the lube meets the API specification and viscosity grade as stated in the Owner's Manual, then all will be fine.
    Buying more $$$ stuff mainly just lightens your wallet and gives you warm fuzzy.
    captrussia253 and udrunk2002[OP] like this.
  6. Apr 29, 2021 at 6:00 PM
    16TacomaSport
    16TacomaSport Well-Known Member
    Jon
    Pittsburgh PA
    2022 Camaro SS 1LE 6spd
    I used it in my 16 and was in there for years and worked fine. Just did it the other day on my 21 after it's break in period. It works great and cheap.
  7. Apr 29, 2021 at 6:01 PM
    udrunk2002
    Toyota is over $40 a quart, Redline is like $19. This Super tech is $7.24/ qt. So 6 qts can cost me like $120 for Redline or like $45 for the cheaper stuff. Looking to see if anyone had any bad experience with this stuff.
  8. Apr 29, 2021 at 6:02 PM
    SearArtist
    SearArtist GX poor
    NC
    GX470 & GX460
    Things
    Yes. I also use super tech for my engine oil in all our vehicles. Zero issues.
    I use Ravenol for the t-case, that’s the only thinf that doesn’t get super tech oil.
    Her GX 460 and my GX 470 also get the same treatment.
  9. Apr 29, 2021 at 6:38 PM
    Bowhuntercoop
    Bowhuntercoop Well-Known Member
    2006 5.9 Cummins , 2018 4Runner, 2025 gx550
    Super tech engine oil and diff oil in the taco and t4r. Ravenol for the t case as @SearArtist mentioned above. Tacos got 40k, t4r has 60k. Been rolling like clocks. Have no issues using super tech with scheduled maintenance intervals at all.
    captrussia253 likes this.
