Anyone replaced an A/C Compressor Pick-up Sensor
Discussion in 'Technical Chat' started by ronmdon, Jul 2, 2012.
  1. Jul 2, 2012 at 10:06 AM
    ronmdon
    ronmdon [OP] Member
    07 SR5 Tacoma
    My air-conditioning stopped working recently and the dealership troubleshot down to the A/C compressor pick up sensor. It's starting to warm up here in Montana and several hours of driving at 75MPH with the windows down is getting old...
    Here is the schematic:
    http://www.ronandonovan.com/p1029101687/e254f5eec#h254f5eec
    I went to a few auto parts stores to see if I could purchase the part myself. They couldn't find the part.
    Anyone have any experience with this replacement? Anywhere online to order a new one? Can I replace it myself?
    Part Number - 81150-04163
    I'll have to get the whole A/C system recharged after this, or so the dealership said.
    Any info is much appreciated, thanks.
    BillyWest12 likes this.
  2. Jul 7, 2012 at 2:06 PM
    Tacoma Mike
    Southern Maine
    Is the ac light flashing ...
    If it is and they diag as that sensor be prepared to put a compressor in it too.
    There is a chance the sensor ring inside the comp is damaged in some way. I have seen that sensor fix vey few flashing lights. I have a spare I use for diag. You do not need to evac and recharge to replace it. This sensor is only for a compressor that is starting to lock up and disconnects the clutch to keep from burning off the belt.
    If they are doing a recharge then the system is low to begin and the system won't activate anyway or they are going to put a fresh charge in it or they are adding on stuff.
    I don't know if the system is throwing codes or not so my info is not a diag.
    I'm not there to confirm or deny the issue.
    You asked for info so I gave you some hehehehehe.
    Good luck..
    Sunfish and BillyWest12 like this.
  3. Aug 16, 2012 at 11:48 PM
    tacobert
    tacobert Active Member
    Vancouver, BC
    06 DCSB TRD Offroad
    Did you get this fixed? If so what was the issue? I have the same prob
