Anyone put wheel spacers on a 3rd gen?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by geekyadam, Jun 16, 2017.
  1. Nov 30, 2018 at 4:09 PM
    #41
    Lanayru
    Lanayru Well-Known Member
    2016 Quicksand Tacoma OR
    Is there any actual function for wheels spacers or is it just for looks?
    BlackGT99 likes this.
  2. Nov 30, 2018 at 4:26 PM
    #42
    navin r
    navin r Well-Known Member
    2017 double cab short bed trd off road 4wd w/ premium pkg.
    For guys with larger tires, or sometime with different wheels, or certain lifts, it's advantageous to run wheel spacers to gain some clearance to the truck fenders. Also, my understanding is the Pro wheels move the tires out 1/2" on each side, I assume for greater stability (?).
  3. Nov 30, 2018 at 7:22 PM
    #43
    TacoPharm
    TacoPharm Follower of Jibbers Crabst
    Phil
    San Diego
    MGM 2017 Tacoma TRD Off Road 4x4
    SPC Light Racing UCA Eibach Pro-Truck Lift System Deaver Stage 1 Leafs Wheelers Superbumps x4 Wheelers U-bolt Flip Kit SCS Ray10 16x8 Gun Metal 285/75/r16 BFG A/T KO2 CMC by @Speed Freek 4.88 Gears CBI Alu Full Skids Sliders by @Shmellmopwho SOS Concepts Streamline Bumper Warn Xeon 10-S winch Factor 55 Flatlink E recovery shackle Optima Red Top 35 @Coupe “TRD” Batt. Hold down Baja Designs Squadron SAE Fogs Caliraised Ditch lights Hypertech Speedometer corrector Fend-X inner fender guards ARE Z-Series Topper DYI sleeping platform
    I needed a little clearance with the tires I’m running, I noticed the truck doesn’t roll as much in turns now too.
    uploadadventure likes this.
  4. Nov 30, 2018 at 8:03 PM
    #44
    Harvo
    Harvo Hanging On !!!
    17' TRD Offroad DCSB
    SpiderTrax, RCI Sliders, Warn bumper, Smittybuilt winch, Ridge Grapplers...
    They push the tires out which helps keep the body off trees.
    stun gun likes this.
  5. Dec 1, 2018 at 1:42 AM
    #45
    BearOnABicycle
    BearOnABicycle Active Member
    Kevin
    2018 black Tacoma TRD off-road
    Bilstein 5100s front/rear, JBA uca’s, falken wildpeak at3w 285/75/16, 16” trd beadlock style wheels, spidertrax 1.25 wheel spacers.
    I run 1.25 spidertrax on my 18 trd/or/dcsb
    I’m lifted 2.5 up front and 2 rear same setup as you with bilstein/888s. Running 285/75/16 with jba uca’s
    I still rub mostly in reverse at full lock left and right and sometimes at full lock going over bumps. Getting cmc job next week to fix this issue bc it’s really annoying lol
  6. Dec 1, 2018 at 2:13 AM
    #46
    bacon_st
    bacon_st Well-Known Member
    San Diego
    16' Taco TRD sport
    If anyone has a Lexus or Toyota car at home, I have some ALCOA Aircraft grade aluminum 10mm spaces which are custom made, and I am selling them all 4 for $150. + shipping. Asking less than half of what I paid for them. These aren't your cheap autozone spacers, these are single cast and machined high strength ones. I sold my car and don't have need for those. 5X114.3 bolt pattern.
  7. Dec 2, 2018 at 6:50 AM
    #47
    UNReaL_PiNeTRee
    UNReaL_PiNeTRee Member
    aPoLLo
    16 Blue Quad SR5
    Do installing these spacers require any adjustment to the vehicle alignement? Planing on doing a lift and wheel spacers, but not at the same time. So in wondering if I will need to do an alignment twice?
    Quicksander17 likes this.
  8. Dec 3, 2018 at 6:41 PM
    #48
    Theshortbusmafia
    Theshortbusmafia Well-Known Member
    Justin
    2017 Tacoma Offroad
    Are you only rubbing on the cab mount? I’ve already done a CMC and I still rub a tiny bit where the mud flaps used to be attached to.
  9. Dec 3, 2018 at 10:17 PM
    #49
    BoggerBret
    BoggerBret Wolfknive
    Bret
    Gualala CA/ Kona HI
    2018 DCLB TRD Sport 4X4 White
    3' ready lift, 285 feds, 2'' wheel spacer.
    3'' lift with 2'' supreme suspension spacers. No real trimming, just a tiny piece of plastic on the cab side of fender that stuck out. Don't rub anymore, I was backing up and full turn goin up a little hill and It did do a little rub. Nothing major. But I also don't off road the thing
    Tacothunder07 likes this.
  10. Dec 3, 2018 at 10:28 PM
    #50
    BearOnABicycle
    Kevin
    Yeah only rubbing on the cab mount. I only got spacers bc I would’ve rubbed the uca’s without them according to marlin from JBA
  11. Mar 9, 2019 at 1:12 PM
    #51
    uploadadventure
    uploadadventure It’s all @ColoradoTJ’s fault
    Dixon, Mo
    2019 Cavalry Blue Tacoma TRD OR (sold) 05 Duramax
    Did your nuts only screw on a few threads? Have you had any issue with this?
  12. Mar 9, 2019 at 1:15 PM
    #52
    uploadadventure
    Dixon, Mo
    I decided not to install spacers just yet until I figure out what I’m going to do about the inner nuts.. I don’t like that they are only using like 3-4 threads
    Fastbilly5 likes this.
  13. Mar 9, 2019 at 2:51 PM
    #53
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    They sell extended lug nuts, just for what you are experiencing. The new extended lugs fit down inside spacer, grabs 8/9 threads. Just google it (wheel sparer extended lug nuts), Low Range offroad has them.
    Guccitaco, CS_AR, Fastbilly5 and 2 others like this.
  14. Mar 9, 2019 at 3:03 PM
    #54
    HoboDave
    David
    Carlsbad, New Mexico
    2023 Toyota Prius
    I used 1" spacers for awhile to solve a rubbing issue. I put BFG KO2 285/75/r16 tires on the stock wheels and had rubbing on the UCA at full right lock. The spacers were just cheapie flat ones the tire store ordered for me but they worked until I got the money to buy TRD Pro wheels. No rubbing with them. They have a different offset than the OR wheels so no spacers needed.
  15. Mar 9, 2019 at 3:47 PM
    #55
    uploadadventure
    Dixon, Mo
    Nice. I’ve been looking all over locally for these (St Louis) only thing close is https://www.oreillyauto.com/detail/...81594?q=Extended+thread+wheel+nuts+m12&pos=62 not sure if I want to check these out or just order some...
  16. Mar 9, 2019 at 7:05 PM
    #56
    synaps3
    synaps3 Wag more bark less
    Dave
    Los Alamos, NM
    2017 White SR5 4x4 DCLB
    SOS armor, ARE MX walk-in, Fox coils, Dakar leafs, etc
    No, you do not need to do an additional alignment with spacers. They do adjust your track width and scrub radius, but neither are adjustable by an alignment. Bad alignment can be exacerbated by spacers though.
    This was my main concern with spacers, I solved it with these: https://www.amazon.com/gp/product/B07DLX519N/ref=oh_aui_search_asin_title?ie=UTF8&th=1 - I have over 10k miles on them and the spacers on that page, including offroading. No issues. I applied them to factory spec (I think 80 ft pounds?) with loc-tite. I checked them about a month ago when I rotated my tires, they were all still to spec.
  17. Mar 9, 2019 at 8:02 PM
    #57
    uploadadventure
    Dixon, Mo
    Nice. I just bought those today. Hopefully this fixes my issue too.
  18. Mar 9, 2019 at 8:14 PM
    #58
    ceedless
    ceedless Well-Known Member
    Los Angeles, CA
    2018 Super White DC TRD OR
    Bora 1.5” hub centric w/ ET Spline lugs for my Method’s. Checking the torque after 550-ish miles driven. Zero movement from any of the lugs that come in the Bora Kit. Some will say it’s overkill but, I’ll be checking them again come summer and then again in winter. Not that I have any concerns, I’m actually very pleased with these spacers but, I do transport my 4 year old around and his safety is my top priority.
  19. Mar 9, 2019 at 8:17 PM
    #59
    uploadadventure
    Dixon, Mo
    @ceedless do you have the extended thread lug nuts?
  20. Mar 9, 2019 at 8:22 PM
    #60
    ceedless
    Los Angeles, CA
    They are 12x1.5...here the link And here the link for the Gorilla ET Spline lugs
