Anyone put tweeter in 3rd gen sail panel?
Discussion in 'Audio & Video' started by Oldman808, Mar 26, 2017.
  1. Mar 26, 2017 at 11:11 PM
    Oldman808
    Oldman808 [OP] Well-Known Member
    Planet Earth
    2023 Taco TRD Sport
    Anyone molding the sail panel for their tweeters ? Toyota screwed the pooch placement of the tweeters on the dash! Imo they should be within 12"s of the mid bass driver , not bouncing off the glass. A pillar mounted not a good idea "airbag" under them. Cutting door skin ouch! Appreciate any feedback from people that understand audio in a vehicle.
    Thanks
  2. Apr 3, 2017 at 8:55 PM
    RC84
    RC84 Well-Known Member
    3G Double Cab TRD OR
    SCS F5 - 17x8.5 Matte Gunmetal Cooper ST Maxx - 255.80.17
    I installed my tweeters in the bottom corner of the a pillar (triangle piece). I used the factory mounts that came with my speakers, which limited my options in regards to direction. I'll post pics tomorrow and more details about the install.
  3. Apr 3, 2017 at 9:03 PM
    Oldman808
    Planet Earth
    2023 Taco TRD Sport
    Cool thanks . Been thinking about this as the dash mounts were designed for a mini mid not a tweeter.
  4. May 6, 2018 at 4:43 PM
    LtPeteMitchell
    LtPeteMitchell Well-Known Member
    2018 TRD OR
    Can you post some pics?
  5. May 6, 2018 at 5:23 PM
    suaveflooder
    suaveflooder Well-Known Member
    2021 4Runner Venture
    yes, pics please
  6. May 20, 2018 at 11:36 AM
    jwhitettu
    jwhitettu Member
    Jesse
    Austin, Texas
    2018 Midnight Black Tacoma DCSB TRD Sport 4x4
    LED bar underneath grill and plates direct to frame brackets. Tuning chip, pedal commander.
    Just an aside, I agree that the corner under the glass is not the best place for the tweeters. But tweeter sound is often underestimated. I replaced them with the Subaru factory tweeters that use the same brackets and component connections as our Tacos. They were like $90 for the pair online. It was an easy install and replace, and the sound improvement was massive! They sound really good. The Toyota speakers are kinda garbage. Also, don't let your dealership talk you into the JBL upgrade package if you get a new Tacoma. The factory speakers bad as they are, sound better than the JBLs in my humble opinion.
    xxTacocaTxx likes this.
  7. May 20, 2018 at 11:38 AM
    Hobbs
    Hobbs Anti-Lander from way back…
    Yep…
    Rock Bangen', Desert Tamin', Gold Findin' Machine!
    Ditto on the Subaru's (made by Kicker). Huge improvement!
    jwhitettu[QUOTED] likes this.
  8. May 20, 2018 at 11:43 AM
    jwhitettu
    jwhitettu Member
    Jesse
    Austin, Texas
    HUUUUGGEEEE difference. Tweeters can really make or break the system.
  9. May 20, 2018 at 12:08 PM
    Hobbs
    Yep…
    Agreed !
    I also installed these in the front door: https://www.crutchfield.com/p_206KSC6930/Kicker-44KSC69304.html?tp=91 and the sound is righteous! And of course they are $30 cheaper now...
    In addition, I installed these in the rear door:https://www.crutchfield.com/p_206DSC6704/Kicker-43DSC6704.html?tp=78072 and that was a waste of money. They add very little sound. Oh well, overall I am happy with the sound!
  10. Jun 30, 2018 at 9:22 AM
    CoastieRon
    CoastieRon Hammocking Fool
    Ron
    Nashua
    Lil' Silver
    Too much.
    But still waiting for a picture of a tweeter in the sail panel....
    LtPeteMitchell likes this.
  11. Jul 1, 2018 at 9:52 AM
    LtPeteMitchell
    2018 TRD OR
    Same here. I just went ahead and made my own brackets with pipe straps.
  12. Jul 1, 2018 at 1:03 PM
    2Loud
    2Loud Well-Known Member
    TRD Pro Grille Predator Step Tube 17" Maverick Alloy Wheels Nitto A/T Terra Grappler (265/65R17) Tri-Fold Hard Tonneau Cover with LED Lights V6 Tow Package Chrome Exhaust Tip XP Badging Stereo Pioneer AVH-X5800BHS Arc Audio 900.6 - 6 channel amplifier (4x60 watts + 1x550 watts bridged) Arc Audio 300.2 - 2 channel amplifier (2x180 watts) Hybrid Audio Technologies Clarus 1" tweeter Hybrid Audio Technologies Legatia 3.5" mids Hybrid Audio Technologies Legatia 6.5" midbass Image Dynamics IDQ10v4D2 10" DVC sub Stinger Roadkill Sound Deadner 200 AMP Circuit Breaker: Rockford 200 Amp Circuit Breaker Krystal Kable RCA Cable KnuKoncepts wiring and interconnects
    When installing in the sail panel, be sure you are right between the two clips so it will fasten back into the frame without modification. Here are my Hybrid Audio tweets mounted in a ball mount so they could be swiveled into the cab in my '17.
  13. Jul 19, 2018 at 11:40 AM
    Taco1.1
    Taco1.1 Well-Known Member
    2018 TRD Off-Road
    Debadged, Kenwood 9905 Head Unit, Tinted Windows, Remote Start
    What is the blue stuff you used to secure the tweeter? Did you just disconnect the factory tweeters? That's a pretty sweet setup.
  14. Jul 19, 2018 at 12:44 PM
    badhabit2break
    badhabit2break Well-Known Member
    Stephen
    Houston, TX
    2018 Red Tacoma TRD Off-Road
    Stock
    Looks like some kind of hot glue.
  15. Jul 20, 2018 at 12:13 PM
    2Loud
    There were no factory tweeters in that location so had to cut my own holes. I used a hole saw to cut the circle so that the body of the tweeter would sit in the sail panel. Then using a heat gun I warmed up the sail panel plastic to "flatten out" the plastic where the tweeter would sit (The sail panel is curved and needed to be flattened out). Then used hot glue to secure the tweet to the back of the sail panel.
  16. Jul 26, 2018 at 4:11 PM
    mrichard89
    mrichard89 Well-Known Member
    2017 tacoma trd pro
    stock for now
    Looks great. Do you know how big the diameter of the total tweeter mounting is, including the swivel mount? Trying to gauge the distance between the clips. Thanks!
  17. Jul 26, 2018 at 4:17 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    Did it in my 2nd Gen and it really made a difference in the Sound Stage.
    RippNU1 and RJ_MacReady like this.
  18. Jul 26, 2018 at 4:26 PM
    pinktaco808
    pinktaco808 Hot Steppa
  19. Jul 27, 2018 at 8:16 AM
    2Loud
    Different manufacturer tweeters are going to be different sizes. For my Hybrid Audio Clarus tweets I used a 54mm hole saw attached to a drill. The info packed with your tweeter (or manufacturer website) should provide dimensions on diameter needed to flush mount your tweet.
  20. Jul 27, 2018 at 1:13 PM
    mrichard89
    2017 tacoma trd pro
    stock for now
    Thanks. I measured and my tweeter should fit comfortably between the clips. My main question is how deep of a tweeter can you flush mount in the sail panel before you have to build it out. The tweeter that I will be installed is almost an inch deep, so I'm not sure if it will fit or not. Thanks.
