Anyone put on 'Leaf Spring Helpers'?
Discussion in '4 Cylinder' started by RockTock, Dec 24, 2013.
  1. Dec 24, 2013 at 9:18 PM
    RockTock
    RockTock [OP] Well-Known Member
    Colorado
    1999 2.4 4 Banger SR5
    I'd like to stiffen up the rear a bit for when I haul stuff around. I've read that the payload capacity is around 700lbs for a 2.7? Anyway, Ive seen leaf spring helpers pretty cheap, seems like a good work-around.
    I can't even say if there is handling issues, it seems pretty tight back there, just looking at the 2 or so leafs when Im under there makes me feel like its undersprung. Only issue is that this might lower the clearance.
    http://www.amazon.com/dp/B00029K01S...TF8&colid=1GBHK4ZYKUJ7P&coliid=I3JR4J0KMD6T5U
  2. Dec 24, 2013 at 9:37 PM
    toyodajeff
    toyodajeff Well-Known Member
    jeff
    06 reg cab sr5
    No I added some leafs to my pack though, you may be able to add some leafs to your pack off another vehicle and get minimal lift, also I saw where somebody uses some stock chevy bumpstops so when it does bottom out on them it isn't so rough.
  3. Dec 24, 2013 at 9:40 PM
    RockTock
    Colorado
    I don't think I want to mess with that myself. How much does a mechanic charge to install one more? (how many hours)?
  4. Dec 24, 2013 at 9:42 PM
    toyodajeff
    jeff
    06 reg cab sr5
    Maybe look at ride rite air bags or just do the helper springs. I used to have an aftermarket add a leaf to get a little lift and be able to carry more weight. It lost its strength pretty quick so I added some leafs out of an s10. I dont know how the helpers would be, never seen to many people use them on here.
  5. Dec 24, 2013 at 9:46 PM
    toyodajeff
    jeff
    06 reg cab sr5
    Also with air bags you could only pump them up when you were hauling stuff and the rest of the time have a smooth ride.
  6. Dec 24, 2013 at 9:47 PM
    RockTock
    Colorado
    Not sure if those helpers would even fit, thats why I'd like to know if someone has even used them on a 2wd taco.
    Yzkiley likes this.
  7. Dec 25, 2013 at 8:25 AM
    toyodajeff
    jeff
    06 reg cab sr5
  8. Dec 25, 2013 at 8:29 AM
    DJB1
    DJB1 Well-Known Member
    Dave
    SLC, UT
    2003 Regular Cab 4X4 5MT
    The Firestone Ride-Rite air bags would give you everything you need without making your truck ride more harsh. Plus it is a bolt-on kit so you could install them in your driveway instead of paying a shop.
  9. Dec 25, 2013 at 8:54 AM
    toyodajeff
    jeff
    06 reg cab sr5
    How long did it take for the stock springs to lose their arch.
  10. Mar 30, 2014 at 12:23 PM
    cwprice79
    cwprice79 New Member
    Atlanta
    08 Tacoma
    i put on some leaf spring helpers on my 2ws 08 tacoma, because i noticed a "thump" when I would be at a stop and take my foot of the brake. I picked up some from Oreillys for about $20. It's basically one "helper" for each side and some U-bolts. You install them upside down to stiffen the suspension. It helped stiffen my suspension and took care of the "thump" It only takes about 45 minutes and a 13 mm socket. I tighten mine one a month, to avoid them squeaking.
    hope this helps
  11. Mar 30, 2014 at 1:06 PM
    ecoterragaia
    ecoterragaia Everyone lives downstream.
    Central Virginia
    2006 RC 4X4 5 speed & 2021 4Runner SR5
    I put these on my '06 reg cab 4X4 about 3 years ago with 18,000 miles:
    http://www.hellwigproducts.com/products/load-control/ez-990/
    They've performed flawlessly, no sag from the stock 8 year old springs. The most weight I had in the back was about 1,500 lbs. (mistakenly loaded too many pavers and didn't realize it until I got home and weighed one). Also hauled many other loads close to 1,000 lbs with no issues.
  12. May 12, 2014 at 1:03 PM
    JJ48Nascar
    JJ48Nascar Member
    Josh
    08 Tacoma Prerunner V6 4.0L
    17 inch rims with Nitto Grappler tires. No lift kit
    You put them in the front of the axle or the rear of the axle to get rid of the thump noise?
    Thanks for the info!
  13. Jul 26, 2014 at 6:25 PM
    glhsracer
    glhsracer Life is good.
    Michigan
    08 4x4
    I too have the Hellwig Helper springs, haul around an 1100 lb truck camper (Travel Lite 690 FD) with no issues. There is no way the stock springs can carry the rated payload capacity, they will hit the bump stops long before then.
    SnackSalad likes this.
  14. Jul 28, 2014 at 5:03 PM
    Beaniam
    Beaniam Well-Known Member
    NJ
    1996 4x4, 2007 2wd, 2014 tundra
    Those 990 hellwigs do they come with new ubolts or are the factory Tacoma ubolts long enough to fit the helper spring in? I used to have the 550 single per side and I really couldn't tell they did anything to help so I sold them. Thinking about getting the 981's.
  15. Jul 28, 2014 at 6:07 PM
    ecoterragaia
    Central Virginia
    I reused the original ubolts per the instructions, though theres not much thread left. Many people will tell you to buy longer ones and double-nut them, which is unquestionably safer, but mine have been on since Feb. 2011 and 50,000 miles later have not loosened at all.
  16. Jul 29, 2014 at 3:25 AM
    Beaniam
    NJ
    Good to know. Ordered them off Amazon for $79 with free shipping.
  17. Feb 6, 2018 at 6:55 AM
    ShuggieTaco
    ShuggieTaco Well-Known Member
    2011 Tacoma
    1.5" level front
    I know this is an old thread and probably got this fixed by now. I used leaf spring clamps to stop the thump. Now I want to put helper springs to stiffen up the back. Did you or anyone end up putting the Helwigs? Wondering if the 550’s go in front or behind the axle. Top or bottom of leaf pack. I have the weeeeeaaak 3 leaf pack.
  18. Feb 7, 2018 at 10:39 AM
    OldandSlow
    OldandSlow Well-Known Member
    Andrew in Austin
    Austin, TX
    2015 Tacoma Access Cab - 2.7, 5 speed, 4x4
    Not much on mods - Leer 180, TRD wheels, Mobtown sliders, rear hitch, helper springs on the rear
    In your case, I'd probably replace the entire spring pack. That noise sounds like it could be caused by axle wrap.
    For my use, on a low mileage 2015, I installed a pair of Hellwig 981 helpers. Huge difference when hauling a load. Rides pretty good unloaded as well.
    The video below say a 991 series - but the install is pretty similar for Hellwig 981 helpers.
    https://www.youtube.com/watch?v=6nBIWQrfGko
    ecoterragaia likes this.
  19. Feb 10, 2018 at 7:54 AM
    Fordconvert
    Fordconvert Well-Known Member
    1997 Tacoma 5 lug low SAS
    SAS, Wallet lightening mod
    I’ve had a good experience with fat bob garages add a leafs, they didn’t flatten over time with a load.
  20. Feb 10, 2018 at 8:53 AM
    Frito
    Frito Well-Known Member
    Why would you rather have had air bags vs the Helwigs as stated in the video ?
