Anyone notice a chain hanging from their spare?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by hotrod53, Feb 8, 2016.
  1. Feb 8, 2016 at 5:21 PM
    hotrod53
    hotrod53 [OP] Well-Known Member
    Lynd
    Pittsburgh, PA
    ‘14 DCLB Sport, ‘18 TCH, ‘13 TCH
    Weathertech floor liners moded to hold OEM floor mats, weathertech vent visors, Toyota bed mat, LEER 100XL cap, hood gasket mod to stop whistling.
    i was under my DCLB '14 the other day and there is a chain hanging out of the middle of my spare tire. I tucked it up on to the top of the rim, when I checked the next day it was hanging down again. I'm assuming that is a part of the spare tire lift but my combined ownership of 195,000 miles with Tacomas, I've never taken a spare tire down. I assume this is normal??
  2. Feb 8, 2016 at 5:23 PM
    GHOST SHIP
    GHOST SHIP hates you.
    GHOST
    Normal. It's part of the tire retention setup. If you ever drop your spare, you'll see why it's there.
  3. Feb 8, 2016 at 5:28 PM
    doghair
    doghair Well-Known Member
    Phoenix
    2013 Single Cab 4x4
    Yeah, it's the lowering system. All is well. I winch mine down once a year or so to put air in the spare. Some year I may try flipping it to see if it will go on with the air nozzle pointing down so I don't have to keep lowering it.
  4. Feb 8, 2016 at 5:31 PM
    cthonia
    cthonia Member
    yes, the spare will fit normally under the vehicle with the valve stem pointing down. not sure why Toyota insists on putting it the wrong way from factory.
    Lord Helmet and doghair[QUOTED] like this.
  5. Feb 8, 2016 at 5:41 PM
    GHOST SHIP
    GHOST
    They did that to protect the valve stem from road debris. It can actually be damaged pretty easily and thus leak air making your spare useless. I know a few guys that have flipped their spares with no problems over several 10s of thousands of miles over various terrain, but just a heads up...
  6. Feb 8, 2016 at 5:49 PM
    doghair
    Phoenix
    2013 Single Cab 4x4
    That does make sense. It's really not a bad thing to remind myself how to do occasionally. The last thing I need is to try to figure that pulley shit out on the side of the freeway or some dark dirt road. Oh and don't trust the "checked spare pressure" check box from the dealer. Last time I got service I checked it on a whim when I got home and there was 17 pounds in it.
    Fenwick1993 likes this.
  7. Feb 8, 2016 at 5:53 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Yeah its normal, they changed from a cable to a chain.
  8. Feb 8, 2016 at 5:53 PM
    Stags863
    Stags863 Bye Felica!
    Florida
    2014 DCSB TRD Off Road 4x4
    - Bilstein 5100's set at 1.75 - 265/70/r17 Goodyear Wrangler Authorities - 6000k headlight and fog light bulbs - NiLight off road LED rear lights - Light bar mounted behind front bumper - White LEDs in dome, map, and sun visor - Tint (5% around / 35% front) - Universal 13 inch metal antenna - Beer bottle opener in bed - Organizer storage box in center console and glove compartment - Mounted MagLite to top of center console storage box - MGM grille - MGM rear bumper - CamLocker toolbox - Rubber floor mats - 2 USB and Cig lighter chargers in rear of center console - Headrest mounted iPad holders for rear seats
    It's normal but I'll just leave this here
    :worthless:
  9. Feb 8, 2016 at 6:41 PM
    studunk1
    studunk1 Well-Known Member
    stu
    jeff city, MO
    13 Access Cab sr5
    running boards, bug deflector, window deflectors, tail gate liner, bed mat
    I bot my 2013 in 2013, the first time I checked the air in the spare I flipped it. The factory valve does not high spot when the spare lies flat on the ground. When I put it back up I positioned the valve stem as close to the differential pumpkin as I could figuring that anything I ran over would contact the pumpkin first somewhat protecting the valve. Have had no problems doing a mild off roading in AZ.. It is much easier to check the spare tire pressure which I do 2x per year, figure flipped is a lesser evil than never checking the spare pressure, which I would not do if I had to lower it every time. Has anyone had a problem with the spare flipped?
  10. Feb 8, 2016 at 8:56 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    They changed from a chain then to a cable and now back to a chain.
    For you youngsters they were using a chain way back.... My first had a chain in 1980.
    Blkvoodoo likes this.
  11. Feb 8, 2016 at 10:25 PM
    shakerhood
    Southern Ohio
    I was just sticking with 2nd Gens, my 08 had a Cable and my 15 has a Chain, but your point is well taken too.
  12. Feb 9, 2016 at 5:38 AM
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    Not a bad idea to lower the spare at each oil change to check it's tire pressure. In my case, tools are under the bottom cushion of passenger rear seat.
  13. Feb 9, 2016 at 2:08 PM
    stbear
    stbear Well-Known Member
    SE PA
    2015 DCSB TRD Sport MGM
    My 02 had a cable and they recalled it and replaced it with a cable. Cable was rusting out. Must have got a deal with the frames. My 2015 has the cable.
  14. Feb 9, 2016 at 2:15 PM
    MQQSE
    MQQSE I take naps
    MooseMan
    Palmer, Alaska
    "Stitch" & "Sumbitch"
  15. Feb 9, 2016 at 2:27 PM
    pittim
    pittim mittip backwards
    Pennsyltucky
    Boujee Prius
    It’sa Lexus, boogie woogie woogie
    The mount--the brace between the frame rails that held the spare and cable up--that was rusting out too. One second you have a spare, the next it drops and you're dragging it behind, then the whole thing breaks off.
  16. Feb 9, 2016 at 4:45 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    Are you sure your 2015 has a cable and not a chain?
    shakerhood likes this.
  17. Feb 9, 2016 at 5:25 PM
    spp
    spp OC, Kalifornia
    OC California
    My 2015 has the chain while my 2010 had the cable.
