Anyone knows what the temperature of the catalytic converter should read on a 2002 toyota?
Discussion in '1st Gen. Tacomas (1995-2004)' started by sramirez1516, Jul 17, 2019.
  1. Jul 17, 2019 at 9:42 AM
    sramirez1516
    sramirez1516 [OP] Saul R.
    Saul
    2002 Toyota tacoma xtracab prerunner 2.7
    None
    I got the P0420 code yesterday and went ahead and bought an infrared thermometer. The front reads 480 and the rear about 380. I cleared the code last night and drove a good 15 miles, today another 5 and the CEL hasn't popped yet. Anyone has any idea of the average temperature?
  2. Jul 17, 2019 at 9:43 AM
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    600-1100 degrees depending on a ton of factors
    it's a 2002, likely the o2 sensor is just worn out. they last around ~120,000-150,000 miles
    it is difficult to get an accurate read of cat temp without a probe inside the exhaust pipe where your o2 bung is, so would not worry. your temp of 380 is likely just a bad reading
    as posted below, when running, 1100-1600 is normal means there is grime that can burn and the cat is burning it.
    I have a +267,000 mile 5vzfe from 1999 on the original cats, second set of a/f and o2 sensors, and it still passes Mass. emissions tests. these cats can last a long time (but not always) if not damaged and you never got or stayed with a rotten gas station over time. my weekend 100 mile trips also help get the temp up and burn any residuals. a lifetime of short trips is what kills cats
  3. Jul 17, 2019 at 9:46 AM
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    800- 1600 is normal
  4. Jul 17, 2019 at 2:59 PM
    djohn24
    djohn24 Well-Known Member
    Dennis
    Pa
    03 Double cab SR5 Tacoma 4x4
    If I am correct, your reading should be about 30- 100 degrees hotter at the rear of cat v.s. front for a normal working cat.
  5. Jul 4, 2024 at 10:01 PM
    roninmd
    roninmd Member
    Ronin
    2005 Tacoma 2.7L Standard Cab
    It's 97 degrees fahrenheit in Texas. I drove my '05 Taco 2.7L [2TRFE] at 60mph for 5 minutes. Coolant temp was 189. Catalyst Temp bank1 sensor 1 = 1375. Catalyst Temp bank1 sensor 2 - 1250.
  6. Jul 4, 2024 at 10:33 PM
    Currygoat
    Currygoat Well-Known Member
    Bay Area, California
    2002 Tacoma 2.4 5 Speed
    Rims, 4600 Bilsteins, K&N filter
    There are many things that can cause the P0420 trouble code... but its usually the O2 sensor.
    • Oxygen Sensor– The P0420 codes is thrown when the oxygen sensors on both sides of the exhaust have very similar readings. When the oxygen sensor is bad, it can cause a false reading and trigger the code. If the engine does not exhibit any of the decreased performance associated with a bad catalytic converter, it very well may be the oxygen sensor (if you haven’t noticed the performance loss yet).
    • Catalytic Converter– A catalytic converter is responsible for scrubbing out as much pollution as possible from the Tacoma’s exhaust. Over time, they can become clogged. Although, modern catalytic converters are supposed to last the life of most vehicles, it could be there is some underlying problem if it has clogged.
    • O2 Sensor Wiring– Over time, the oxygen sensor wiring can go bad. It is especially volatile since it is right next to the hot exhaust at all times. The downstream oxygen sensor wiring is especially volatile since it is so far from the ECM (more distance to travel.
    • Tacoma Timing– If your Tacoma is misfiring or the exhaust timing is off, this can affect the gasses that are actually going to the O2 sensors enough to cause the P0420 code to register.
    • Exhaust Leak– If there’s a noticeable exhaust leak coming from the vehicle it can change what the O2 sensors register enough to throw the P0420 code.
    • Engine Temp Sensor– If the computer doesn’t know what the engine temp is it’ll keep the fuel mixture rich. When the fuel mixture is rich, the exhaust the O2 sensors see will be out of range and it could throw the sensor.
  7. Jul 4, 2024 at 11:12 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    There's no temp sensing capability on these old systems, that's a diesel thing. The scan tool is taking a guess and throwing a number up there to fill in a blank pid
    Check for exhaust leaks upstream or near any oxygen sensors. Like black soot around a connection or gasket
    If no leaks are found it probably needs a new cat
