Anyone know if i can use FJ front differential in my prerunner?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jboudreaux1965, Aug 15, 2017.
  1. Aug 15, 2017 at 6:07 PM
    jboudreaux1965
    jboudreaux1965 [OP] Ragin Cajun Fan
    Joseph
    Hub City
    2023 TRD Sport
    I'm getting an engine for my 2006 prerunner out of a 2007 4WD FJ. Guy is willing to sell tge whole drivetrain. Any chance the front diff. And shafts etc will fit on a Tacoma?
    Thanks guys!
  2. Aug 15, 2017 at 6:37 PM
    jboudreaux1965
    Joseph
    Hub City
    2023 TRD Sport
    I Neg. a good deal so just bought the complete engine (ecu included in case I need it), auto trans. and tranfer case. If I end up not using the trans and t-case, I'm sure someone I know will. Front of drivetrain I still need some input???
  3. Aug 15, 2017 at 7:50 PM
    libagui
    libagui Well-Known Member
    Dominican Republic
    05 tacoma prerunner
    Bilsteins 5100 set at .085 Rear custom 1" add a leaf 265/70 R17 tires. Custom made aluminum tonneau cover with bike rack. 4x4 conversion with 4Runner transfer case.
    Yes, it will
  4. Aug 15, 2017 at 8:04 PM
    jboudreaux1965
    Joseph
    Hub City
    2023 TRD Sport
    thanks! I'm going to keep my TRD Sport rear, I assume gear ratio in FJ and Tacoma is the same?
  5. Aug 15, 2017 at 8:17 PM
    libagui
    Dominican Republic
    05 tacoma prerunner
    Gear ratio is 3.73 for all V6 engines en 4Runner, Tacoma and FJ cruiser.
  6. Aug 15, 2017 at 8:25 PM
    jboudreaux1965
    Joseph
    Hub City
    2023 TRD Sport
    Thanks! I guess back to negotiate tomorrow :)
    To be clear, I am still a Pre-Runner fan, but for the price, this may be a fun project. I can always go back, hehehehehe!
  7. Aug 15, 2017 at 8:27 PM
    libagui
    Dominican Republic
    05 tacoma prerunner
    And you can go with a 4x4 conversion :transformer:
  8. Aug 16, 2017 at 1:02 AM
    Muddinfun
    Muddinfun Well-Known Member
    So, if you can also get the spindles, hubs, half shafts, diff, and driveshafts, you hit the mother lode. You could have a 4wd in a weekend. Probably have to have some driveshaft work done.
  9. Aug 16, 2017 at 1:10 AM
    bullaculla
    bullaculla IKA fabrications
    Da big big island!
    2013 MGM DCSB Tacoma 4X4 TRD Off Road
    All pro 3 link SAS kit, Diamond axle, kings on 37" MTR/K
    Trans crossmember is different on prerunners. Not quite that easy of a swap.
    Pabloeeto likes this.
  10. Aug 16, 2017 at 2:02 AM
    jowybyo
    jowybyo Well-Known Member
    Joe
    Baltimore, MD
    '14 MGM DCSB Postrunner 4wd Conversion, Debadged
    It is different but it's still pretty easy.
  11. Aug 16, 2017 at 2:39 AM
    bullaculla
    Da big big island!
    Yes, If you are a fabricator like you are. Just need a make and weld on a custom plate. Just trying to give a heads up that it's not a simple bolt on swap.
  12. Aug 16, 2017 at 3:55 AM
    jowybyo
    Joe
    Baltimore, MD
    True statements. I assume if he's going to tackle swapping the entire drive train, that modifying the cross member probably isn't a huge issue for him. Maybe that's a bad assumption.
    Also, when you are done with your SAS, come do mine. I have no idea where to start. :D
    bullaculla[QUOTED] likes this.
  13. Aug 16, 2017 at 7:25 AM
    Justinlhc
    Justinlhc Not looking for a relationship
    Anybody find it odd that the PreRunner frame is somehow slightly different than the 4wd frame? This seems like a waste of money to produce different frames for an identical truck minus the front drivetrain and TC.
    It's the frame that's slightly different, right?
  14. Aug 16, 2017 at 7:30 AM
    Paul123
    Paul123 Web-Wheeler
    Paul
    Reno
    2014 TRDOR pyrite mica, 3" lift 33's, 4.56’s
    The frame is the same, it's just the crossmember that's different. The 4x4 crossmember would just have an added section to support the tcase if I had to guess, I've never looked at a prerunner frame to see what the difference is though.
  15. Aug 16, 2017 at 7:36 AM
    Justinlhc
    I remember reading a conversion thread where a 4wd crossmember was used and it still didn't line up properly.
    If it's just the crossmember than it would be as easy as using the crossmember from a 4wd truck.
  16. Aug 16, 2017 at 8:08 AM
    jowybyo
    Joe
    Baltimore, MD
    No, the frame is different. The mounts for the cross member hang lower on the 4x4. Most ppl mod the cross member itself cause it's easier than modifying the frame. Why they did this, I don't know. I also find it odd that the transmissions are different. They could have easily made due with only the 4x4 version and changed the tail piece. Instead the output shaft is different too. It's odd.
  17. Aug 16, 2017 at 8:18 AM
    Justinlhc
  18. Aug 16, 2017 at 10:27 AM
    bullaculla
    Da big big island!
    Yeah, the prerunner crossmember doesn't hang down as low and is a little to the rear. The nice thing is youll have a little more clearance than a 4x4 frame. This is what my buddy Mike did. But he's also a machinist and a welder so...
  19. Aug 16, 2017 at 11:19 AM
    bullaculla
    Da big big island!
    :rofl: it's pretty much done. Just gotta button up a few more things. Just make sure you have everything before you start chopping up your truck. I cut off my IFS way too early and took way too long waiting on the right parts. It's been over a year doing everything myself with help from some friends all in my garage.
    SASed mall crawler yo! Still haven't setup the hydro bumps. Can't wheel it yet...
    04TacoRunner and 98tacoma27 like this.
  20. Aug 16, 2017 at 11:29 AM
    libagui
    Dominican Republic
    05 tacoma prerunner
    This is what I did
    B0823272-6155-4569-8D78-5917EE993AE1-2021-000001FF9A33C904.jpg 688E796C-88C3-4A3C-B1A0-671B346FC29D-2021-000001FF8CEF6AC6.jpg C016EE25-6586-431C-AD00-ED092D918699-2021-000001FFC5C53D5F.jpg
