Anyone know how to remove tpms led bulb
Discussion in 'Wheels & Tires' started by DARK TRD, Apr 10, 2010.
  1. Apr 10, 2010 at 8:20 AM
    DARK TRD
    DARK TRD [OP] Well-Known Member
    Bartlett,IL
    All Black TRD Sport
    ez lift 3inch plus 1 inch block custom flat black trd black stickers same style as stock black badges from toyota black headlights tinted windows satoshi grille with grillcraft grill vinyl tinted tail lights
    my tpms light is on i sold the sensors with the wheels and i dont want to buy new ones any idea how to just pull the bulb
  2. Apr 10, 2010 at 8:30 AM
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    It's probably not a bulb but an LED. I would assume you would have to pull the gauge cluster and open it up.
  3. Apr 10, 2010 at 9:45 AM
    DARK TRD
    Bartlett,IL
    All Black TRD Sport
    has anyone done this that could give me a clue how to do it
  4. Apr 10, 2010 at 10:08 AM
    howasniper
    howasniper New Member
    Los Angeles
    '07 Tacoma 6" Pro Comp Lift
    6" Pro Comp Suspension Lift 35" Tires
    It is an L.E.D., so there is not a bulb to pull out.
    I just disassembled the Instrument cluster and put
    a small piece of electrical tape on the backside of the
    Tire pressure graphic. Essentially blocking the L.E.D.
    light from showing.
  5. Apr 10, 2010 at 10:12 AM
    rmb_crew
    rmb_crew My other ride has 18,400HP!!!!!!
    Jacksonville, FL 30.243103, -81.591007‎
    2010 F150 XLT SuperCrew 4X4
    Access larado tonneau, magnaflow exhaust
    I have completely removed it. You have to open the cluster up and than take everything apart so your looking at the circuit board and than just take a soldering iron to each side of it and pull up with a pair of tweezers and it should come right off.
  6. Apr 10, 2010 at 10:23 AM
    yosh2000
    yosh2000 Well-Known Member
    CO
    '17 Tundra CM 5.7
    check out this thread on how to remove it.
    if you want change the color of your dash, now would be a good time to do it as well! get LEDs from the place linked in my cluster thread in my sig
  7. Apr 10, 2010 at 11:53 AM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    BSP '10 4x4 TRD Off-Road DC
    See build thread in signature
  8. Apr 10, 2010 at 1:50 PM
    JKD
    JKD Well-Known Member
    Can't you just disconnect the TPMS ECU?
  9. Apr 17, 2010 at 12:43 AM
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    Welcome to TW. Your solution is actually a very good one. Does the light bleed through, or is it absolutely not visible anymore?
    I don't think so. Not without throwing a MIL condition. Although it may be possible to disable the Tire Pressure Warning Antenna and Receiver and achieve the same goal.
  10. Apr 17, 2010 at 12:46 AM
    yosh2000
    CO
    '17 Tundra CM 5.7
    if your going to go through all the trouble of taking the cluster apart...might as well just do it right and remove the LED!! the solution of using tape is actually not a good solution at all...its a jerry rigged solution when two more steps would completely remove the LED!!
  11. Apr 17, 2010 at 12:54 AM
    Crom
    Nick
    San Diego, CA
    Millions
    Right. But what if you want to reverse the mod to sell the truck? Perhaps soldering the LED back in may prove difficult? Pulling the tape may be a lot easier.
    Dmil74 likes this.
  12. Apr 17, 2010 at 9:16 AM
    yosh2000
    CO
    '17 Tundra CM 5.7
    your still going to have to remove the cluster, remove the front plastic, remove the needles, remove the faceplate, remove the tape, reinstall faceplace, reinstall needles, reinstall front plastic, reinstall cluster....
    if your doing all that, soldering one little LED should be no big deal...IMHO...;)
    but to each their own...i just like to do stuff right and complete on my truck...
  13. Apr 21, 2010 at 1:43 PM
    howasniper
    Los Angeles
    No light bleed through at all. It's a permanent But reversable fix without taking a soldering iron to the LED to remove it.
    Dmil74 and Taco_Daniel like this.
  14. Apr 21, 2010 at 2:08 PM
    c0astie31
    c0astie31 TACO SUPREME
    Dennis
    Long Island ny
    2011 4Runner Trail Edition
    A LOT
    i put a piece of electrical tape over it, works perfect
  15. Apr 21, 2010 at 2:10 PM
    ShadowFalken
    ShadowFalken Well-Known Member
    Jim
    Maryland
    10 Off Road
    Raptor stainless bars, Wet Okole covers, RollBak bed cover, PopNLock, Redline hood struts, XM radio factory kit
    I am not one that likes a lot of gubment in my life. That said, your are defeating a Federal safety system that is required on 2008 and up vehicles. Result of the Tread Act of 2000. There is liability in there for those that care.
    Lots of ways to defeat systems, lots of lawyers too. Dangit.
    Just a thought, not being the MOD police.
  16. Apr 21, 2010 at 2:17 PM
    Crom
    Nick
    San Diego, CA
    Millions
    x2 That is good information! I didn't know that. Thanks!!!:)
  17. Apr 21, 2010 at 2:38 PM
    Bryan07sport
    Bryan07sport Well-Known Member
    Bryan
    Smyrna, Delaware
    '22 TRD off-road.
    Bilstein 6112/5100. Icon progressive AAL. Overland Torque Tune. Toyota roof rack. Toyota bed extender. Gator trifold tonneau. Bora .75" wheel spacers. 265/75r16 tires.
    I dont' get why everybody hates it so much. It serves a good purpose. Why not just check your air pressure when the light comes on and add air as needed? takes 5 mins, and that includes lowering the spare. I absolutely love having it. Every so often mine will come on, and I check the tires, theres one a few pounds low, and I throw some air in it. Keeps my fuel mileage high, and my treadlife long! my .02
  18. Apr 21, 2010 at 3:08 PM
    snowgod06
    snowgod06 UG legend wannabe
    Rob
    A farm field, OREGON
    06 Access Cab
    crap bolted and welded together....
    theres a thread somewhere here i think or on CT i read where you can just cut the power wire for it, when you do that just add some connectors to it and if you want to hook it back up just plug the ends back together. I was going to do this when i couldnt get my light off for about 3 months till it decided to just turn off by itself one day.
