Anyone Install a Second USB Port That Can Play Music?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Tunngavik, Sep 16, 2018.
  1. Sep 16, 2018 at 7:50 AM
    Tunngavik
    Tunngavik [OP] Well-Known Member
    Alberta, Canada
    2018 TRD Off-Road Access Cab 6 speed manual
    KC-HiLites Fog Lamps, Kicker speaker and tweeter upgrade, USB in center console, Power tailgate lock, Soundproofing, 32" lightbar
    I'm looking to install a second USB port in the center console box. I installed one in my 2nd gen following some instructions I found on Tacomaworld but after searching in the 3rd gen forum, haven't found a similar thread from someone who did it with their truck.
    Key point is the head unit has changed between my model of 2nd gen and 3rd gen trucks.
    It's nice not having your USB flash drive sticking out of the dash, and instead hidden in a port installed in an out of sight area.
    And yes - I already have one of those mini flash drives.
    Has anyone done this before?
  2. Sep 16, 2018 at 8:16 AM
    Norsemanvike
    Norsemanvike Well-Known Member
    Escondido, CA
    '18 Sport 4x4, DblCb, ShBd, BBP
    I would be curious about this too.
  3. Sep 16, 2018 at 8:17 AM
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    Beef Nachos and opteron like this.
  4. Sep 16, 2018 at 10:46 AM
    metwo
    metwo Member
    Entune's QNX supports two USB ports it appears. Add a 2+port USB hub to the existing USB port. Add your USB drive to port one of the USB hub. And another USB drive / phone to port two of the USB hub.
    Tullie D likes this.
  5. Sep 16, 2018 at 10:58 AM
    apoteker
    apoteker Well-Known Member
    2012 DCSB O/R debadged
    JBL/Entune Touchscreen Navigation with speed sensor override mod, JBL Speaker refit, debadged, chime removed, overhead led mod, switch LED mod, rear cupholder LED mod, ImMrYo Rear-View Mirror Lift Bracket #339, Custom Cobra CB install, Iggy Switch panel, OEM Katzkin leather seats, Seat heaters, Illuminated 4runner 4WD switch, 4runner side mirrors (heated, turnsignals, puddle lamps), husky x-act fit floor mats, climate control knob upgrade, air injection pump filter mod, underhood LED light mod, KB Voodoo bike bar
    What instructions did you use for 2nd gen?
  6. Sep 16, 2018 at 7:44 PM
    Tunngavik
    Alberta, Canada
    There is a super thread about installing a 2014 head unit in 2005 - 2011 trucks here: https://www.tacomaworld.com/threads...nfo-part-numbers.318616/page-15#post-10439195
    Basically you take out the head unit and then.
    1. Plug in one of these into the appropriate plug at the back of the head unit : https://www.amazon.com/dp/B00XKUVJQG?psc=1&redirect=true&ref_=oh_aui_detailpage_o03_s00
    2. Install a USB port splitter that connects to the above in a space behind the dash: https://www.amazon.com/C2G-Cables-G...d=1537150593&sr=1-3&keywords=two+port+usb+hub
    3. Install one of these to replace the USB/Aux port in the dash (you can find more OEM looking ones if you look hard enough): https://www.amazon.com/Toyota-VIGO-...F8&qid=1537150343&sr=1-17&keywords=tacoma+usb
    4. Connect #3 to #2
    5. Buy a male - female USB cable and connect it to #2 and run the other end to the center console (where you want access): https://www.amazon.com/AmazonBasics...0823&sr=8-3&keywords=male+to+female+usb+cable
    And you are done. I'm not sure what the back of the 3rd Gen head unit looks like and if something like, or the same as, the plug in #1 would work.
  7. Sep 16, 2018 at 8:27 PM
    Tunngavik
    Alberta, Canada
  8. Nov 4, 2018 at 5:31 PM
    helix66
    helix66 Well-Known Member
    DPRC
    2017 DclB TRDor MgM
    ProGrille,MesoStuff,Tinted,AllPro sliders, RCI ALL skids, BAMF diff skid, KDmaxPro tune, Demello bumper, Warn evo10s, BD s8 & squadrons, Accutune UCAs, Fox 2.5pes, Eibach & Deaver
    Anyone follow through on this?
    I'm looking to do the exact same thing, run the second to the console and would like to have it all hidden.
    I still use the one under the radio.
  9. Nov 4, 2018 at 6:20 PM
    Tunngavik
    Alberta, Canada
    I'm working on it but won't have the tools and shop space to do it until the X-mas holidays.
    I plan on doing what I did with my 2010 as described in Post #6 above. The only part I would change is from Part 1. (Axxess Ax-Toyusb) in that post to the Metra AX-TOYUSB USB Port Cable
    helix66[QUOTED] likes this.
  10. Nov 4, 2018 at 6:28 PM
    helix66
    DPRC
    2017 DclB TRDor MgM
    This looks along the same lines as well....
    https://www.tacomaworld.com/threads/plug-n-play-harness-to-relocate-usb-port.510714/
    Tunngavik[QUOTED][OP] likes this.
  11. Nov 4, 2018 at 6:32 PM
    Tunngavik
    Alberta, Canada
  12. Nov 4, 2018 at 6:51 PM
    helix66
    DPRC
    2017 DclB TRDor MgM
    It looks like a crap load of connections to have stuffed behind the dash....which IMO is a shitty way of doing it, but it does do it.
    I think that you have to get some kind of small hub...I thought that there were some cables that would do multiple audio connections.
    I still want the audio port at the oem location in addition to the console.
    And further into the thread another guy bought what looks like an extension of the stock...where you'd remove the OEM usb/3.5mm and plug directly into it and stuff that behind the dash....but then you lose the original location on the dash.
  13. Aug 13, 2019 at 11:54 PM
    Beef Nachos
    Beef Nachos Here for a good time, not a long time
    Dallas/Ft. Worth
    2017 SR5 DCSB 4x4
  14. Aug 14, 2019 at 6:24 AM
    JoeCOVA
    Joe
    Colorado Springs
    I didn’t. Never heard of putting a 3 amp fuse in. Just using the stock fuse.
    The fuse would defeat the purpose of the blue sea since it’s 4.8 amp charger
    Beef Nachos[QUOTED] likes this.
  15. Aug 14, 2019 at 6:57 AM
    Beef Nachos
    Dallas/Ft. Worth
    2017 SR5 DCSB 4x4
    Thanks!
  16. Aug 14, 2019 at 11:38 AM
    JoeCOVA
    Joe
    Colorado Springs
    Ya so the "cig lighter" uses a proprietary connector, I cut that off and crimped on normal female disconnect connectors. The proprietary connector is two different sizes for positive and negative so just cut it off and discard. You could do what that post says but I feel like thats more work.
  17. Aug 14, 2019 at 12:12 PM
    Beef Nachos
    Dallas/Ft. Worth
    2017 SR5 DCSB 4x4
    “Normal” connectors... I’m new to everything electrical, so part numbers or any extra help would be awesome
