Anyone here use Rust Kutter on their trucks?
Discussion in '1st Gen. Tacomas (1995-2004)' started by ztwatson, May 17, 2022.
  1. May 17, 2022 at 4:10 PM
    ztwatson
    ztwatson [OP] Well-Known Member
    Milwaukee, WI
    2004 Tacoma TRD Xtra Cab
    This is what my Rear Diff looks like before and after two coats of Rust Kutter (phosphoric acid). Curious if people rinse the excess product off or not? I've seen some mention of both. I'm not sure if that will appear different after rinsing. I'll be replacing the springs shocks etc later so I'm just getting this main section coated for now.
  2. May 18, 2022 at 7:39 AM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    Myself it might be the pictures I can not see a major difference.
    Just what is this product supposed to do? How expensive is it?
  3. May 18, 2022 at 8:00 AM
    ztwatson
    Milwaukee, WI
    Rust Kutter is the brand but it is a bottle of Phosphoric Acid, the primary component in most rust converters/encapsulators. It was like $20 for a quart spray bottle. Went through the whole laundry list of options for dealing with rust and it seemed that a combination of phosphoric acid followed up with linseed oil would be my best bet for preserving the rusty parts. I've been on the fence about whether or not I want to paint over rust/converted rust.
    This video was helpful
    https://www.youtube.com/watch?v=tu1n1POMg98&t=692s&ab_channel=RepairGeek
  4. May 18, 2022 at 9:35 AM
    Bivouac
    I will stick with blasting it is easier for me.
    Then primer and paint
  5. May 18, 2022 at 10:42 AM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    :thumbsup:Coroseal and Rust-Oleum:thumbsup:
    alarka likes this.
  6. May 18, 2022 at 11:44 AM
    alarka
    alarka Well-Known Member
    WNC/SE GA
    2k X cab 3.4 5spd
    King ex travel, JBA UCA’s, All Pro Springs/shackles, Locked, all new poly bushings & rack, SS brake & clutch lines, ext bumps for starters.
    ^^^THIS X2^^^
