Anyone have experience with a Weathertech bug deflector?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by hotrod53, Feb 26, 2021.
  1. Feb 26, 2021 at 3:59 PM
    hotrod53
    hotrod53 [OP] Well-Known Member
    Lynd
    Pittsburgh, PA
    ‘14 DCLB Sport, ‘18 TCH, ‘13 TCH
    Weathertech floor liners moded to hold OEM floor mats, weathertech vent visors, Toyota bed mat, LEER 100XL cap, hood gasket mod to stop whistling.
    I have a brand new still in the box Weathertech bug deflector that I’ve been hesitant to install. This deflector fastens under the hood and wraps through the front hood gap.
    Does anyone have experience with this unit? Does it scrape the grill shell? Does it rub the edge of the hood? Does that tape that they provide hold up in protecting the hood and staying in place? Does it make any wind noise?
    I’ve had a deflector on my last 2 Tacoma’s and I loved them, but they were stood off with metal brackets.
  2. Feb 26, 2021 at 4:47 PM
    Haole Toy
    Haole Toy Well-Known Member
    Mauna Kea, AZ
    '21 SR 4x4
    I have the AVS version, I am not sure how similar they are, but mine doesn't rub anything. I did have to get a few longer connector rivets for the outer holes to pull it up tight to the under side.
  3. Feb 26, 2021 at 4:55 PM
    hotrod53
    Lynd
    Pittsburgh, PA
    Does the AVS fit tight like this?
  4. Feb 26, 2021 at 5:12 PM
    Haole Toy
    Mauna Kea, AZ
    '21 SR 4x4
    Yes, but I have an '06. It looks the same though. It sits ahead of the front of the hood
    hotrod53[OP] likes this.
  5. Feb 26, 2021 at 5:18 PM
    ABA180
    ABA180 It burns when I pee....
    East Bridgewater MA
    Pioneer CD, Megaloud/JBL amps, Rockford/Polk speakers.
    I also have the same style AVS..they're made by the same people ultimately. Zero issues in 8 years.
  6. Feb 27, 2021 at 7:37 AM
    JRYTacoma
    JRYTacoma Well-Known Member
    British Columbia
    2012 Tacoma Sr5 Spruce Mica
    I bought a 45,000 KM truck that had a deflector. Pulled it within the first day to find out it had already caused permanent paint damage to the hood.
    Each mounting point had foam but rocks and debris collected / got caught underneath the foam and made a mess.
    I would advise against it if you like your paint. Functionally, it probably works.
    saweetlou and asuchemist like this.
  7. Feb 27, 2021 at 9:14 AM
    AllTacosFloat
    AllTacosFloat If yours sank you’re entitled to compensation
    Boston ish
    Has lockers and a skewp
    I'd say no way, it will rub the paint where it touches and most importantly they do not work. If they did every vehicle would come with them or a fin to prevent it. If you like the look then rock on. It's your truck, make it what you want it to look like.
  8. Feb 27, 2021 at 9:16 AM
    asuchemist
    asuchemist My Hamstrings Hurt!
    South South Dirty Gilbert
    11' TRD Sport V6, 23' TRD Pro 4Runner, 23' Tacoma TRD Pro
    NONE
    OEM one removed at 33k miles. Rubbed paint down to the metal. Also deflected rocks straight to windshield.
  9. Feb 27, 2021 at 9:28 AM
    ace96
    ace96 Well-Known Member
    Western KY
    '11 SWB DC TRD SPORT
    AVS bug deflector, Weathertech digital fit floor mats, TRD skid plate w/ Sockmonkey decal, SOS Cocept sliders w/ Line-x, Pioneer 3500, Hybrid Audio Technology Mirus 6X9s & 6.5s, back up cam mod, Wet Okoles-front & rear, TRD exhaust, 17X9 XD Spy w/ Falken Wildpeaks, Avid light bar
    That is not same deflector OP is referring too. That is the OEM which is straight garbage. The Weathertech or AVS one does not rub. I’ve had one on my truck for nearly 100k miles. No issues.
    They do work in protecting the leading edge of the hood which is the whole point.
  10. Feb 27, 2021 at 9:32 AM
    AllTacosFloat
    Boston ish
    I had the AVS one and it did rub the paint... Over 100k. Also when opening the hood it gives a little less space to initially pop the hood. I have fat fingers. Mine was partially removed for me on a job site when some caution tape looped around it and the barrels were moved. Popped it off and wouldn't do it again.
    ace96 likes this.
  11. Feb 27, 2021 at 9:47 AM
    ace96
    Western KY
    did it tube the paint or did the barrels cause it to rub paint?
  12. Feb 27, 2021 at 9:52 AM
    blu92in99
    blu92in99 Hates everyone, equally
    Elk Grove, Ca
    This has been my experience as well, on various trucks and brands of hood deflector.
    If you want to protect the hood, look into a "clear bra" instead.
  13. Feb 27, 2021 at 9:53 AM
    spitdog
    spitdog Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
    I had a bug deflector on my first gen for 17 years. It came with the truck and honestly I don’t think I ever needed it. It only caused damage to the paint where 2 tabs touched the hood for support. My opinion, a bug deflector is a no go. It’s just add on junk people do because they can.
    asuchemist likes this.
  14. Feb 27, 2021 at 10:03 AM
    AllTacosFloat
    Boston ish
    It was yanked from just the driver side and broke 2 tabs... The rub was constant and got a little chip in the paint on that side.I assume from it being removed. Either way I drive thru stuff where I don't need anything removable like that but to each their own. I liked mine until I didn't. If anybody is so sure yours didn't hurt the paint go remove it check and report back please. The tape is cheap.
    ace96[QUOTED] likes this.
  15. Feb 27, 2021 at 10:35 AM
    Taco'09
    Taco'09 Well-Known Member
    I have it on my '14 and put it on a short time after buying the truck new. I love it and would replace it with the same if need be.
