Anyone got any info on cutting 1/2 inch thick rubber mat?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by undermoneyed, Jul 1, 2012.
  1. Jul 1, 2012 at 2:29 PM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    blowtorch. :devil:
    Kidding. Do NOT use a blowtorch. :p
  2. Jul 1, 2012 at 3:12 PM
    stewartx
    stewartx Well-Known Member
    Huntsville AL
    2012 Silver DC SB TRD Off-Road
    Winch, front hitch, step bars, bed extender, bed step, gull-wing toolbox, tailgate lock, security system, cb radio, etc.
    If it were soft rubber, common sense suggests he wouldn't be considering power tools to cut it.
    I've used various bandsaws for decades. The gaps for the blades are significantly smaller than the 1/2" thickness of rubber, thus could not likely do as you describe (pull a hand into the blade) -soft rubber wouldn't pull that hard and hard rubber wouldn't fit through the gap to pull at all.
  3. Jul 1, 2012 at 3:56 PM
    undermoneyed
    undermoneyed [OP] aka Alley Opp,
    Mark
    B.C., Canada
    Tacoma TRD
    totally stock
    Thanks for the input guys. I'll get back to you on what worked.
    Mark
  4. Jul 1, 2012 at 4:02 PM
    Rsoxfan1
    Rsoxfan1 Well-Known Member
    Mass
    2012 DCSB TRD Sport 4x4
    Tin snips
  5. Jul 1, 2012 at 4:04 PM
    dbratcher
    dbratcher Active Member
    N AL
    07 SWB DCLB Sport
    I used a utility knife and a straight edge to cut my bed mat out. It was half inch mat used in fitness centers and weight rooms. The utility knife cuts right through it. Bending the mat like troy28 said helps and i let mine get good and hot out in the sun and it cut almost in one pass.
  6. Jul 1, 2012 at 4:33 PM
    davelac
    davelac Well-Known Member
    Capital Region
    2011 SR5
    Yes - this is the technique I used with my mats from Tractor Supply. I used a heavy duty utility knife and changed blades every 5 or 6 cuts. IMO, this gives the cleanest edge with the least amount of mess. Cut on a sheet of scrap plywood.
  7. Jul 1, 2012 at 4:40 PM
    joes06tacoma
    Joe
    Central Coast, CA
    I did it this way. It sucked and took forever, but it did work.
  8. Jul 1, 2012 at 5:10 PM
    lj973gm
    lj973gm Sold it, dont miss it yet.
    Ohio
    06 DCSB 4wd
    Don't use a jig saw. I tried cutting my 5/8" thick mat with one and clamped a metal straight edge to the mat to follow for a nice straight line.
    Well that straight line did not happen. After the blade warms up due to friction with the mat it is not strong enough to stay straight. On a factory or other thin mat it will likely work but not on any thing over a 1/4" thick.
    So on the top of the mat it looked good but after about 12" of cutting the blade starting cutting at a 45 degree angle.
    Was pissed since I did not get a perfect fitting mat and had to cut off the fucked up part.
    Ended up just using a box cutter with a lot of blades and some patience. Dont forget the lube, this process is more delicate than anal.
  9. Jul 1, 2012 at 5:16 PM
    aptech
    aptech Jetfixer
    houston
    10 dc offroad
    toy teccoil overs 2.5 lift.600lb springs, allpro expedition leaf pack. cbi hybrid bumper, cbi slider,cbi rear bumper swing arm, roof rack ghostflames, sport hood, tsb steering, trd cai, red map lights, derp works custom platform for bed. backup cam any time mod, fog light any time mod. bed light mod. 400watt inverter mod. 2857516 dura tracs. beach sand intsall and a lot more shite
    a hydraulic sheer at your buddy's fab shop
  10. Jul 1, 2012 at 5:29 PM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    might try a dremel with a pin router.
  11. Jul 1, 2012 at 5:34 PM
    Executive
    Executive Conservative
    Peabody, Massachusetts
    2012 DCLB TRD Sport
  12. Jul 1, 2012 at 5:36 PM
    TennesseeFan76
    TennesseeFan76 I intend to live forever. So far, so good.
    Phill Goodfactor
    Georgia
    2005 PreRunner DCLB
    3 inch lift, Debadged, 5% Tint, Custom Stereo, BHLM, Fog Light Mod, Sockmonkey Decals, OEM Bedmat, Plasti Dip Front Valence, Slims 6K HIDs (thanks goes to TheGloryFades), Hyper yellow fog lights, LED interior lights, Satoshi Grille with FJ Emblem, Pro Comp lights behind Satoshi, FatMat
    Carpet Knife
  13. Jul 1, 2012 at 5:44 PM
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Armour: All-Pro Skid plates - IFS, transmission, and transfer case. Pelfreybilt rear standard plate bumper, Metal Tech Sliders w/ kickout and dimple die filler plates. Front Suspension: OME 885 + NitroCharger 9000 shocks + 1/2" spacers for a 3" lift. Superbumps replacing stock bumpstops. Camburg ball joint UCA SS braid brake lines Future: ADS Extended length, extended length UCA BJ to increase droop capability Rear Suspension: All-Pro Expedition rear leafs, Walker Evans 27" rear shocks, extended rear brake lines (Wheelers Offroad), U -bolt flip kit, rear Timbren bumpstops. Future: Hammer Hangers, Shock relocate, ADS 12" or 14" shock. Interior: Weatherteck floor liners - front, Wet Okoles- front, ScanGauge, LED interior & map lights. Power moonroof. Exterior: Raider Cobra canopy, retrofit headlight by Insight, LED bulbs all around, modified flasher unit for LEDs. Rear diff breather mod. Front diff vibe problem, driver's side needle bearing replaced with ECGS bushing. yet to install: HID Blazer Fog Retrofit, LED Flood & Spot, + switches, fuse panel. swaybar relocate blocks (build my own)
    use dish soap rather than hydrocarbon based lube for blade to cut neatly through rubber type products. Works slick.
  14. Jul 1, 2012 at 5:46 PM
    AndrewFalk
    AndrewFalk Science!
    The North East
    2010 5 speed 5 lug
    Bandsaw with a fence setup for straight cuts. Keep wax or some kind of lube for the blade on hand.
  15. Jul 1, 2012 at 6:02 PM
    #35
    undermoneyed
    Mark
    B.C., Canada
    Tacoma TRD
    totally stock
    I tried the circular saw first, the smell of burning rubber was too much. Tried the jig saw next, didn't make a dent. Tried the Olfa knife, took about 5 cuts to get through. I cut about 3 to 5 inches at a time. Took about 20 mins to get the job done. Thanks for all the advice guys.
    Mark
  16. Jul 1, 2012 at 6:09 PM
    #36
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    I just did the same with a horse stall mat from tractor supply 1 inch thick. Used a jig saw with a 10 tooth per inch wood blade. it cut great staight smooth cuts. Take your time and let the blade cut.
    Just a not: The 1 inch thick mat is heavy as hell.
  17. Jul 1, 2012 at 6:15 PM
    #37
    undermoneyed
    Mark
    B.C., Canada
    Tacoma TRD
    totally stock
    I tried the circular saw, the smell of burning rubber was too much and progress was slow. Tried the jig saw, didn't make a dent. The Olfa knife did a good job, it was a little slow, took me about 20 minutes. Thanks for all the advice guys.
    Mark
  18. Jul 1, 2012 at 6:30 PM
    #38
    SOSHeloPilot
    SOSHeloPilot My 1st Muscle Car
    S.E USA & S.E. Asia too
    2024 4Runner SR5
    Missing My Last Tacoma --- Had 11 Toyota trucks in the past and many other Toyota cars too.
    I have 2 mats that I got at Tractor Supply and they are about 3/4" thick and super heavy and I plan to cut them with a "knife blade" on my jig saw.
    Not every store those blades, but they work great for things like this. Good luck and keep us posted on how you cut it and your results.
  19. Jul 1, 2012 at 6:34 PM
    #39
    medic2230
    Murph
    Bama! Roll Tide
    That isn't a rotary olfa is it?
  20. Jul 1, 2012 at 7:20 PM
    #40
    undermoneyed
    Mark
    B.C., Canada
    Tacoma TRD
    totally stock
    I tried getting a rotary Olfa, those Swedes are slow coming up with one. Maybe next time.
    Mark
