Anyone familiar with Tacoma TX Pro Baja
Discussion in '2nd Gen. Tacomas (2005-2015)' started by NorCal Adventures, May 31, 2020.
  1. May 31, 2020 at 8:37 PM
    NorCal Adventures
    NorCal Adventures [OP] Member
    Scott
    Looking at a Tacoma
    I am in the market for a Tacoma Double Cab 4x4 SB. Pretty much impossible to find in NorCal. I did come across one that almost looks like a TX Pro Baja body style and trim. Anyone familiar with this trim package and is it better or worse than a Trd off road SB.
  2. May 31, 2020 at 8:38 PM
    Bishop84
    Bishop84 Well-Known Member
    If it red coil springs in the front, its a Pro and its far better than other Tacoma models.
    Does it have graphics on the side of the bed?
  3. Jun 1, 2020 at 4:16 AM
    12taco12
    12taco12 Well-Known Member
    rochester NY
    2012 TX Pro
    Billy 5100s OME 886 Billy remote resi 5125 rear General hd packs TImbren superbumps/flipkit Pelfrey steel full hoop front SOS bolt on sliders Baja squadron amber fogs Baja 20" bar Aux fuse panel and switches custom 10 sub box double din
    Wheels will be the beadlock wheels, will have red coils in the front, sit about 1" higher than the offroad, will have diff lock, think also had the pro headlights and bed graphics. or you can get the vin plug it in and it will tell you if its a truly a pro or not. also pictures always help us
  4. Jun 1, 2020 at 6:33 AM
    Bajajohn
    Bajajohn New Member
    Hockessin De
    2102 Tacoma TRD Baja
    I own a 2012 TRD Baja. It is definitely better equipped than any other model of Taco in 2012-13 model year. It was a $5k upgrade.
    BizzyB726 and Island Cruiser like this.
  5. Jun 1, 2020 at 9:01 AM
    NorCal Adventures
    Scott
    Looking at a Tacoma
    Here are the two I saw. One has the graphics the other doesn't. I put in the VINs and it looks like they have that package.
  6. Jun 1, 2020 at 9:47 AM
    TacoTyusday
    TacoTyusday Well-Known Member
    Zac
    San Diego
    2014 White Tacoma TRD Baja
    I just bought a TRD TX Baja back in October last year. I believe it's virtually the same as the TRD Pro of those years, with a slightly different suspension more designed for higher offroad speeds, while the TRD Pro is more geared for crawling. We got a whole thread, here's the link. Technically, it's not a Pro, as the TRD Pro is a separate model. It's the TRD T/X Baja
    They come with Rear locker, outlet in the bed, bilstein 9100 suspension, extra lift, plastic floors instead of carpet, the gunmetal gray faux-beadlock wheels, and some of them also have graphics along the bedsides. Mine used to, but they were already removed when i bought it. still had a bit of adhesive left on there. They were a limited production run, I think 1500 of each color made?
    https://www.tacomaworld.com/threads/trd-pro-tx-baja-official-thread.360056/unread
  7. Jun 1, 2020 at 10:02 AM
    NorCal Adventures
    Scott
    Looking at a Tacoma
    Thanks for the clarification
  8. Jun 1, 2020 at 10:06 AM
    NorCal Adventures
    Scott
    Looking at a Tacoma
    Looking at the two pics I posted are they essentially the same vehicle but with different front bumpers?
  9. Jun 1, 2020 at 10:11 AM
    TacoTyusday
    Zac
    San Diego
    certainly looks like it, the bottom pic has an aftermarket plate bumper.
    i'm not 100% sure so i would look into it, but I was under the belief that the Bajas only came with the Grey beadlock wheels which are exclusive to the baja, but it's certainly possible they swapped out for black or painted/dipped them. Vin number will be the best method of checking when you're looking to buy.
    Georgeth1022 likes this.
  10. Jun 1, 2020 at 10:53 AM
    Island Cruiser
    Island Cruiser TVita
    Kauai
    Baja
    Those(or at least the 2nd Tacoma) appear to be the TX Pro which is the edition above the TRD Offroad and below the Baja. The TX Pro’s suspension is the same as the Offroad’s, just has the black beadlock style wheels and TRD exhaust in addition
    Anderson likes this.
