Anyone ever used a wireless/remote battery disconnect switch as an anti-theft device?
Discussion in '1st Gen. Tacomas (1995-2004)' started by CoastieTX, Feb 3, 2022.
  1. Feb 3, 2022 at 1:50 PM
    CoastieTX
    CoastieTX [OP] Well-Known Member
    PNW
    Original owner 1998 Tacoma TRD; 3.4 V6 with 5 MT
    Instead of a mechanical on/off switch mounted to a battery terminal, devices like this can disconnect/reconnect the battery via push-button on a key fob. Much more convenient, and secure, than a mechanical switch which needs to be accessed by opening and closing the hood.
    I know it’s not as good as other anti-theft systems, but it appears installation would be minimally intrusive. I do not like the idea of messing with my truck’s wiring.
    Any thoughts on this, and this unit in particular?
    https://www.summitracing.com/parts/sms-t3-12v#overview
  2. Feb 3, 2022 at 2:00 PM
    Andy01DblCabTacoma
    Andy01DblCabTacoma Well-Known Member
    Andy
    San Diego, CA
    01 Double Cab v6 4x4 TRD
    F: Kings SPC, R: 5100s+J59s. Custom armor.
    Few thoughts. Setting up the head unit each time would be inconvenient. But probably more important, resetting your ECU each time means that you're always going to be running on the pre-programmed map and that your ECU will never complete it's self-tests. It's probably not a good idea. A switch wired to the fuel pump is plenty sufficient.
  3. Feb 3, 2022 at 2:04 PM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    Besides what's posted above I doubt the disconnect could handle starting current being drawn through it too many times before it lets out it's magic smoke.
  4. Feb 3, 2022 at 2:11 PM
    warlock
    warlock Member
    david
    magnolia, ms
    2013 Tocoma
    • Might be good to install on the hot wire going to the starter. That way you done loose any setting on the radio.
    • David
    CoastieTX[OP] likes this.
  5. Feb 3, 2022 at 4:25 PM
    hessian42
    hessian42 Well-Known Member
    Max
    Just find the hot wire going to your fuel pump relay and put a switch on that. Done
  6. Feb 3, 2022 at 6:30 PM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
  7. Feb 4, 2022 at 10:52 AM
    CoastieTX
    PNW
    Thanks for the info. I had anticipated losing my head unit’s presets, but didn’t think of the ECU having to constantly reset itself.
