Anyone else use the Party Pig?
Discussion in 'Homebrewing' started by Databox, Dec 29, 2012.
  1. Dec 29, 2012 at 3:03 AM
    Databox
    Databox [OP] Well-Known Member
    Fernandina Beach, FL
    2007 TRD Sport SR5
    Rims and Tires
    I know the door I'm opening with the title...but here goes anyway.
    It holds 2.5 gallons of brew. I fill it when I'm bottling. Half in the pig, half in bottles.
    The problem I'm having is that the beer I put in the Pig gets so pressurized when you try and dipense some beer it's super foamy and I end up loosing a lot of brew. I've been told perhaps too much priming sugar. The thing is the beer in the bottles is perfect.
    Anybody else experience this.
  2. Dec 31, 2012 at 3:42 PM
    TheKid
    TheKid Well-Known Member
    Bay Area, Ca
    2011 Tacoma
    Where do you get one of these?
  3. Dec 31, 2012 at 3:56 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Ya, lower the sugar slightly, or orient the pig so it can vent and release SOME of the pressure.
    You want the beer carbonated, but it's over-foaming because of the excessive pressure combined with the "nozzle" effect of the dispenser.
    It's a problem with bar design. The farther from the bar the kegs are, the larger lines are needed, and it takes some trial and error balancing the CO2 pressure to deliver the product, but not overcarbonate it.
    Kegs in the basement are the hardest to deal with.
  4. Jan 2, 2013 at 12:25 PM
    Evil Monkey
    Evil Monkey There's an evil monkey in my truck
    Robert
    Escondido, CA
    07 4x4 DC SR5 TRD Off-road
    Weathertech front & rear mats, rear suspension TSB, Toytec AAL for TSB, Hi-Lift Jack, Bilstein 5100 & Toytec Adjustable coilovers, Built Right UCAs, KMC XD 795 Hoss Wheels, Definity Dakota MTs 285/75R16, Leer XR, Thule Tracker II & Thule MOAB basket
  5. Jan 3, 2013 at 1:37 PM
    Databox
    2007 TRD Sport SR5
    Rims and Tires
    Thanks Rich, I'll try that next time. If it were you how much would you reduce the sugar by? 25%...10%...5%? Or perhaps more?
  6. Jan 3, 2013 at 7:10 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    No clue.
    My buddy used to homebrew and "keg" into 5 gallon soda syrup cans for his kegerator. I brew Meade... I'm using like 64oz of honey per gallon of must (last batch was 17%!)
  7. Jan 5, 2013 at 5:25 PM
    USAFVol
    USAFVol Well-Known Member
    07 TRD Sport
    Maybe you're using too much priming sugar. Does the dispensing co2 and normal prime amount equal too much? I know it sucks but maybe add your priming sugar for bottles and your pigs separate. Trial and error.
  8. Jan 21, 2013 at 3:41 PM
    gzahn
    gzahn New Member
    NW Arkansas
    '13 TRD Offroad
    The main problem that you will face, regardless of priming sugar technique is that the dispenser on the party pig won't open "properly." Same as if you halfway pull a keg dispenser. Causes a lot of bubbles. Just keep it as cold as possible, be sure you push the dispenser in ALL the way, and then save some money to upgrade to 5-gal soda kegs. You will never go back!:)
  9. Feb 8, 2013 at 6:29 AM
    rhion82
    rhion82 El Duderino
    Mitchell
    TN/GA
    16 Taco
