Anyone else have a squeaky clutch pedal?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by RustysTaco, Jul 14, 2017.
  1. Nov 2, 2021 at 4:24 PM
    #61
    su.b.rat
    su.b.rat broken truck
    try getting a bit of disc brake grease on two fingers (with a glove, of course) and rub it into the inner and outer portions of the coil of the return spring. you may also grease the pivot points on the assembly. this seems to work better than stuff like lithium because it's thicker and won't run off. this works for most although some have different issues or methods.
    welcome to TW by the way.
    shakerhood and evmibo[QUOTED] like this.
  2. Nov 2, 2021 at 4:25 PM
    #62
    TriniPhantom
    TriniPhantom Well-Known Member
    Bay Area, California
    2018 Tacoma TRD Off Road DCSB
    Prinsu roof rack, Budbuilt Sliders, Avid Bumper Guard, MESO Ultimate Turn Signals, Door sill decals, Raptor Lights, Tailgate inserts, Mudflaps, Tri-fold Tonneau, DC Motorsports Muffler Tip, TVD Vinyl Decals, Many Interior Mods.
    I used some Permatex Brakes Grease a couple months ago. Get under your dash and put it everywhere in the pedal where there are parts moving against each other. Haven't heard and squeak since. Actually forgot I had the issue.
    Tacowin1013 and shakerhood like this.
  3. Nov 2, 2021 at 4:27 PM
    #63
    Woodini
    Woodini Well-Known Member
    Ray
    Daytona Beach Shores
    89 Pickup 22RE 4wd
    LCE i/h/e OME susp (install soon) 17” fn counter steer, gonna buy new rubber
    Mine squeaks but is an 89 :D need to put some lubey on it
    shakerhood likes this.
  4. Nov 2, 2021 at 4:47 PM
    #64
    evmibo
    evmibo New Member
    Fort Myers, FL
    2020 Mag Gray TRD Sport XP 6MT
    Thanks for the welcome and quick responses. Should I also grease up the master cylinder push rod?
    I was down there this afternoon trying to identify where the noise was coming from. I think it’s the clutch pedal spring holder, but could also be the spring itself, or the pedal bushing.
  5. Nov 2, 2021 at 8:15 PM
    #65
    stealthmode
    stealthmode Well-Known Member
    Alberta
    2016 Short N Stubby Bed- MGM
    Front and Rear lifts Tires ECGS bushing Lots of other crap +HP sticker
    Are all MTs eligible for TSB? Even if out of warranty?
  6. Nov 3, 2021 at 2:08 AM
    #66
    s14brent
    s14brent Member
    Brent
    Las Vegas
    2021 TRD OR 6MT
    I thought i was going crazy with this issue. Glad I found this post and about the tsib. Didn't expect it from a brand new truck tbh, i complained at my first oil change service and they did the tsib for me since they had the parts on hand (which apparently is rare now days). So thanks guys'!
  7. Nov 3, 2021 at 4:51 AM
    #67
    su.b.rat
    not if out of warranty.
    stealthmode[QUOTED] likes this.
  8. Nov 3, 2021 at 5:16 AM
    #68
    jon316
    jon316 Member
    Jon
    2019 TRD OR
    Ask the dealer about T-SB-0112-19. They'll replace the pedal and the master cylinder. Have them adjust the pedal height when they're done. I didn't and my pedal height was too high.
  9. Nov 3, 2021 at 5:23 AM
    #69
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    Had a squeaky steering assembly...does that count?
  10. Nov 3, 2021 at 8:53 AM
    #70
    stealthmode
    Alberta
    Boo
  11. Nov 3, 2021 at 10:48 AM
    #71
    su.b.rat
  12. Nov 3, 2021 at 2:31 PM
    #72
    stealthmode
    Alberta
    You got time for that. I don't. Lol.
    But I have seem that thread and contemplated it.
    You did it for a gen 3?
  13. Nov 3, 2021 at 2:53 PM
    #73
    su.b.rat
    yeah i'm in a 2017.
  14. Nov 3, 2021 at 6:19 PM
    #74
    evmibo
    evmibo New Member
    Fort Myers, FL
    Added brake disc grease this morning to all moving parts. Good at first then it started to come back. I’m 90% sure my squeak is coming from the rod going into the master cylinder after inspecting it some more... added another application to the the rod and master cylinder and all noise is gone. Will see if it lasts...
  15. Nov 3, 2021 at 6:46 PM
    #75
    HAILST8
    HAILST8 Retired Munitioneer
    Russ
    Florida
    2022 Sport SWDCSB4WD
    Stock+
    Put the grease where the rod contacts the pedal. Easy application with a q-tip. That's what fixed it for me about a year ago. No issues since.
    TriniPhantom and shakerhood like this.
  16. Nov 3, 2021 at 6:56 PM
    #76
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    I know it's a bit tight under there but find pushing the pedal down with my left hand to cycle the pedal exposes more for you to reach up there. I use those long wooden Q-Tips and probably do it once a year or so and it's totally silent.
  17. Nov 4, 2021 at 1:44 PM
    #77
    tacologico
    tacologico New Member
    My squeak is not inside. only when pressed the pedal with my left hand i can hear it out there. but i still lubricate the piston though. any leads?
  18. Nov 4, 2021 at 2:44 PM
    #78
    6MTPro
    6MTPro Well-Known Member
    HI -> CA
    2018 TRD Pro 6MT | 2004 4Runner 4.7 V8
    Tune, 285/75/16, Diode Dynamics, PPF, Bakflip Mx4, Meso, Cali Raised, TJM
    There is a TSB for it so the dealership should fix it.
  19. Nov 5, 2021 at 2:16 PM
    #79
    tacologico
    I finally got it! after studying some TW threads, I went to the slave cylinder and carefully removed the boot from housing that covers the transmission and applied a brush with grease to the fork ball.
    Then I saw a video showing the opening the boot has facing rear where you can insert lubricant with a nozzle or grease without removing the boot at all! easy!
    https://www.youtube.com/watch?v=_Ky33cKdyOo
    doublethebass likes this.
  20. Nov 7, 2021 at 7:35 AM
    #80
    TacoJeff19
    TacoJeff19 Well-Known Member
    Jeff
    19' DCSB OR
    OVtune, ADM, Hurst Short Throw.
    I don't have a picture of it. But try some dry Teflon lube on the spring and pivot points of the pedal
