anybody's AUX jack get jacked up?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by NiceGuyEddie, Apr 16, 2014.
  1. Apr 16, 2014 at 8:36 PM
    NiceGuyEddie
    NiceGuyEddie [OP] Well-Known Member
    Chino, SoCal
    none yet
    i did a search but i didn't find anything.
    i am absolutely positive the problem is the AUX jack, it's not the cord. (tried multiple cords, each male end, in multiple things.)
    when using the iPod, the signal cuts out, most often switching automatically to CD or FM radio. sometimes i can't get the unit to switch back to AUX. you have to keep moving around the cord, in-n-out until it gets a signal again, then you can switch back to AUX. then 10 minutes later, you get static and it cuts out again.
    anybody know what's involved in replacing the female AUX jack?
  2. May 28, 2014 at 6:39 AM
    FX Jenkins
    FX Jenkins Well-Known Member
    NOVA
    2010 Taco OR, 2010 4Run Limited, 2017 TRD Pro
    YEP...but I don't think its the AUX jack. I think it is Aux/CD button or something within the radio itself. Reason I say that is...you should be able to change the radio to Aux mode without having a cord in the jack or even an incoming signal from an iPhone or other device. I know this because when mine started going out on me, I would try to plug and unplug the cord, wiggle it multiple times etc, etc and it would finally change over... but I found that sometimes I could get it to change over by just selecting Aux/CD with the button, without anything plugged into the jack. Prob got progresivly worse over the last 6 months until this am, can't get it go to AUX mode at all, but the CD player still works if I slide one in... Considering changing out the whole unit now to put in something with a nav screen, because I can't go without Pandora radio...was searching for Radio change out mods when I found your initial post.
  3. May 28, 2014 at 6:42 AM
    jbmccul
    jbmccul Well-Known Member
    2021 GMC Sierra AT4, 2019 Audi A5, 2017 Audi Q5
    Mine is, won't connect. Gonna get the dealer to look at it this weekend
  4. May 28, 2014 at 6:46 AM
    FX Jenkins
    NOVA
  5. May 28, 2014 at 6:50 AM
    fubar718
    fubar718 Well-Known Member
    Jose
    NJ
    2010 double cab, TRD offroad
    mine took a crap on me a few months ago, determined that it was the jack itself. ended up just replacing the radio and streaming from my phone
  6. Jun 11, 2014 at 5:57 AM
    Mercer86
    Mercer86 New Member
    Monroe Wa
    09 Toyota Tacoma TRD
    Hey guys, I just fixed mine last night by soldering some of the connections. Mine wasn't working as well for a long time and finally looked up a youtube vid for it. It works now and doesn't shut off anymore BUT the sound come mustily from the driver side tweeter speaker. Bugs the hell out of me so I'm going to try again, might of just missed a spot with my soldering gun.
  7. Jun 11, 2014 at 6:13 AM
    iseeredandyellow
    iseeredandyellow I wanna go fast!
    Jeff
    San Diego
    10 DCSB 4wd OR Speedway Blue
    ^^^^^ This. Had the same issue. Just apply a small amount of solder to all of the connectors. Issue will be corrected.
  8. Jun 12, 2014 at 6:00 AM
    Mercer86
    Mercer86 New Member
    Monroe Wa
    [FONT=&quot]I noticed there's one spot you don't solder. I did solder I believe all 5 little connections but when I hooked it up there was no sound at all so I took off some solder on one connection and it worked perfectly. Don't mind the mess of solder[/FONT]. [​IMG] Hope that helps you out, sorry I didn't take a pic of the fixed aux jack just the one when I soldered all. I highlighted the spot you DONT solder.
  9. Jun 12, 2014 at 8:40 AM
    357sig
    357sig Donut king
    dough boy
    donut shop
    Gold digger
    Mine does the same thing. Except i can always go back to aux. Even had the plug changed and few days later same shit. I have to hang the cord up over my cb radio and around cb cord. That works until I hit a bump and the cord moves lol
  10. Jul 21, 2014 at 10:00 AM
    FX Jenkins
    NOVA
    Fixed mine by doing the repair in the video, only soldering the middle two connectors together... took me a few tries and I tested it before putting everything back together but its been about a month now and no issues.
  11. Jul 21, 2014 at 10:27 AM
    Pool Runner
    Pool Runner Well-Known Member
    Nor Cal
    '14,TRD/OR, Entune & Nav '13 Subaru Outback
    Lowes Slimline Tool box, OEM Bug shield.
    Are the Aux jacks the same on 2014? I only ask, as sometimes I have my iphone plugged in via the Aux, to charge it. At least 3 times since I've had my truck, the sound or music just quit, and I couldn't figure out why? This is on a truck two months old with 4500 miles on it.
  12. Jul 21, 2014 at 11:10 AM
    1stTruck
    1stTruck Well-Known Member
    Jim
    South Carolina
    PreRunner
    Billies 5100's front set to 1.75 plus 1/4 taco lean spacer. Rears Billies plus AAL for a 2" leaf. 265/75/16 BGF's. Double din Kenwood stereo w/bluetooth and steering wheel controls and JBL speakers front & rear. Heavy duty battery. Billet grill blacked out. K&N air filter and MBRP cat-back. Just tuned it up new plugs and new front brake pads. Steel powered coated tailgate cap. Billet Grill painted black & factory roof racks. Oh new head lights thanks to toyota.
    Mine bit the dust on a road trip, made me so mad I replaced the entire cheap OEM stereo w/a new head unit. Should have done so months ago. W/4 new speakers now I have a real stereo. Great sound USB + AUX & Bluetooth. :rockband:
  13. Jul 21, 2014 at 12:09 PM
    FX Jenkins
    NOVA
    Your Aux jack doesn't provide power/charge to the phone. It just input for audio from your phone to the sterio speaker system, but Yes I think Toyota is using the same aux jack units in a wide variety of models/ years. Even if you have it replaced under warranty, its liable to happen again. You must beef up the solder joints.
  14. Jul 22, 2014 at 10:03 AM
    HiLuxWisher
    HiLuxWisher New Member
    Texas
    14 4x4 SR5 Texas Edition
    I think what you are talking about is the USB port under the AUX jack. The AUX jack is just the "headphone" type jack.
    I have a 2014 Taco and I have had mixed results plugging my iPhone cable into that port. I have a 3S iPhone, and usually get an error message (factory radio) when connecting with the cable. It will play through the cable, but the audio quality is greatly reduced vs just going the Bluetooth route. Bottom line up front, I am using one of the charging jacks with a USB charger and running Bluetooth. Audio quality is great, battery stays charged, no error messages on the factory display.
