Anybody used Mobil 1 or Amsoil 75w-90?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Yurizx6r, Nov 8, 2017.
  1. Nov 9, 2017 at 8:27 AM
    Sig45
    Sig45 Well-Known Member
    Mark
    Maine
    FYI - I run this in front & rear diff as well as transfer case.
    Yurizx6r[OP] likes this.
  2. Nov 9, 2017 at 10:54 AM
    PackCon
    PackCon Well-Known Member
    Connor
    2017 Subaru Forester Limited
    This. I believd the Amesoil Severe Gear goes to 100k miles.
    Boutique oils are more for extended intervals. If you aren’t going to do this don’t bother with the more expensive stuff.
  3. Nov 9, 2017 at 10:57 AM
    glk21c
    glk21c Well-Known Member
    MD
    2007 Silver Tacoma TRD Sport 4x4
    been using the AMSOIL severe gear ( the weight you mentioned as well) for about 261,000 miles. OEM was drained and replaced with the AMSOIL at 100,000. drained and refilled again at 200,00 with AMSOIL. Fluid in the difffs and t-fer case currently has about 161,000 miles on it. (361,000 total right now) I'll probably change it out at 400,000.
    Oh, you'll still need the limited slip additive (I used AMSOIL as well) in the limited slip rear. I thought the same thing originally, shouldn't need it. You do.
    needless to say, I recommend the AMSOIL Severe gear oil
    Good luck
  4. Nov 9, 2017 at 11:54 AM
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    spot on advice, just change it regularly at 30k miles, usually an over the counter gear oil works just as well as the boutiques when doing those intervals. I was looking at an FJ owners forum and a lot are using the Walmart 75w90 gl5 semi syn in thiers FJs instead of the req'd 75w85 and are holding up fine with it.
  5. Nov 9, 2017 at 12:41 PM
    thegardentool
    thegardentool Active Member
    2013 Tacoma TX Baja Barcelona Red
    I changed all 3 with Mobil 1 75w90 LS about 2 years ago and roughly 20k miles later of mostly city driving I'm not hearing or feeling anything that gives me concern. Will probably go ahead and change them out over the winter or early spring just due to age. Will be curious if they are anywhere near as nasty as the factory oil was at ~30k miles.
    Based on my recent experience at the dealership with an oil change I ran out of time to do myself, and asked them what the upcharge would be for synthetic I can fully believe $37+/quart for diff oil.
  6. Nov 9, 2017 at 2:11 PM
    Yurizx6r
    Yurizx6r [OP] Well-Known Member
    2015 Pre Runner, TRD Sport
    Just curious. Dud anybody else besides glk21c with the TRD Sport (Limited slip dif) need any more LS additive with the Mobil 1?
  7. Nov 9, 2017 at 2:13 PM
    ecgreen
    ecgreen overeducated redneck
    Sean
    2015 4x4 4-banger Access
    I use valvoline, cheaper and works just fine.
  8. Nov 9, 2017 at 2:32 PM
    80schild
    80schild Well-Known Member
    Chad
    Flori-Bama
    2007 TRD Sport Access Cab
    I don't believe you should need any additive at all since you don't have a mechanical limited slip. The additive is for 05-08 Sport models.
    FWIW, I used CarQuest 80w-90 with a tube of additive in my 07 and it works just fine.
    Yurizx6r[QUOTED][OP] likes this.
  9. Nov 9, 2017 at 10:19 PM
    DaveB.inVa
    DaveB.inVa Well-Known Member
    SWVa
    2015 AC SR5 4x4 V6 AT MGM
    Oil Catch Can, OIl Pressure and Temp Gauges, Falken Wildpeak A/T3W 265/70R16
    I run Amsoil 75W-90 Severe Gear as well, the original poster won't need the LS additive though due to the "limited slip" function in his being performed by the ABS system. Yours would since it's an 07.
    The Amsoil Severe Gear line does have the friction modifier included, but it's on the light side. Every clutch pack type LSD I've seen use Amsoil did have to add a little extra friction modifier to prevent chatter.
  10. Nov 9, 2017 at 11:07 PM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    Mobile 1 here also,no problems.
