Anybody used BlazeCut automatic underhood fire extinguisher?
Discussion in 'Product Reviews' started by alphabravo, Mar 3, 2015.
  1. Mar 3, 2015 at 10:07 PM
    alphabravo
    alphabravo [OP] Well-Known Member
    Christopher
    Canada via FL
    2003 Tacoma TRD
    Supercharger AntiDark Hood Light Redline Tuning Hood Struts Morimoto Projectors Grey Wire Mod Tundra 13WL Brake Conversion EBC ED Pads and GD Rotors Mean Green Starter DC Power 250A Alternator Odyssey PC2150 Battery, Artec Cage ADS shocks Total Chaos UCA ComeUp Winch, Factor 55 Splicer Relentless bumpers OTRATTW Switches, Bussman 15304-2-2-4 RTMR, Paranoid Fabrication switch brackets Jensen JHD3630BT Morimoto XB LED Fogs Deaver Custom Springs Ivan Stewart TRD Wheels, Pro Series TRD Wheels
  2. Jul 3, 2015 at 9:18 AM
    Trapperpete52
    Trapperpete52 Well-Known Member
    Pete
    98 Tacoma 4 X 4 5 speed 93 Tacoma 4 X 4 5 speed 95 Tacoma 4 X 4 5 speed
    roll bar and lights
    Sounds and looks like a gimmick to me. I worked in a mine that ran automatic fire suppression on the drills. The factory came out and installed them. One went off as a small exhaust leak hit the main canister and it got hot enough to expand the gas in the deploy gas cylinder making it go off while the engine was running wide open. The resulting mess took a week to clean the drill enough to run again.
    The unit used the standard baking soda to suffocate a fire. The media was sucked into the engine and even though all oils and fuel were drained and refilled. All air filters were changed and ducts washed out it was inside the engine. Within 60 hours of operation the engine didn't have enough compression to start and run. The bearings also showed sign of premature wear from the media. Long story short if use a chemical fire extinguisher on an engine fire be prepared to do a full rebuild IMHO.
  3. Apr 4, 2022 at 12:05 PM
    Owhatafeeling
    Owhatafeeling Belly Bomber Squadron
    South Florida
    2004 extended cab
    Resurrecting the thread. Blazecut uses gas to remove oxygen from the engine compartment to douse flames. Somewhat popular in VW circles.
    https://m.youtube.com/watch?v=iePku-2jh7Y
    There seems to be similar products now, but haven’t heard any testimonials how it saved someone’s vehicle.
    Always the same, “hope I never have to find out”.
