Any trailer light kits that don't require a wire run to the battery?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Commocean, Jun 28, 2022.
  1. Jun 28, 2022 at 10:50 AM
    Commocean
    Commocean [OP] Well-Known Member
    St. Petersburg, FL
    2023 Tacoma SR5 DCSB 2.7L Ice Cap
    Haven't come across anything yet myself.
  2. Jun 28, 2022 at 10:51 AM
    6 gearT444E
    Deep South
    Herculiner Hootus
    How else would the lights get power?
  3. Jun 28, 2022 at 10:52 AM
    Shellshock
    Iowa
  4. Jun 28, 2022 at 10:56 AM
    Commocean
    St. Petersburg, FL
    Same way the tail lights get power. I don't understand why you can't just tap into the wiring at the tail light. With that said, electrical is my Achilles heel.
  5. Jun 28, 2022 at 10:58 AM
    6 gearT444E
    Deep South
    Herculiner Hootus
    a standard 4 or 5 plug flat doesn’t require any wiring to the battery. If you want a charge circuit for a 7 pin you’ll need to run that wire to battery. You could always install a 7 pin and leave the trickle charger function empty at the connector.
    Shellshock likes this.
  6. Jun 28, 2022 at 11:08 AM
    Commocean
    St. Petersburg, FL
    So, for a basic trailer with a flat connector, I could use one of the Curt kits that taps into the tail lights, and not have to run the power wire?
    six5crèéd likes this.
  7. Jun 28, 2022 at 11:13 AM
    Farcedude
    Farcedude Well-Known Member
    Greg
    Westminster, CO
    ‘23 MGM DCSB OR
    For the Curt 4 flat kit for my truck, I did have to run a power wire to the battery, sadly. I don’t think you can get away with just tapping off the existing wiring on a modern truck.
  8. Jun 28, 2022 at 3:15 PM
    6 gearT444E
    Deep South
    Herculiner Hootus
    im not 100% sure but as long as the wiring can handle the extra load it shouldn’t be a problem. Usually manufactures will have the install instructions.
  9. Jun 28, 2022 at 6:11 PM
    Mas Olas
    Mas Olas Well-Known Member
    Woody
    10 miles north or 400 miles south of the border.
    2020 Blacked-Out White DCLB TRD OffRoad 4x4
    As a knuckle dragger are we assuming you don’t have towing option installed? If thats the case then you should save your time and aspirin headaches and just run the wire forward. Ground anywhere along the path. Modern rigs can sense additional taps on circuits.
    Farcedude likes this.
  10. Jun 28, 2022 at 8:42 PM
    Spacecoast
    Spacecoast Well-Known Member
    2022 White SR5 2.7L
    Trailer wiring kit, hitch, seat risers
    You can, but that is a weak system. Yeah, I spent about an hour on my back running the wire, but I do things as perfectly as possible. The kit I used included an integrated fuse in the wire and has a power distribution box..getting its power directly from the battery. There is no electrical drain. The rest of the harness plugs into the rear lights. No cutting...no splicing. That is the correct way of doing it.
  11. Jun 28, 2022 at 8:57 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
  12. Jun 29, 2022 at 5:52 AM
    Spacecoast
    2022 White SR5 2.7L
  13. Jun 29, 2022 at 6:31 AM
    Sungod
    Sungod Well-Known Member
    St Augustine
