any thoughts on Sequoia's off-roading capabilities?
Discussion in 'Off-Roading & Trails' started by bd., Aug 9, 2019.
  1. Aug 9, 2019 at 4:35 PM
    bd.
    bd. [OP] Member
    bd
    Southeastern Pa
    looking to get a tacoma. i am starting to catch the tacoma bug, bad, i'm afraid
    want double cab with a long bed and a hard shell.
    Let me know what you think about Sequoia's off-roading capabilities.
  2. Aug 9, 2019 at 4:44 PM
    lucky13don
    lucky13don Well-Known Member
    Don
    Milton, fl
    R.I.P.04 tacoma prerunner, 04 sequoia 4x4
    Too many to list
    20190330_113330.jpg first thing ditch the running boards. I went 285/70r17 on tires slightly rub a full lock. Theres a Facebook group and those guys go all out with they're rigs. Also bruteforce fab makes killer armor for them. Mine is 1st gen. 4.7l bulletproof motor. Gets crap fuel economy tho...lol.
    bd.[OP] likes this.
  3. Aug 9, 2019 at 4:52 PM
    bd.
    bd. [OP] Member
    bd
    Southeastern Pa
    Are there years that are better for off roading than others?
    I read about a redesign that seemed to insinuate that on wikipedia, but honestly, I am not sure that is necessarily accurate.
  4. Aug 9, 2019 at 4:56 PM
    lucky13don
    Don
    Milton, fl
    Too many to list
    Theres more aftermarket support for 1st gens. 2nd gen is hit or miss and latest is just not available yet. Also 1st gens are cheap. New will run you 70k fully loaded. They tow great also. I tow my camper and forget its there sometimes. With any luck i will start building mine up soon
  5. Aug 9, 2019 at 4:57 PM
    dfanonymous
    dfanonymous Well-Known Member
    2019 Voodoo Blue Tacoma TRD Pro.
    -Shmellfab rocksliders.... -BD ditch lights -Cali raised ditch light brackets -Sway bar discos -Auxbeam aux 6 gang -Uptop Bravo -Rci trans skid -Rci cat guards -Trd pro eibach lift springs -Hypertech speedo calibrator Etc.
    It ain’t no 4runner
    lucky13don likes this.
  6. Aug 9, 2019 at 4:59 PM
    lucky13don
    Don
    Milton, fl
    Too many to list
    They are way heavier. Can haul 8 ppl in comfort, tow great. But use fuel like its going out of style. And wider too
    bd.[OP] likes this.
  7. Aug 13, 2019 at 1:55 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    I would avoid such a large vehicle if you're in the woods or on tight trails a lot. Early Sequoias are only marginally bigger than 5th gen 4Runners, though... I don't like the size of my '17 4Runner for trail use, I definitely wouldn't want anything bigger.
    I'm sure they wheel "ok" but they are far from ideal. Driving my dad's Sequoia around the streets is like maneuvering a battleship, I can't imagine on a trail, lol.
    Honestly, there isn't *that* much more stuff you can fit inside, anyway. There really is only a few more inches in all directions in the cargo area. Main thing you get is more seating room.
    So unless you wheel with 7 of your closest friends or are 6'6" 320#, I'd avoid it for off-roading.
  8. Oct 4, 2019 at 6:44 PM
    neverstuck
    neverstuck Well-Known Member
    Guido
    Lebanon
    13 DCLB sport
    slide-in camper, OME Nitros w 884's and Dakars, Michelin A/T2, Pro EFX heated towing mirrors, Timbren HD bumpstops, KB VooDoo bed rails and tailgate cap, ImMrYo rvm bracket, G-Tek Fab door sill protectors, Ultragauge, window visors, hood deflector, Wet Okole seatcovers, in-vehicle safe.
    Old thread, but I’ll chip in with my thoughts anyway.
    I went from 2013 DCLB Tacoma to a 2003 sequoia. It’s about a foot shorter and more maneuverable wheeling around lots or trails. It’s more than 1000 lbs heavier with a 4 speed tranny instead of 5, and it still gets better mileage than my Tacoma did.
    I took out the second and third row seats and put in a full 10” thick memory foam twin size bed on an adjustable (inclining) steel bed frame. It doesn’t even come as far as the beginning on the rear passenger footwells, and there’s about a 12” wide void along one side of the bed. There a TON of room in it. Ive owned a 4Runner. This thing feels similar in size to a 2nd gen taco, but has a lot more room in it than a 4Runner.
    I expected it to be a pig on fuel but if I go easy on the throttle and stick within 10 of the speed limit, I’m getting 20mpg.
    Find one that’s been taken care of, with a clean frame (no rust) and I think it’s one of the best vehicles you can buy for the price.
    Heavy vehicle = Safe vehicle.
    Inertia is real.
    cornbread_wy, Durango95 and Benson X like this.
